fedes_gl Posted April 5, 2024 Posted April 5, 2024 (edited) So I bought this chinise Android TV Box and would love to install armbian on it. I am new on this and discovered armbian just after buying it. I didn't know there was no support and not official open source for the Rockchip RK3528, otherwise I would have chosen any other. The box works fine but it has that known malware that send packets to suspicious links (I scanned activity with pi-hole). Description says it has 2GB RAM and 16GB storage (Hynix H26M51002KPR) WiFi chip is LGX8800D I attach images of the board and all of it's componentes, including IR sensor and display. It also has a red LED that turns on when in stand-by mode. I hope this help to develop or patch a working version of armbian for it. I have already read about some patches around that would probably work, but I' new to this and I'm not sure how to start. What I would like to do first is a completly ROM backup, and start doing test with a pendrive or SD card, not writting directly to the eMMC (if possible) until the important things get working. And any help would be appreciated. Edit: I will keep posting in this thread with my progress (or attemps!) Edited April 6, 2024 by fedes_gl 0 Quote
fedes_gl Posted April 6, 2024 Author Posted April 6, 2024 (edited) 12 hours ago, blust0ne said: try to this image, it may work for you. Thank you. Before doing so, I would like to backup the firmware, which I'm a little troubled. I'm trying with a tool called rkdumper from xda forum, but it seems to fail with the RK3528. Seems it is read protected. However, I suppose I can boot and use armbian from SD with touching the eMMC, right? Edited April 6, 2024 by fedes_gl 0 Quote
Hqnicolas Posted April 14, 2024 Posted April 14, 2024 I'm thinking about buyng an RK3528 Shit box, but X88 pro 13 just have 10/100M Ethernet RJ45 port 0 Quote
fedes_gl Posted April 19, 2024 Author Posted April 19, 2024 I tried to dump the full firmware to have a backup but I couldn't do this because its read protection. Apparently I could only extract uboot.img and many other files. There is a workoround by unpacking that file, editing 4 bytes with any HEX editor, repacking and flashing, that allows to fully dump the firmware after tweaking it. I'm not sure of any risk of bricking the device If anything goes wrong. By the momment I cannot unppack the uboot.img file to do the trick. Also I'm looking for some more information about how to use the UART interface with it. I have a UART USB dongle (CP2102 chip) that I believe I can use to connect it. Any information would be appreciated. 0 Quote
fedes_gl Posted April 19, 2024 Author Posted April 19, 2024 On 4/14/2024 at 11:28 AM, Hqnicolas said: I'm thinking about buyng an RK3528 Shit box, but X88 pro 13 just have 10/100M Ethernet RJ45 port Yes, mine is 10/100M. I'm using it to watch content on a 1080p TV and works pretty fine. If useful to you, it has an USB 3.0 port, to use an external HDD or probabbly a gygabit LAN to USB dongle... 0 Quote
Hqnicolas Posted April 19, 2024 Posted April 19, 2024 9 hours ago, fedes_gl said: I'm using it to watch content on a 1080p TV and works pretty fine 1080p on linux? the gpu was working? 0 Quote
fedes_gl Posted April 19, 2024 Author Posted April 19, 2024 4 hours ago, Hqnicolas said: 1080p on linux? the gpu was working? Sorry for the confusion. For the moment I'm using it with original android firmware. I tried the build suggested by user blustOne (above in this thread), booting from SD card, GPU has signal output but seems not to have HW acceleration for playback (it loads the file, but stutter/choppy playback). Also no sound through HDMI port. I'm tring to first dump the entire firmware of the device. I don't want to get it bricked because of playing with it. Once I can dump it, I will try to play with the armbian variants, try to build my own, etc. I have never done this and I know I have a long way ahead reading and learning (and no much time), just I want to start with the backup. I will also try to debloat the android version. I'm using it connecting a flash drive with videos, I connect it to internet as little as possible, it has many bloatware that I'm not sure of what thing it can cause in my private network. Probbaly i'm worring too much about it? .. 0 Quote
fedes_gl Posted May 8, 2024 Author Posted May 8, 2024 (edited) So I managed to extract .dtb files from uboot.img using this extract-dtb tool. Later on, on a PC running Ubuntu 22.04 LTS I used "device tree compile" to decompile thos dtb files into dts files. I followed this article trying to use those DTS files to get the correct hardware informatin and/or drivers, but the /boot folder in the flashed SD card is empty. Probably, as the article says, dtb overlay is not activated in this image. Edited May 8, 2024 by fedes_gl 0 Quote
Dudley1001 Posted October 23, 2024 Posted October 23, 2024 (edited) If you are still looking for an image for the X88pro 13 , I used the desktop image for the Mango pi M28k located here and it worked but I did not have ethernet or wifi. I just used usb wifi on it. I will see if I can get the on-board network/wifi working. I have not done a full test but it does boot up and seems to run fine. I am just using the sdcard for now and have not tried to flash the eMMC Edited October 23, 2024 by Dudley1001 addition 0 Quote
fedes_gl Posted November 4, 2024 Author Posted November 4, 2024 Thank you! Yes I'm still looking for an image. Tried that one but no luck, multiple error messages at boot 0 Quote
fedes_gl Posted July 29 Author Posted July 29 I saw the release of linux kernel 6.16 with initial support for Rockchip RK3528. I hope this update makes more viable to run and configura Armbian on this board 😀 1 Quote
John Taylor Posted September 10 Posted September 10 Guys, please do keep us all updated on the rk3528. I was just about to buy a job lot of boards for a grid computing project when I found it's not supported yet. I found that my old TV rk32xx box was well supported, so am prepared to wait. 0 Quote
Hqnicolas Posted Tuesday at 03:52 PM Posted Tuesday at 03:52 PM On 9/9/2025 at 10:13 PM, John Taylor said: Guys, please do keep us all updated on the rk3528 I know an expert in rk3528, his name is @fensoft we are depending on him finding a weekend to dedicate to the community https://github.com/ilyakurdyukov/rk3528-tvbox he will help us by taking this repository and including it in armbian with a wonderful pull request I would like to buy this board and join the fun that you have, but my country has literally started an embargo on all TV boxes 1 Quote
fedes_gl Posted 15 hours ago Author Posted 15 hours ago Thanks! we hope this guy could get the time to do it, I will be here for every testing need ! 😁 I already installed Armbien on an orange Pi zero 3, and I'm running pihole on it. Works fantastic! At least this allows me have some experiencie with Armbian 0 Quote
Hqnicolas Posted 2 hours ago Posted 2 hours ago for Pi-Hole i'm using: "cbcrowe/pihole-unbound" https://hub.docker.com/r/cbcrowe/pihole-unbound For docker Containers I'm on Casa-OS curl -fsSL https://get.casaos.io | sudo bash pihole-unbound.yaml 0 Quote
