mic_e Posted February 21, 2017 Posted February 21, 2017 I'm using an Olimex LIME2 board with an A20 processor (actually it's a Olimex A20-SOM, but that shouldn't matter) and trying to use PWM. I have an older image (jessie with Kernel 3.4) where the PWM hardware can be accessed through /sys/class/pwm-sunxi/pwm*/{duty, duty_percent, period, pin, polarity, pulse, run}. Now I'm building a newer image (xenial with Vanilla kernel). It has /sys/class/pwm, but the directory is empty. Any ideas? The fex file is the same for both boards; the relevant section is: [pwm0_para] pwm_used = 1 pwm_period = 10000 pwm_duty_percent = 50 [pwm1_para] pwm_used = 1 pwm_period = 10000 pwm_duty_percent = 50
hook Posted September 30, 2017 Posted September 30, 2017 Same situation here on a Lime2(eMMC) on latest stable using the 4.11.6-sunxi kernel. What I did was add the following the Armbian docs on Allwinner DT overlays to /boot/armbianEnv.txt: overlay_prefix=sun7i-a20 overlays=pwm and reboot. But that didn’t fix it either. So I then tried to load the module (unsure which one it would be): modprobe pwm-sun4i modprobe pwm-fan But that didn’t fix it either. If you have any suggestion, do let me know.
