Posted (edited)
So I bought this chinise Android TV Box and would love to install armbian on it. I am new on this and discovered armbian just after buying it. I didn't know there was no support and not official open source for the Rockchip RK3528, otherwise I would have chosen any other. The box works fine but it has that known malware that send packets to suspicious links (I scanned activity with pi-hole).
Description says it has 2GB RAM and 16GB storage (Hynix H26M51002KPR)
WiFi chip is LGX8800D
I attach images of the board and all of it's componentes, including IR sensor and display. It also has a red LED that turns on when in stand-by mode.
I hope this help to develop or patch a working version of armbian for it. I have already read about some patches around that would probably work, but I' new to this and I'm not sure how to start.
What I would like to do first is a completly ROM backup, and start doing test with a pendrive or SD card, not writting directly to the eMMC (if possible) until the important things get working. And any help would be appreciated.
Edit: I will keep posting in this thread with my progress (or attemps!)
Edited by fedes_gl
Posted (edited)
12 hours ago, blust0ne said:
try to this image,  it may work for you.
Thank you. Before doing so, I would like to backup the firmware, which I'm a little troubled. I'm trying with a tool called rkdumper from xda forum, but it seems to fail with the RK3528. Seems it is read protected.
However, I suppose I can boot and use armbian from SD with touching the eMMC, right?
Edited by fedes_gl
I tried to dump the full firmware to have a backup but I couldn't do this because its read protection. Apparently I could only extract uboot.img and many other files. There is  a workoround by unpacking that file, editing 4 bytes with any HEX editor, repacking and flashing, that allows to fully dump the firmware after tweaking it.
I'm not sure of any risk of bricking the device If anything goes wrong.
By the momment I cannot unppack the uboot.img file to do the trick.
Also I'm looking for some more information about how to use the UART interface with it. I have a UART USB dongle (CP2102 chip) that I believe I can use to connect it. Any information would be appreciated.
On 4/14/2024 at 11:28 AM, Hqnicolas said:
I'm thinking about buyng an RK3528 Shit box,
but X88 pro 13 just have 10/100M Ethernet RJ45 port
Yes, mine is 10/100M. I'm using it to watch content on a 1080p TV and works pretty fine. If useful to you, it has an USB 3.0 port, to use an external HDD or probabbly a gygabit LAN to USB dongle...
4 hours ago, Hqnicolas said:
1080p on linux?
the gpu was working?
Sorry for the confusion. For the moment I'm using it with original android firmware.
I tried the build suggested by user blustOne (above in this thread), booting from SD card, GPU has signal output but seems not to have HW acceleration for playback (it loads the file, but stutter/choppy playback). Also no sound through HDMI port.
I'm tring to first dump the entire firmware of the device. I don't want to get it bricked because of playing with it. Once I can dump it, I will try to play with the armbian variants, try to build my own, etc. I have never done this and I know I have a long way ahead reading and learning (and no much time), just I want to start with the backup. I will also try to debloat the android version.
I'm using it connecting a flash drive with videos, I connect it to internet as little as possible, it has many bloatware that I'm not sure of what thing it can cause in my private network. Probbaly i'm worring too much about it? ..
Posted (edited)
So I managed to extract .dtb files from uboot.img using  this extract-dtb tool.
Later on, on a  PC running Ubuntu 22.04 LTS I used "device tree compile" to decompile thos dtb files into dts files.
I followed this article trying to use those DTS files to get the correct hardware informatin and/or drivers, but the /boot folder in the flashed SD card is empty. Probably, as the article says, dtb overlay is not activated in this image.
Edited by fedes_gl
Posted (edited)
If you are still looking for an image for the X88pro 13 , I used the desktop image for the Mango pi M28k located here and it worked but I did not have ethernet or wifi. I just used usb wifi on it. I will see if I can get the on-board network/wifi working. I have not done a full test but it does boot up and seems to run fine. I am just using the sdcard for now and have not tried to flash the eMMC
Edited by Dudley1001
addition
I saw the release of linux kernel 6.16 with initial support for Rockchip RK3528. I hope this update makes more viable to run and configura Armbian on this board 😀
Guys, please do keep us all updated on the rk3528. I was just about to buy a job lot of boards for a grid computing project when I found it's not supported yet. I found that my old TV rk32xx box was well supported, so am prepared to wait.
I know an expert in rk3528, his name is @fensoft
we are depending on him finding a weekend to dedicate to the community
https://github.com/ilyakurdyukov/rk3528-tvbox
he will help us by taking this repository and including it in armbian with a wonderful pull request
I would like to buy this board and join the fun that you have,
but my country has literally started an embargo on all TV boxes
Thanks! we hope this guy could get the time to do it, I will be here for every testing need ! 😁
I already installed Armbien on an orange Pi zero 3, and I'm running pihole on it. Works fantastic! At least this allows me have some experiencie with Armbian :)
I also happened to get an X88pro13 TV box on my desk. Since it promises good performance,  I've been experimenting with getting Armbian running..
My first attempts look promising.
Armbian-update and armbian-config are working. It could be a good platform for Smart-Home,
Console and desktop Armbian is running well.
    _             _    _                             __  __ _    _      _
   /_\  _ _ _ __ | |__(_)__ _ _ _ ___ _  _ _ _  ___ / _|/ _(_)__(_)__ _| |
  / _ \| '_| '  \| '_ \ / _` | ' \___| || | ' \/ _ \  _|  _| / _| / _` | |
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|   \_,_|_||_\___/_| |_| |_\__|_\__,_|_|
 v25.11 rolling for Hugsun X88pro running Armbian Linux 6.1.115-vendor-rk35xx
 Packages:     Ubuntu stable (noble)
 Support:      DIY (custom image)
 IPv4:         (LAN) 192.168.178.71 (WAN) 130.185.10.185
 Performance:
 Load:         82%               Uptime:       0 min     Local users:  3
 Memory usage: 7% of 3.82G
 CPU temp:     41°C              Usage of /:   10% of 58G
 RX today:     262 KiB
 Commands:
 Configuration : armbian-config
 Monitoring    : htop
HDMI output, LAN, Wi-Fi, and USB 2.0 are supported.
Audio not tested yet.
Bluetooth and USB 3.0 aren't working yet and require further investigation.
IR remote control is also not working.
I've shared my results and instructions for creating the image at: https://github.com/joilg/x88pro
A ready-made image for an Armbian server with a console interface is available at: https://github.com/joilg/x88pro/tags
A desktop version can also be easily created.
Please try  this version and let me know if you encounter any problems.
johlnx
@johlnx I have tried your recently built image from here Github Page and it booted fine. Boots fine.
Wifi and Ethernet works. USB port only one is working. The blue one and I assume that that is wired for USB3. So I find this strange.
I have still not touched the original eMMC. Here is the output from blkid. Note I am using a 16GB micro SD to boot and that is at /dev/mmcblk0
cyberhazard@x88pro:~$ blkid
/dev/mmcblk0p1: LABEL="armbi_boot" UUID="d312472c-e5d3-4ef4-9a72-4d38e367fa7c" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="bootfs" PARTUUID="c7a9a714-e024-406b-a111-dbf5782bfd06"
/dev/mmcblk0p2: LABEL="armbi_root" UUID="ead9d55f-9f5d-4db3-84af-1b4c0807169c" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="6acc9d55-8827-45f0-bb5f-3b864952abfa"
/dev/mmcblk1p11: UUID="da8b6f4f-89cc-4ed5-8bd6-aa0ef3b881e8" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="metadata" PARTUUID="b85e0000-0000-4752-8000-0c2400004469"
/dev/mmcblk1p10: UUID="790cebf2-3e31-464d-bf22-00bea1cb7eb6" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="cache" PARTUUID="cb490000-0000-4c68-8000-157e000041fe"
/dev/zram1: LABEL="log2ram" UUID="d0a97d5c-6f8c-41e3-863b-f7fdf23d9288" BLOCK_SIZE="4096" TYPE="ext4"
/dev/zram0: UUID="334781b1-ee36-425e-819a-6796d4f4f36a" TYPE="swap"
/dev/mmcblk1p3: PARTLABEL="trust" PARTUUID="71760000-0000-4537-8000-2f8f00000c08"
/dev/mmcblk1p13: PARTLABEL="super" PARTUUID="94030000-0000-4f58-8000-234700004169"
/dev/mmcblk1p1: PARTLABEL="security" PARTUUID="e9430000-0000-4579-8000-4da800000c18"
/dev/mmcblk1p8: PARTLABEL="recovery" PARTUUID="8a190000-0000-457d-8000-74a10000796b"
/dev/mmcblk1p6: PARTLABEL="vbmeta" PARTUUID="e02c0000-0000-496d-8000-062400006ffa"
/dev/mmcblk1p4: PARTLABEL="misc" PARTUUID="8d390000-0000-472e-8000-3dc60000506d"
/dev/mmcblk1p14: PARTLABEL="userdata" PARTUUID="134d0000-0000-4d40-8000-71540000188f"
/dev/mmcblk1p2: PARTLABEL="uboot" PARTUUID="523b0000-0000-4275-8000-4a4700000883"
/dev/mmcblk1p12: PARTLABEL="baseparameter" PARTUUID="e3430000-0000-4f7b-8000-3af900005bf5"
/dev/mmcblk1p9: PARTLABEL="backup" PARTUUID="d31e0000-0000-4930-8000-76c000007aec"
/dev/mmcblk1p7: PARTLABEL="boot" PARTUUID="a61c0000-0000-4708-8000-75db00002fb2"
/dev/mmcblk1p5: PARTLABEL="dtbo" PARTUUID="f0710000-0000-412e-8000-58350000717b"
Can I help you with something? Do you require any files from the original emmc partitions? Maybe this would allow to use all the HW.
Also do you think the front LED segment display can be functional?
@CyberHaZard Thanks for the feedback.
Yes, the internal eMMC is untouched. You can mount these Android partitions in your file system if you want to access them.
Thank you for the offer. I already have access to the Android OS, but tests are apriciated
Usb3  is not fully implemented yet . It might just be a Linux configuration issue.
I still need to investigate. Maybe it's also acting as a device. there could be a switch via GPIO.
The front LED display uses the HT1628 chip. There's a driver available at https://github.com/venkatesh4009/TM1628_LED_Driver It's worth a try.
Thanks for the effort and sharing! I'll do the testing in my device when I can get some time :)
I'll probably need some help building or applying patches to the images.
Apparently, there are more versions of the box. One has two stars on the nameplate and "V 1.4" printed on the PCB.
Although WiFi works on version 1.2, if  does not work on this version
V1.4 has a different Wi-Fi chip: EA6521.
dmesg | grep 'SDIO'  gives:
 [    9.621165] mmc2: new ultra high speed SDR104 SDIO card at address 8800
So I made a second test with your image. I changed to a 32GB SD card because the other one's capacity was an old 4gb one and run out of space when installing some stuff.
I run your image as is in my device. I don't change the DTB to the extracted one from Android partition, because if I do so, I get black screen.
I managed to install kodi and xfce4 desktop (xinit and lightdm are required to make it work, as I understand)
sudo apt update && sudo apt upgrade
sudo apt install xfce4 xinit lightdm
I realized I could run Kodi without xfce desktop... just typiing "kodi" command.
Before doing so I plugged my pendrive in the USB3.0 port and checked it was mounted. I did some file exploration with ls commands, mount, lsblk etc... but at the end when opened Kodi it was detected as "New_volume" which is the drive's name.
For my surprise: When moving through Kodi's menu, the "tic" sound came out from my TV. So: HDMI sound was working :)
Added the movie's folder to the Kodi library and it searched all the stuff that Kodi does (movie posters, tittle, information, etc.)
Hit play on one of them and movie played fluid ! :D
movie spec: 1080p and H264 codec
I looked for another movie encoded with H265 (HEVC)  file... and it played but with some "stuttering". I don't know the cause, if USB is not working at 3.0 speed, or GPU is running slower than expected (or other reason) --> The same file in the same pendrive in the same port, when running the device's Android and Kodi, plays perfectly smooth.  Also: In ANdroid Kodi es v21 and the one in Armbian is v20.5 ; maybe some HW acceleration issue there?
In conclusion, at the moment, with the original @johlnx image (v0.3, the latest at the moment of testing), for this board (pics in first post of this thread) I have:
USB2.0 port: Working: used for wireless keyboard+mouse receiver
USB3.0 port: Working, used for a 64G Pendrive (I don't know if it was recognized as USB 3.0 or 2.0, I don't know hoy to check that, yet)
HDMI-Video: Working
HDMI-Audio: Working (played few movies with 2ch audio content)
HDMI-CEC: Not tested, don't know how to do it, yet.
SD card reader: Working, as device boots from SD card.
LAN: Working
WiFi: Not fully tested, (I could only "See" networks , but did'nt connect to them as I was using the device wired.) So it is supposed to be working. Will fully test it in another moment.
IR and LCD: Not tested, I don't know where to start with those (will appreciate some help)
Analog A/V output: Not tested yet.
I can do more tests if some of you consider it, just ask me.  The more specific information (and how-to's...) the better.
Thanks
@fedes_gl
To list USB speeds, do
Quote
lsusb -t -v
You will get an output like:
Quote
/:  Bus 001.Port 001: Dev 001, Class=root_hub, Driver=ehci-platform/1p, 480M
    ID 1d6b:0002 Linux Foundation 2.0 root hub
    |__ Port 001: Dev 029, If 0, Class=Hub, Driver=hub/4p, 480M
        ID 05e3:0610 Genesys Logic, Inc. Hub
        |__ Port 001: Dev 030, If 0, Class=Mass Storage, Driver=usb-storage, 480M
            ID 0bda:9210 Realtek Semiconductor Corp. RTL9210 M.2 NVME Adapter
480M is the important part, this is is usb2.0.
for USB3.0 you will see 5G or 10G for 3.1
Also check your ethernet port speed with:
Quote
ethtool end0 | grep Speed
(replace end0 with your ethernet device)
And if im not mistaken, those are my 2 issues with this image: only usb2.0 and network speed of 100mbps. Making it similar to a 5 years old device..
Let me know if you found the same speeds.
Posted (edited)
On 12/14/2025 at 8:07 PM, DaBo said:
the 8 pin holes close the lcd display
Mine does not have any pinholes near the lcd display.
Send a pic, or/and trace their paths into some chip and see what that chip does by its id
Edited by Joao Cordeiro
the pin holes are connected to the ht1628 Front Display driver.  You can connect here individual keys or a key matrix.However, the ht1628 driver for this has not yet been implemented in Armbian.
The holes are visible in the 4. Image of fedes_gl's first message. The holes are  right to the display. The pins are connected to the AIP1628. This images are from the first layout version. I now have a second Board with  V1.4 marked in the Layout. The holes are no longer present in this version. It has also has a different Wi-Fi chip, therefore Wi-Fi doesn't work in my current  Armbian release with this v 1.4. box.
