Hi friends...
I understand that you have to be careful with the power supply and SD cards. For the above, I bought 2 power supplies (original) and several SD cards from different suppliers. After several attempts I can't get it to start from the sdcard (it only starts from the nvme).
I burned the images on Linux (wipefs + dd + gparted) and Windows (SD Memory Card Formatter + balenaEtcher). Also, I used RKDevTool to burn the images to the sd card and nothing (evidently I deleted the spi content).
--- begin part of the log ---
U-Boot SPL board init
U-Boot SPL 2017.09-gc060f28d70-220414 #zyf (Apr 18 2022 - 18:13:34)
Failed to set cpub01
Failed to set cpub23
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed witoot from MMC1
Card did not respond to voltage select!
mmc_init: -95, time 13
spl: mmc init failed with error: -95
Trying to boot from MTD2
GUID Partition Table Header signature is wrong: 0xX != 0xX
part_get_info_efi: *** ERROR: Invalid GPT ***
--- end part of the log ---
(I attach complete file)
If anyone can help me.
Thank you.-
Update:
Friends:    I contacted Sandisk (westerndigital) and they told me the cards were fake.  I just purchased 3 different cards directly from WesterDigital (I hope this resolves the issues I'm having with not being able to boot from an SD card. I bought the following cards : SanDisk Ultra, SanDisk Extreme, y SanDisk Extreme PRO (two of each, All A1))
concard.txt
Edited by JamesCL
update
