Banana Pi - apt update no longer works...
Go to solution Solved by SteeMan,
Hello!
I haven't had any problems with the updates so far, but today it no longer works.
Maybe someone has an idea what the problem is?
armbian.list
deb http://mirror-eu-de1.armbian.airframes.io/dl/ buster main buster-utils buster-desktop
deb http://apt.armbian.com buster main buster-utils buster-desktop
apt update...
root@fulla:~# apt-get --allow-releaseinfo-change --allow-insecure-repositories update
Hit:2 http://ftp.de.debian.org/debian buster InRelease
Hit:3 http://ftp.de.debian.org/debian buster-updates InRelease
Hit:4 http://ftp.de.debian.org/debian buster-backports InRelease
Hit:5 http://security.debian.org buster/updates InRelease
Ign:1 https://mirror-eu-de1.armbian.airframes.io/dl buster InRelease
Ign:7 https://mirror-eu-de1.armbian.airframes.io/dl buster Release
Ign:6 http://fi.mirror.armbian.de/apt buster InRelease
Ign:8 https://mirror-eu-de1.armbian.airframes.io/dl buster/main armhf Packages
Ign:9 https://mirror-eu-de1.armbian.airframes.io/dl buster/main all Packages
Ign:11 https://mirror-eu-de1.armbian.airframes.io/dl buster/main armhf Contents (deb)
Err:10 http://fi.mirror.armbian.de/apt buster Release
  404  Not Found [IP: 65.21.120.247 80]
Ign:12 https://mirror-eu-de1.armbian.airframes.io/dl buster/main all Contents (deb)
Ign:13 https://mirror-eu-de1.armbian.airframes.io/dl buster all Contents (deb)
Ign:14 https://mirror-eu-de1.armbian.airframes.io/dl buster armhf Contents (deb)
Ign:15 https://mirror-eu-de1.armbian.airframes.io/dl buster/buster-utils armhf Packages
Ign:16 https://mirror-eu-de1.armbian.airframes.io/dl buster/buster-utils all Packages
Ign:17 https://mirror-eu-de1.armbian.airframes.io/dl buster/buster-utils all Contents (deb)
Ign:18 https://mirror-eu-de1.armbian.airframes.io/dl buster/buster-utils armhf Contents (deb)
Ign:19 https://mirror-eu-de1.armbian.airframes.io/dl buster/buster-desktop all Packages
Ign:20 https://mirror-eu-de1.armbian.airframes.io/dl buster/buster-desktop armhf Packages
Ign:21 https://mirror-eu-de1.armbian.airframes.io/dl buster/buster-desktop armhf Contents (deb)
Ign:22 https://mirror-eu-de1.armbian.airframes.io/dl buster/buster-desktop all Contents (deb)
Err:8 https://mirror-eu-de1.armbian.airframes.io/dl buster/main armhf Packages
  404  Not Found [IP: 161.97.118.90 443]
Reading package lists... Done
W: The repository 'http://mirror-eu-de1.armbian.airframes.io/dl buster Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://apt.armbian.com buster Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
No matter which mirror server is used, the same error message always appears with armbian.
Does anyone have any idea what I could try or what the problem could be?
I tested it with wget.
root@fulla:~# wget https://mirror-eu-de1.armbian.airframes.io/dl
--2024-03-09 14:09:01--  https://mirror-eu-de1.armbian.airframes.io/dl
Resolving mirror-eu-de1.armbian.airframes.io (mirror-eu-de1.armbian.airframes.io)... 161.97.118.90
Connecting to mirror-eu-de1.armbian.airframes.io (mirror-eu-de1.armbian.airframes.io)|161.97.118.90|:443... connected.
HTTP request sent, awaiting response... 308 Permanent Redirect
--2024-03-09 14:09:01--  https://mirror-eu-de1.armbian.airframes.io/dl/
Reusing existing connection to mirror-eu-de1.armbian.airframes.io:443.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: ‘dl’
dl                                          [ <=>        ]  39.16K  --.-KB/s    in 0.01s
2024-03-09 14:09:01 (2.74 MB/s) - ‘dl’ saved [40102]
Edited by R I
  • Solution
Buster was recently moved to end of support status in Armbian (Debian ends support in a couple of months too).  Buster was released nearly five years ago.  It is time to upgrade.
@SteeMan
Oh... thanks.
Has all worked well for me so far, didn't need any major updates as I don't have much running on there.
Can you recommend a current release that I can upgrade to without any problems?
I think it's enough if I just add it to the source.list?
Or would it be better to set everything up from scratch? I've had it running for years and have never changed much.
Edit:
Just updated to bullseye, seems to be working well so far. Bullsyes should buy me some more time, I hope.
Edited by R I
