kasparsd Posted February 25, 2017 Share Posted February 25, 2017 It took me a while to get this ILI9340 based LCD monitor working with the Orange Pi Zero until I found a post on this forum that explains how the H2+ ports are mapped to the GPIO numbers in the Linux kernel. So I built an online tool that does the math for you: Here is a map of all the Orange Pi Zero GPIO pins: All the additional details are described in this blog post. 3 Link to comment Share on other sites More sharing options...
awef Posted February 25, 2017 Share Posted February 25, 2017 a little easier: https://jsfiddle.net/tuav7f6q/2/ 1 Link to comment Share on other sites More sharing options...
martinayotte Posted February 25, 2017 Share Posted February 25, 2017 Simple Python script : import sys import string def convert(value): value = value.upper() alp = value[1] idx = string.ascii_uppercase.index(alp) num = int(value[2:], 10) res = idx * 32 + num return res if __name__ == "__main__": args = sys.argv[1:] if not args: print("Usage: %s <pin>" % sys.argv[0]) sys.exit(1) print("%d" % convert(args[0])) Link to comment Share on other sites More sharing options...
