PcDuino3 Nano - on board ethernet fails to load, mainline 4.9.7
Go to solution Solved by palmatown,
I just updated my pcduino3 nano with armbian mainline 4.9.7 download on SD card and now the onboard ethernet port fials.
I am using a USB to ethernet for now with no problems.
Below are the messages I get during boot
Feb 22 14:35:23 localhost kernel: [ 2435.162554] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma
Feb 22 14:35:23 localhost kernel: [ 2435.168668] stmmac_hw_setup: DMA engine initialization failed
Feb 22 14:35:23 localhost kernel: [ 2435.174517] stmmac_open: Hw setup failed
I have tried several times to reset via cli and NetworkManager with the same results.
ip a & ip link show as down
seen in ifconfig but not able to change state
I am guessing the fix wil need to be during boot.
Anyone run into this?
Thanks for any help here!
Dave
SOLVED - I had downloaded the PcDuino3 instead of the PcDuino Nano image.  Ethernet interface came up fine!  Sorry for any confusion.
I had a similar issue with my 3B which is a 3 with GBe. That needed the nano image.
Did you try legacy on yours? I had issues with high cpu load which is why I switched to mainline.
