Boot error
When I run the Linux kernel on the Odroid XU4 board, it enters a loop with this error during boot:
U-Boot 2017.05-00008-g6a9ddb8303-dirty (May 19 2020 - 19:48:01 +0900) for ODROID-XU4
CPU:   Exynos5422 @ 800 MHz
Model: Odroid XU4 based on EXYNOS5422
Board: Odroid XU4 based on EXYNOS5422
Type:  xu4
DRAM:  2 GiB
MMC:   EXYNOS DWMMC: 0, EXYNOS DWMMC: 1
MMC Device 0 ( SD ): 29.7 GiB
mmc_init: -5, time 4
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Press quickly 'Enter' twice to stop autoboot:  0
reading /boot.ini
2401 bytes read in 4 ms (585.9 KiB/s)
## Executing script at 43e00000
reading config.ini
6911 bytes read in 5 ms (1.3 MiB/s)
ini: Imported macaddr as 00:1e:06:61:7a:39
ini: Imported vout as hdmi
ini: Imported HPD as true
ini: Imported cecenable as false
ini: Imported disable_vu7 as false
ini: Imported ddr_freq as 825
ini: Imported overlay_resize as 16384
ini: Imported overlay_profile as
ini: Imported overlays as spi0 i2c0 i2c1 uart0
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
reading zImage
7299952 bytes read in 490 ms (14.2 MiB/s)
reading exynos5422-odroidxu4.dtb
88559 bytes read in 11 ms (7.7 MiB/s)
reading overlays/spi0.dtbo
691 bytes read in 5 ms (134.8 KiB/s)
reading overlays/i2c0.dtbo
224 bytes read in 5 ms (43 KiB/s)
reading overlays/i2c1.dtbo
226 bytes read in 5 ms (43.9 KiB/s)
reading overlays/uart0.dtbo
227 bytes read in 6 ms (36.1 KiB/s)
Kernel image @ 0x40008000 [ 0x000000 - 0x6f6370 ]
## Flattened Device Tree blob at 44000000
   Booting using the fdt blob at 0x44000000
   reserving fdt memory region: addr=44000000 size=2c000
   Using Device Tree in place at 44000000, end 4402efff
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 6.1.77+ (odroid@odroid) (gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Wed Mar  6 17:56:35 -03 2024
[    0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Hardkernel ODROID XU4
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 128 MiB at 0x00000000b6800000
[    0.000000] Samsung CPU ID: 0xe5422001
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
[    0.000000]   HighMem  [mem 0x0000000070000000-0x00000000be9fffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000be9fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000be9fffff]
[    0.000000] Running under secure firmware.
[    0.000000] percpu: Embedded 17 pages/cpu s39124 r8192 d22316 u69632
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516928
[    0.000000] Kernel command line: console=tty1 console=ttySAC2,115200n8 root=UUID=e139ce78-9841-40fe-8823-96a304a09859 rootwait ro fsck.repair=yes net.ifnames=0  HPD=true vout=hdmi e
[    0.000000] hdmi: using HDMI mode
[    0.000000] Unknown kernel command line parameters "false HPD=true vout=hdmi", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1903668K/2074624K available (12288K kernel code, 1139K rwdata, 2940K rodata, 2048K init, 363K bss, 39884K reserved, 131072K cma-reserved, 1157120K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000000] clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000032] genirq: irq_chip COMBINER did not update eff. affinity mask of irq 57
[    0.001509] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.001535] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.001555] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001572] Ignoring duplicate/late registration of read_current_timer delay
[    0.002351] Console: colour dummy device 80x30
[    0.003109] printk: console [tty1] enabled
[    0.003176] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.003223] CPU: Testing write buffer coherency: ok
[    0.003313] pid_max: default: 32768 minimum: 301
[    0.003464] LSM: Security Framework initializing
[    0.003658] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003711] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.005467] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
[    0.006882] cblist_init_generic: Setting adjustable number of callback queues.
[    0.006928] cblist_init_generic: Setting shift to 3 and lim to 1.
[    0.007116] cblist_init_generic: Setting adjustable number of callback queues.
[    0.007151] cblist_init_generic: Setting shift to 3 and lim to 1.
[    0.007359] Setting up static identity map for 0x40200000 - 0x40200060
[    0.007711] ARM CCI driver probed
[    0.008305] Exynos MCPM support installed
[    0.008707] rcu: Hierarchical SRCU implementation.
[    0.008734] rcu:     Max phase no-delay instances is 1000.
[    0.010012] smp: Bringing up secondary CPUs ...
[    0.011171] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
[    0.012478] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
[    0.013707] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
[    0.014902] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.014919] CPU4: detected I-Cache line size mismatch, workaround enabled
[    0.014927] CPU4: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.015018] CPU4: Spectre BHB: enabling loop workaround for all CPUs
[    0.016286] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.016300] CPU5: detected I-Cache line size mismatch, workaround enabled
[    0.016307] CPU5: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.017624] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.017638] CPU6: detected I-Cache line size mismatch, workaround enabled
[    0.017645] CPU6: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.018922] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.018937] CPU7: detected I-Cache line size mismatch, workaround enabled
[    0.018945] CPU7: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.019180] smp: Brought up 1 node, 8 CPUs
[    0.019244] SMP: Total of 8 processors activated (384.00 BogoMIPS).
[    0.019276] CPU: All CPU(s) started in HYP mode.
[    0.019297] CPU: Virtualization extensions available.
[    0.020752] devtmpfs: initialized
[    0.042523] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.042807] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.042850] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.045974] pinctrl core: initialized pinctrl subsystem
[    0.048866] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.052562] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.054296] audit: initializing netlink subsys (disabled)
[    0.054571] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[    0.055157] thermal_sys: Registered thermal governor 'step_wise'
[    0.055436] cpuidle: using governor menu
[    0.055910] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.055941] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.185987] EXYNOS5420 PMU initialized
[    0.292725] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.294707] fbcon: Taking over console
[    0.296476] iommu: Default domain type: Translated
[    0.296501] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.296909] usbcore: registered new interface driver usbfs
[    0.296979] usbcore: registered new interface driver hub
[    0.297050] usbcore: registered new device driver usb
[    0.297807] s3c-i2c 12c70000.i2c: slave address 0x00
[    0.297837] s3c-i2c 12c70000.i2c: bus frequency set to 378 KHz
[    0.298170] s3c-i2c 12c70000.i2c: i2c-0: S3C I2C adapter
[    0.298383] s3c-i2c 12c80000.i2c: slave address 0x00
[    0.298412] s3c-i2c 12c80000.i2c: bus frequency set to 65 KHz
[    0.298719] s3c-i2c 12c80000.i2c: i2c-2: S3C I2C adapter
[    0.299209] mc: Linux media interface: v0.10
[    0.299295] videodev: Linux video capture interface: v2.00
[    0.299921] Advanced Linux Sound Architecture Driver Initialized.
[    0.301010] clocksource: Switched to clocksource mct-frc
[    0.301481] VFS: Disk quotas dquot_6.6.0
[    0.301559] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.315803] NET: Registered PF_INET protocol family
[    0.316073] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.317886] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.317937] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.318036] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.318132] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.318434] TCP: Hash tables configured (established 8192 bind 8192)
[    0.318557] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.318617] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.318871] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.318931] NET: Registered PF_XDP protocol family
[    0.320817] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.322010] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.324097] Initialise system trusted keyrings
[    0.324437] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.333908] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
[    0.421548] NET: Registered PF_ALG protocol family
[    0.421584] Key type asymmetric registered
[    0.421605] Asymmetric key parser 'x509' registered
[    0.421839] bounce: pool size: 64 pages
[    0.421992] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.422397] io scheduler mq-deadline registered
[    0.422425] io scheduler kyber registered
[    0.422681] io scheduler bfq registered
[    0.424520] samsung-pinctrl 13400000.pinctrl: Failed to create device link (0x180) with soc
[    0.426837] samsung-usb2-phy 12130000.phy: supply vbus not found, using dummy regulator
[    0.427839] exynos5_usb3drd_phy 12100000.phy: supply vbus not found, using dummy regulator
[    0.428032] exynos5_usb3drd_phy 12100000.phy: supply vbus-boost not found, using dummy regulator
[    0.428460] exynos5_usb3drd_phy 12500000.phy: supply vbus not found, using dummy regulator
[    0.428634] exynos5_usb3drd_phy 12500000.phy: supply vbus-boost not found, using dummy regulator
[    0.436864] dma-pl330 3880000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.436898] dma-pl330 3880000.dma-controller:        DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6
[    0.439976] dma-pl330 121a0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.440008] dma-pl330 121a0000.dma-controller:       DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    0.443083] dma-pl330 121b0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.443116] dma-pl330 121b0000.dma-controller:       DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    0.444270] dma-pl330 10800000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.444300] dma-pl330 10800000.dma-controller:       DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
[    0.461998] dma-pl330 3880000.dma-controller: PM domain MAU will not be powered off
[    0.533568] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.536218] 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 124, base_baud = 0) is a S3C6400/10
[    0.536771] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 125, base_baud = 0) is a S3C6400/10
[    1.553526] printk: console [ttySAC2] enabled
[    1.560131] exynos-trng 10830600.rng: Exynos True Random Number Generator.
[    1.567245] exynos-mixer 14450000.mixer: Adding to iommu group 0
[    1.574772] exynos-drm-g2d 10850000.g2d: Adding to iommu group 1
[    1.581147] exynos-rotator 11c00000.rotator: Adding to iommu group 2
[    1.587248] exynos-scaler 12800000.scaler: Adding to iommu group 3
[    1.593888] exynos-scaler 12810000.scaler: Adding to iommu group 4
[    1.600295] exynos-scaler 12820000.scaler: Adding to iommu group 5
[    1.607009] exynos-drm-gsc 13e00000.video-scaler: Adding to iommu group 6
[    1.613211] exynos-drm-gsc 13e00000.video-scaler: drm gsc registered successfully.
[    1.620298] exynos-drm-gsc 13e10000.video-scaler: Adding to iommu group 7
[    1.627466] exynos-drm-gsc 13e10000.video-scaler: drm gsc registered successfully.
[    1.652020] brd: module loaded
[    1.654773] usbcore: registered new device driver r8152-cfgselector
[    1.659902] usbcore: registered new interface driver r8152
[    1.665405] usbcore: registered new interface driver cdc_ether
[    1.671186] usbcore: registered new interface driver cdc_subset
[    1.677065] usbcore: registered new interface driver r8153_ecm
[    1.685749] phy phy-12130000.phy.6: phy_power_on was called before phy_init
[    1.691276] exynos-ehci 12110000.usb: EHCI Host Controller
[    1.696714] exynos-ehci 12110000.usb: new USB bus registered, assigned bus number 1
[    1.704845] exynos-ehci 12110000.usb: irq 133, io mem 0x12110000
[    1.731064] exynos-ehci 12110000.usb: USB 2.0 started, EHCI 1.00
[    1.735818] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    1.743876] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.751068] usb usb1: Product: EHCI Host Controller
[    1.755880] usb usb1: Manufacturer: Linux 6.1.77+ ehci_hcd
[    1.761370] usb usb1: SerialNumber: 12110000.usb
[    1.766665] hub 1-0:1.0: USB hub found
[    1.769693] hub 1-0:1.0: 3 ports detected
[    1.774988] phy phy-12130000.phy.6: phy_power_on was called before phy_init
[    1.780583] exynos-ohci 12120000.usb: USB Host Controller
[    1.786000] exynos-ohci 12120000.usb: new USB bus registered, assigned bus number 2
[    1.793806] exynos-ohci 12120000.usb: irq 133, io mem 0x12120000
[    1.865293] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[    1.872132] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.879280] usb usb2: Product: USB Host Controller
[    1.884074] usb usb2: Manufacturer: Linux 6.1.77+ ohci_hcd
[    1.889502] usb usb2: SerialNumber: 12120000.usb
[    1.894774] hub 2-0:1.0: USB hub found
[    1.897855] hub 2-0:1.0: 3 ports detected
[    1.904077] UDC core: dbgp: couldn't find an available UDC
[    1.908531] mousedev: PS/2 mouse device common for all mice
[    1.915382] i2c_dev: i2c /dev entries driver
[    1.943247] vdd_ldo9: Bringing 3300000uV into 3000000-3000000uV
[    1.960292] vddq_mmc2: Bringing 3300000uV into 2800000-2800000uV
[    1.979785] vdd_sd: Bringing 3300000uV into 2800000-2800000uV
[    2.049199] s5m-rtc s2mps14-rtc: registered as rtc0
[    2.054487] s5m-rtc s2mps14-rtc: setting system clock to 2000-01-01T00:00:08 UTC (946684808)
[    2.061844] s2mps11-clk s2mps11-clk: DMA mask not set
[    2.076557] exynos-tmu 10060000.tmu: More trip points than supported by this TMU.
[    2.082622] exynos-tmu 10060000.tmu: 2 trip points should be configured in polling mode.
[    2.092426] exynos-tmu 10064000.tmu: More trip points than supported by this TMU.
[    2.098440] exynos-tmu 10064000.tmu: 2 trip points should be configured in polling mode.
[    2.108348] exynos-tmu 10068000.tmu: More trip points than supported by this TMU.
[    2.114407] exynos-tmu 10068000.tmu: 2 trip points should be configured in polling mode.
[    2.124320] exynos-tmu 1006c000.tmu: More trip points than supported by this TMU.
[    2.130338] exynos-tmu 1006c000.tmu: 2 trip points should be configured in polling mode.
[    2.140250] exynos-tmu 100a0000.tmu: More trip points than supported by this TMU.
[    2.146302] exynos-tmu 100a0000.tmu: 6 trip points should be configured in polling mode.
[    2.155544] s3c2410-wdt 101d0000.watchdog: watchdog inactive, reset disabled, irq disabled
[    2.163331] device-mapper: uevent: version 1.0.3
[    2.167537] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[    2.191451] sdhci: Secure Digital Host Controller Interface driver
[    2.196199] sdhci: Copyright(c) Pierre Ossman
[    2.201064] Synopsys Designware Multimedia Card Interface Driver
[    2.208067] dwmmc_exynos 12220000.mmc: IDMAC supports 32-bit address mode.
[    2.208115] dwmmc_exynos 12200000.mmc: IDMAC supports 32-bit address mode.
[    2.220477] dwmmc_exynos 12220000.mmc: Using internal DMA controller.
[    2.224492] s5p-secss 10830000.sss: s5p-sss driver registered
[    2.226796] dwmmc_exynos 12220000.mmc: Version ID is 250a
[    2.232750] dwmmc_exynos 12200000.mmc: Using internal DMA controller.
[    2.234102] hid: raw HID events driver (C) Jiri Kosina
[    2.238124] dwmmc_exynos 12220000.mmc: DW MMC controller at irq 144,64 bit host data width,64 deep fifo
[    2.244291] dwmmc_exynos 12200000.mmc: Version ID is 250a
[    2.264162] dwmmc_exynos 12200000.mmc: DW MMC controller at irq 145,64 bit host data width,64 deep fifo
[    2.268759] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    2.275936] dwmmc_exynos 12200000.mmc: allocated mmc-pwrseq
[    2.292675] exynos-nocp: new NoC Probe device registered: 10ca1000.nocp
[    2.297970] exynos-nocp: new NoC Probe device registered: 10ca1400.nocp
[    2.304571] exynos-nocp: new NoC Probe device registered: 10ca1800.nocp
[    2.305514] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    2.312086] exynos-nocp: new NoC Probe device registered: 10ca1c00.nocp
[    2.327451] exynos-ppmu: new PPMU device registered 10d00000.ppmu (ppmu-event3-dmc0-0)
[    2.335102] exynos-ppmu: new PPMU device registered 10d10000.ppmu (ppmu-event3-dmc0-1)
[    2.342974] exynos-ppmu: new PPMU device registered 10d60000.ppmu (ppmu-event3-dmc1-0)
[    2.350839] exynos-ppmu: new PPMU device registered 10d70000.ppmu (ppmu-event3-dmc1-1)
[    2.361081] exynos5-dmc 10c20000.memory-controller: error -ENXIO: IRQ drex_0 not found
[    2.367518] exynos5-dmc 10c20000.memory-controller: error -ENXIO: IRQ drex_1 not found
[    2.375591] exynos5-dmc 10c20000.memory-controller: DMC initialized, in irq mode: 0
[    2.384755] mmc_host mmc0: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0)
[    2.394797] samsung-i2s 3830000.i2s-sec: DMA channels sourced from device 3830000.i2s
[    2.397011] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[    2.407340] NET: Registered PF_PACKET protocol family
[    2.409624] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[    2.412797] NET: Registered PF_KEY protocol family
[    2.422627] Key type dns_resolver registered
[    2.426187]  mmcblk0: p1 p2
[    2.426754] Registering SWP/SWPB emulation handler
[    2.434051] registered taskstats version 1
[    2.437817] Loading compiled-in X.509 certificates
[    2.443116] Key type .fscrypt registered
[    2.446464] Key type fscrypt-provisioning registered
[    2.457336] Key type encrypted registered
[    2.588749] exynos-chipid 10000000.chipid: cpu0 opp0, freq: 1500 missing
[    2.594193] exynos-chipid 10000000.chipid: cpu4 opp0, freq: 2100 missing
[    2.600762] exynos-chipid 10000000.chipid: Exynos: CPU[EXYNOS5800] PRO_ID[0xe5422000] REV[0x1] Detected
[    2.617722] OF: graph: no port node found in /soc/hdmi@14530000
[    2.624147] [drm] Exynos DRM: using 14450000.mixer device for DMA mapping operations
[    2.630520] exynos-drm exynos-drm: bound 14450000.mixer (ops 0xc0e7bc8c)
[    2.637165] exynos-drm exynos-drm: bound 14530000.hdmi (ops 0xc0e7c26c)
[    2.643884] exynos-drm-g2d 10850000.g2d: The Exynos G2D (ver 4.1) successfully registered.
[    2.651958] exynos-drm exynos-drm: bound 10850000.g2d (ops 0xc0e7d27c)
[    2.658441] exynos-rotator 11c00000.rotator: The exynos rotator has been probed successfully
[    2.666855] exynos-drm exynos-drm: bound 11c00000.rotator (ops 0xc0e7db08)
[    2.673723] exynos-scaler 12800000.scaler: The exynos scaler has been probed successfully
[    2.681842] exynos-drm exynos-drm: bound 12800000.scaler (ops 0xc0e7e250)
[    2.688607] exynos-scaler 12810000.scaler: The exynos scaler has been probed successfully
[    2.696755] exynos-drm exynos-drm: bound 12810000.scaler (ops 0xc0e7e250)
[    2.703526] exynos-scaler 12820000.scaler: The exynos scaler has been probed successfully
[    2.711662] exynos-drm exynos-drm: bound 12820000.scaler (ops 0xc0e7e250)
[    2.718396] exynos-drm-gsc 13e00000.video-scaler: The exynos gscaler has been probed successfully
[    2.727314] exynos-drm exynos-drm: bound 13e00000.video-scaler (ops 0xc0e7eb24)
[    2.734594] exynos-drm-gsc 13e10000.video-scaler: The exynos gscaler has been probed successfully
[    2.743425] exynos-drm exynos-drm: bound 13e10000.video-scaler (ops 0xc0e7eb24)
[    2.791131] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[    2.838676] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[    2.878753] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
[    2.907827] Console: switching to colour frame buffer device 180x56
[    2.973325] exynos-drm exynos-drm: [drm] fb0: exynosdrmfb frame buffer device
[    2.984476] [drm] Initialized exynos 1.1.0 20180330 for exynos-drm on minor 0
[    3.004351] mali 11800000.gpu: GPU identified as 0x0620 r0p1 status 0
[    3.010719] mali 11800000.gpu: Protected mode not available
[    3.018316] mali 11800000.gpu: Probed as mali0
[    3.026735] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    3.030849] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
[    3.039677] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[    3.048138] xhci-hcd xhci-hcd.8.auto: irq 153, io mem 0x12000000
[    3.054235] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    3.059294] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
[    3.066981] xhci-hcd xhci-hcd.8.auto: Host supports USB 3.0 SuperSpeed
[    3.073679] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.081733] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.088855] usb usb3: Product: xHCI Host Controller
[    3.093692] usb usb3: Manufacturer: Linux 6.1.77+ xhci-hcd
[    3.099147] usb usb3: SerialNumber: xhci-hcd.8.auto
[    3.105733] hub 3-0:1.0: USB hub found
[    3.108240] hub 3-0:1.0: 1 port detected
[    3.113412] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.120627] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    3.128666] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.135843] usb usb4: Product: xHCI Host Controller
[    3.140461] usb usb4: Manufacturer: Linux 6.1.77+ xhci-hcd
[    3.148036] usb usb4: SerialNumber: xhci-hcd.8.auto
[    3.153685] hub 4-0:1.0: USB hub found
[    3.157741] hub 4-0:1.0: 1 port detected
[    3.169399] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    3.175224] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[    3.183781] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[    3.193572] xhci-hcd xhci-hcd.9.auto: irq 154, io mem 0x12400000
[    3.200100] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    3.205886] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[    3.213785] xhci-hcd xhci-hcd.9.auto: Host supports USB 3.0 SuperSpeed
[    3.220664] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.229213] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.236762] usb usb5: Product: xHCI Host Controller
[    3.241897] usb usb5: Manufacturer: Linux 6.1.77+ xhci-hcd
[    3.247575] usb usb5: SerialNumber: xhci-hcd.9.auto
[    3.253145] hub 5-0:1.0: USB hub found
[    3.257072] hub 5-0:1.0: 1 port detected
[    3.261543] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.269904] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    3.278421] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.285801] usb usb6: Product: xHCI Host Controller
[    3.290803] usb usb6: Manufacturer: Linux 6.1.77+ xhci-hcd
[    3.292505] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    3.294925] usb usb6: SerialNumber: xhci-hcd.9.auto
[    3.314476] hub 6-0:1.0: USB hub found
[    3.318373] hub 6-0:1.0: 1 port detected
[    3.324905] s3c-rtc 101e0000.rtc: rtc disabled, re-enabling
[    3.330709] s3c-rtc 101e0000.rtc: registered as rtc1
[    3.340796] exynos-bus: new bus device registered: soc:bus-wcore ( 88700 KHz ~ 532000 KHz)
[    3.345656] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[    3.348273] exynos-bus: new bus device registered: soc:bus-noc ( 66600 KHz ~ 111000 KHz)
[    3.370263] exynos-bus: new bus device registered: soc:bus-fsys-apb (111000 KHz ~ 222000 KHz)
[    3.379488] exynos-bus: new bus device registered: soc:bus-fsys2 ( 75000 KHz ~ 200000 KHz)
[    3.388608] exynos-bus: new bus device registered: soc:bus-mfc ( 83250 KHz ~ 333000 KHz)
[    3.397524] exynos-bus: new bus device registered: soc:bus-gen ( 88700 KHz ~ 266000 KHz)
[    3.406667] exynos-bus: new bus device registered: soc:bus-peri ( 66600 KHz ~  66600 KHz)
[    3.411109] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    3.419851] exynos-bus: new bus device registered: soc:bus-g2d ( 83250 KHz ~ 333000 KHz)
[    3.431814] exynos-bus: new bus device registered: soc:bus-g2d-acp ( 66500 KHz ~ 266000 KHz)
[    3.440249] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[    3.440969] exynos-bus: new bus device registered: soc:bus-jpeg ( 75000 KHz ~ 300000 KHz)
[    3.460397] exynos-bus: new bus device registered: soc:bus-jpeg-apb ( 83250 KHz ~ 166500 KHz)
[    3.469573] exynos-bus: new bus device registered: soc:bus-disp1-fimd (120000 KHz ~ 200000 KHz)
[    3.478997] exynos-bus: new bus device registered: soc:bus-disp1 (120000 KHz ~ 300000 KHz)
[    3.487932] exynos-bus: new bus device registered: soc:bus-gscl-scaler (150000 KHz ~ 300000 KHz)
[    3.497582] exynos-bus: new bus device registered: soc:bus-mscl ( 84000 KHz ~ 666000 KHz)
[    3.508589] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
[    3.535680] ALSA device list:
[    3.539420]   #0: ODROID-XU4
[    3.544075] Waiting for root device UUID=e139ce78-9841-40fe-8823-96a304a09859...
[    3.605856] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=22.23
[    3.615230] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.623491] usb 3-1: Product: USB2.0 Hub
[    3.628491] usb 3-1: Manufacturer: GenesysLogic
[    3.682358] hub 3-1:1.0: USB hub found
[    3.689564] hub 3-1:1.0: 2 ports detected
[    3.751499] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    3.794759] usb 4-1: New USB device found, idVendor=05e3, idProduct=0616, bcdDevice=22.23
[    3.805887] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.815965] usb 4-1: Product: USB3.0 Hub
[    3.822775] usb 4-1: Manufacturer: GenesysLogic
[    3.858309] hub 4-1:1.0: USB hub found
[    3.863915] hub 4-1:1.0: 2 ports detected
[    4.061238] usb 3-1.1: new low-speed USB device number 3 using xhci-hcd
[    4.206144] usb 3-1.1: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
[    4.221958] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.233307] usb 3-1.1: Product: USB Optical Mouse
[    4.238474] usb 3-1.1: Manufacturer: Logitech
[    4.371238] usb 6-1: new SuperSpeed USB device number 2 using xhci-hcd
[    4.391069] usb 3-1.2: new low-speed USB device number 4 using xhci-hcd
[    4.412822] usb 6-1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
[    4.422627] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    4.431336] usb 6-1: Product: USB 10/100/1000 LAN
[    4.437514] usb 6-1: Manufacturer: Realtek
[    4.443094] usb 6-1: SerialNumber: 000001000000
[    4.536824] usb 3-1.2: New USB device found, idVendor=1a2c, idProduct=2d23, bcdDevice= 1.10
[    4.549773] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.559722] usb 3-1.2: Product: USB Keyboard
[    4.564096] usb 3-1.2: Manufacturer: USB
[    4.677461] r8152-cfgselector 6-1: reset SuperSpeed USB device number 2 using xhci-hcd
[    4.733246] r8152 6-1:1.0: Direct firmware load for rtl_nic/rtl8153a-3.fw failed with error -2
[    4.742982] r8152 6-1:1.0: unable to load firmware patch rtl_nic/rtl8153a-3.fw (-2)
[    4.793138] r8152 6-1:1.0 eth0: v1.12.13
[    4.939315] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    5.000498] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[    5.060339] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[    5.119528] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
[    5.459354] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    5.522765] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[    5.578951] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[    5.635751] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
[    5.979379] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    6.042260] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[    6.098485] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[    6.157505] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
[    6.498761] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    6.556671] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[    6.612113] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[    6.668707] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
[    7.009370] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[    7.070667] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[    7.126100] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[    7.183829] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
Providing logs with
armbianmonitor -u
 helps with troubleshooting and significantly raises chances that issue gets addressed.
This doesn't look like an Armbian kernel.  What image are you using?
