Hi all,
Only just found out about Armbian. Looks really useful. Want to use an Orange Pi Zero 3 for Pihole with Unbound and Pivpn.
However, i haven't found an answer for when you would use one distro over the other.
Also which is what in the download listings?
Thank you.
  • Solution
Bionic, Focal, jammy Noble are all Ubuntu.
Buster, Bullseye, bookworm, sid are all Debian versions.
You use what you prefer or what fits your tasks best.
I use Armbian Jammy on my Rock5B since I use it as main desktop and that's the image that works best for that.
On my travel NanoPi R6S I use Armbian Noble because it has a better KDEnlive version to edit and render video's on my cycling trips.
On my NAS ZimaBoard I use Noble because it fixes an issue with mounted drives, but could just as well use a debian version.
For your tasks I would probably use Armbian Bookworm and install the apps.
You probably could use CasaOS on Jammy for these tasks. It is a webinterface that allows you to install and setup docker apps.
To install casaOS on Jammy :
wget -qO- https://get.casaos.io | sudo bash
So both downloadable images are community releases and not official armbian supported images.
There is bookworm Debian 12 minimal which has only the essential things to boot a system and set it up.
The other is Jammy Ubuntu 22.04 with the Gnome desktop.
I would advice to build your own images with the distro version you want.
Hi NicoD,
Thanks for your insights.
I am fairly new in Linux as in using it, but have read a lot. So I did know the Ubuntu comes from Debian for instance. Although now administered separately.
Your note above does helps me, so many thanks. I believe a mention of just using what you want should be mentioned in the beginners guide. I didn't see anything like it. Also, which distribution name belongs to what vendor. But that's just my opinion.
CasaOS seems interesting but more than what I need at this stage.
Building my own is again more that what I am prepared to do stuff this stage, too daunting.
LurchNZ
Edited by LurchNZ
Thoughts and spelling
