ulumid Posted April 6 Share Posted April 6 please, can everyone help me make dtb for h96 max 8k ultra hd rk3528 from my dump file ? source file of the second file boot.img in the firmware snippet of file contents Quote /dts-v1/; / { compatible = "rockchip,rk3528-evb2-ddr3-v10\0rockchip,rk3528"; interrupt-parent = <0x01>; #address-cells = <0x02>; #size-cells = <0x02>; model = "Rockchip RK3528 EVB2 DDR3 V10 Board"; aliases { ethernet0 = "/ethernet@ffbd0000"; ethernet1 = "/ethernet@ffbe0000"; gpio0 = "/pinctrl/gpio@ff610000"; gpio1 = "/pinctrl/gpio@ffaf0000"; gpio2 = "/pinctrl/gpio@ffb00000"; gpio3 = "/pinctrl/gpio@ffb10000"; gpio4 = "/pinctrl/gpio@ffb20000"; i2c0 = "/i2c@ffa50000"; i2c1 = "/i2c@ffa58000"; i2c2 = "/i2c@ffa60000"; i2c3 = "/i2c@ffa68000"; For full dump, please download the file below If anyone succeeds please tag me thanks dump_rk3528.dts warning process.txt 0 Quote Link to comment Share on other sites More sharing options...
fedes_gl Posted April 6 Share Posted April 6 I'm Also interested as I have the same chip on my tv box. Did you dump the Dts file with rkdumper ? Or how have you done it? 1 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted April 6 Share Posted April 6 (edited) @ulumid take some photos from the device board if this device have SDcard Reader you can try other devices ROM find a device that looks like your device "same SOC" rk3528 like this RUPA X88 Pro have the same ROM from HT2 burn the ROM to a SD card and run it. Edited April 6 by Hqnicolas 2 Quote Link to comment Share on other sites More sharing options...
ulumid Posted April 7 Author Share Posted April 7 (edited) @Hqnicolas case Quote board Quote so hard to upload board, always error I uploaded it elsewhere full board image up side >> https://mega.nz/file/G98k1BAT#QafubfxNI6_Wk9yg8_yvxELPMQb0C5b2uRo0RvAccpk back side >> https://mega.nz/file/XhFUUIyQ#KKrdvWjesq_cGGEVuAKWdSK71BAHWcZ8dN0BjIsT35A chipset inside firmware Quote firmware version >> https://mega.nz/file/D98ElZ5L#kG1mMbfe9C9xnp0IiBZVUiXYNO-6iq4llcCB-NfSR0M Edited April 7 by ulumid 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted April 7 Share Posted April 7 (edited) Did you try this images? https://github.com/armbian/community/releases/tag/24.5.0-trunk.367 ################################################# You can try flash this image with balena onto an SD card https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_legacy_5.10.160_minimal.img.xz https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop.img.xz ################################################# Using linux you also can drop the DTB file inside /boot/dtb/rockchip and do $ nano armbianEnv.txt edit the file to reconize dtfile=rockchip/dump_rk3528.dtb https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_legacy_5.10.160_minimal.img.xz https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop.img.xz ################################################# the following kernel 6 images wont work with android DTB but maybe can work withou editing https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_vendor_6.1.43_minimal.img.xz https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_vendor_6.1.43_gnome_desktop.img.xz ################################################# Edited April 7 by Hqnicolas 2 Quote Link to comment Share on other sites More sharing options...
jock Posted April 7 Share Posted April 7 i have one of those boards, the silkprint on the PCB says RK3528_DDR3, that's the one I used to bring up the mutltool for rk3528. A major "problem" I have it is that the board does not boot from sdcard when the eMMC is blanked. I had no time to understand what is the reason behind. Though it should boot when a bootloader is available in eMMC. 1 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted April 7 Share Posted April 7 7 hours ago, jock said: Though it should boot when a bootloader is available in eMMC you need to find a Original ROM from your 8gb device "ROM.img" extract the image using this "windows" application " imgRePackerRK @ulumid Please make a backup from you bootloader! https://drive.google.com/file/d/1mtENAzLQ9J0eszeKG21NWIeqZCBcORQW/view?usp=sharing https://drive.google.com/file/d/1GKwjPepDoBIQHTafcOVEthfmkxy8EC6O/view?usp=sharing https://drive.google.com/file/d/1tIaW30UiAER1wGF0r3q2ldVvL55Gv-t3/view?usp=sharing Use one of these to backup your bootloader from your image to repair this loader you can follow this steps: Linux desktop $ sudo -i $ apt update $ apt-get rkdeveloptool connect the device "Press bootloader button" $ rkdeveloptool -h $ rkdeveloptool db MiniLoaderAll.bin Windows Desktop Rockchip_DriverAssitant_v5.1.1 RKDevTool_Release_v2.86 click "Download" "Dev Partition" Check the "write by address" checkbox Check the "Loader" checkbox "run" 0 Quote Link to comment Share on other sites More sharing options...
fedes_gl Posted April 8 Share Posted April 8 On 4/6/2024 at 1:11 PM, ulumid said: please, can everyone help me make dtb for h96 max 8k ultra hd rk3528 from my dump file ? Would you please explain me how did you make the dump file? I tried to dump the entire firmware of my device (I'm the owner of the Rupa that Hqnicolas mentioned) using "rkdumper" but it seems that device is read-protected. Anyway, I THINK that the dtb was dumped ok. I attach screenshot of the results from rkdumper. As I udnerstand, all those partition with "unknown" format, were not correctly dumped because of read-protection 0 Quote Link to comment Share on other sites More sharing options...
fedes_gl Posted April 8 Share Posted April 8 23 hours ago, ulumid said: so hard to upload board, always error I don't want to be off-topic with this but I recommend to resize and recompress your images with some imaging tool like Irfanview. I did that to upload my Rupa images and had no problems. Each image recompressd had a file size of around 200kb, yours are 1.5Mb or bigger, that's probably overloading the server. 0 Quote Link to comment Share on other sites More sharing options...
ulumid Posted April 8 Author Share Posted April 8 (edited) @fedes_gl my dump file is dtb android, get second file in boot.img from firmware and convert to dts or dtd Edited April 8 by ulumid 0 Quote Link to comment Share on other sites More sharing options...
jock Posted April 8 Share Posted April 8 @Hqnicolas thanks for the instructions, but I already have a backup of my box I had taken with multitool. The problem that is puzzling me is why the box does not boot from sdcard when the emmc is empty, something which is absolutely normal for other rockchip devices. 1 Quote Link to comment Share on other sites More sharing options...
fedes_gl Posted April 8 Share Posted April 8 (edited) On 4/7/2024 at 9:21 AM, Hqnicolas said: Did you try this images? I could manage to flash the SD card and boot Armbian in my device. I'm happy with that first step I used: Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop.img.xz However, I noticed (and was expected) many things not working: HDMI output is ok, for 1080p (that's the max my TV supports) The HDMI output has no audio. In settings, audio device is "Dummy"... WiFi is not detected. I couldn't test LAN yet, but I can give it a try later. However Bluetooth at least appeared (I understand is the same hardware for BT and Wifi, isn't it?), but I didn't connect anything USB port 2.0 worked OK: the receiver of keyboard and mouse was connected there, working USB port 3.0 worked: i connected a flash drive with some video files The video file played with lot of stuttering, nothing smooth, using the "Celluloid" player. Probabbly not HW accelerated by the mali GPU? The remote control did nothing, no response. I guess it my requiere some setting up, map buttons or sth like that. And when I turned it off, actually it rebooted. What can I do now for trying, testing, or modify things to try yo make this work? I would like to start with audio output, video playback and wifi Edit: If any documentation I can read I would be pleased. Edited April 8 by fedes_gl added in Edit line (last one) 0 Quote Link to comment Share on other sites More sharing options...
ulumid Posted April 9 Author Share Posted April 9 (edited) @Hqnicolas Quote Posted Sunday at 08:21 PM (edited) Did you try this images? https://github.com/armbian/community/releases/tag/24.5.0-trunk.367 ################################################# You can try flash this image with balena onto an SD card https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_legacy_5.10.160_minimal.img.xz https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop.img.xz ################################################# Using linux you also can drop the DTB file inside /boot/dtb/rockchip and do $ nano armbianEnv.txt edit the file to reconize dtfile=rockchip/dump_rk3528.dtb https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_legacy_5.10.160_minimal.img.xz https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop.img.xz ################################################# the following kernel 6 images wont work with android DTB but maybe can work withou editing https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_vendor_6.1.43_minimal.img.xz https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_vendor_6.1.43_gnome_desktop.img.xz ################################################# in my case dtb was on > usr/lib/linux-image5.10.160legacy-rk35xx/rockchip and armbianEnv.txt on > usr/share/armbian inside armbianEnv.txt verbosity=1 bootlogo=false to direct new dtb just add "dtfile=rockchip/dump_rk3528.dtb" or add code to other file ??? Edited April 9 by ulumid 0 Quote Link to comment Share on other sites More sharing options...
giga Posted April 27 Share Posted April 27 (edited) Hello I have got the LEMFO RBOX HK1RBOX with rk3528 (https://de.aliexpress.com/item/1005006654505780.html?spm=a2g0o.order_list.order_list_main.32.7cbf5c5fIj4Quv&gatewayAdapt=glo2deu) Is there any img and dtb, that works with this TV-Box. I tried Armbian_24.5.0_rockchip_h28k_jammy_5.10.160_server_2024.04.25.img.gz from ophub with rk3528-hlink-ht2.dtb, unfortunately the LAN did not work, even with all rk3528 dtb's I have tried the image recommended above https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_legacy_5.10.160_minimal.img.xz but I was lost, since the folder structure is different from the ones I am familiar with. I copied the rockchip folder to the boot folder and as well the a armbianEnv.txt adding dtfile=rockchip/rk3528-hlink-ht2.dtb. The original armbianEnv.txt was modified the same way. that did not work. Did you miss any other steps? I would appreciate any hint? Edited April 27 by giga 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted April 27 Share Posted April 27 On 4/9/2024 at 2:46 PM, ulumid said: 5.10.160legacy in this case, i think rk3528.dtb was on boot partition. Can you share the: $ lsblk $ df -h $ blkid 0 Quote Link to comment Share on other sites More sharing options...
fedes_gl Posted May 8 Share Posted May 8 On 4/7/2024 at 9:21 AM, Hqnicolas said: Using linux you also can drop the DTB file inside /boot/dtb/rockchip I'm trying to do this but my /boot folder is empty. I used the exact same version you mentioned: Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop Was it moved to another folder? 0 Quote Link to comment Share on other sites More sharing options...
fedes_gl Posted May 8 Share Posted May 8 (edited) On 4/27/2024 at 11:35 AM, Hqnicolas said: Can you share the: $ lsblk $ df -h $ blkid May this tell you something? Edit: In my case, on the SD card the /boot folder is empty. So I don't know how to use DTS files. Also, a flash drive was plugged: sda1 device. I can see Armbian sees the internal memory of my device (mmcblk1p1...p2...) lsblk: NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 1 57,7G 0 disk └─sda1 8:1 1 57,7G 0 part /media/chad/New Volume mmcblk1 179:0 0 14,7G 0 disk ├─mmcblk1p1 179:1 0 4M 0 part ├─mmcblk1p2 179:2 0 4M 0 part ├─mmcblk1p3 179:3 0 4M 0 part ├─mmcblk1p4 179:4 0 4M 0 part ├─mmcblk1p5 179:5 0 4M 0 part ├─mmcblk1p6 179:6 0 1M 0 part ├─mmcblk1p7 179:7 0 64M 0 part ├─mmcblk1p8 179:8 0 96M 0 part ├─mmcblk1p9 179:9 0 384M 0 part ├─mmcblk1p10 179:10 0 384M 0 part ├─mmcblk1p11 179:11 0 16M 0 part ├─mmcblk1p12 179:12 0 1M 0 part ├─mmcblk1p13 179:13 0 4G 0 part └─mmcblk1p14 179:14 0 9,7G 0 part mmcblk1boot0 179:32 0 4M 1 disk mmcblk1boot1 179:64 0 4M 1 disk mmcblk0 179:96 0 29G 0 disk ├─mmcblk0p1 179:97 0 256M 0 part /boot └─mmcblk0p2 179:98 0 28,4G 0 part /var/log.hdd / zram0 254:0 0 989,3M 0 disk [SWAP] zram1 254:1 0 50M 0 disk /var/log df -h Filesystem Size Used Avail Use% Mounted on tmpfs 198M 6,3M 192M 4% /run /dev/mmcblk0p2 28G 4,7G 23G 17% / tmpfs 990M 0 990M 0% /dev/shm tmpfs 5,0M 0 5,0M 0% /run/lock tmpfs 990M 12K 990M 1% /tmp /dev/mmcblk0p1 224M 122M 92M 58% /boot /dev/zram1 47M 1,6M 42M 4% /var/log tmpfs 198M 104K 198M 1% /run/user/1000 /dev/sda1 58G 28G 31G 48% /media/chad/New Volume blkid /dev/mmcblk0p1: LABEL="armbi_boot" UUID="b7da92dc-e8d6-4f98-bc78-2c2d26cb0e58" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="bootfs" PARTUUID="5ebaa50c-e6a2-ef4b-bdc0-42959c284dac" /dev/mmcblk0p2: LABEL="armbi_root" UUID="15ad00eb-944a-4829-8ff0-a0d0b211226c" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="a6783103-918f-fc44-b9ba-b8c9fc8915e4" /dev/mmcblk1p11: UUID="c6ed55dd-55ba-4fb3-81ed-e341a836e379" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="metadata" PARTUUID="015f0000-0000-4131-8000-2af900001415" /dev/mmcblk1p14: UUID="4548798e-a22e-48de-8b75-9fcbd508481a" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="userdata" PARTUUID="216e0000-0000-471b-8000-1139000006f0" /dev/mmcblk1p10: UUID="d90fb683-12be-438a-a851-85bb4899d594" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="cache" PARTUUID="a1470000-0000-4b4a-8000-335e00002f47" /dev/zram0: UUID="f4ddf41e-a476-410c-927e-7d1ad4814472" TYPE="swap" /dev/zram1: LABEL="log2ram" UUID="e37fe586-baaf-498e-980e-cdd667b954c2" BLOCK_SIZE="4096" TYPE="ext4" /dev/mmcblk1p3: PARTLABEL="trust" PARTUUID="d1630000-0000-4261-8000-78e300006a8d" /dev/mmcblk1p13: PARTLABEL="super" PARTUUID="78170000-0000-462e-8000-351f00003b21" /dev/mmcblk1p1: PARTLABEL="security" PARTUUID="72340000-0000-4939-8000-1a3d00005715" /dev/mmcblk1p8: PARTLABEL="recovery" PARTUUID="b2460000-0000-455b-8000-592d000036b6" /dev/mmcblk1p6: PARTLABEL="vbmeta" PARTUUID="4e6c0000-0000-4d7e-8000-1fcf000040fc" /dev/mmcblk1p4: PARTLABEL="misc" PARTUUID="357e0000-0000-4575-8000-0005000045d9" /dev/mmcblk1p2: PARTLABEL="uboot" PARTUUID="28010000-0000-4b3f-8000-3b8d00007f0e" /dev/mmcblk1p12: PARTLABEL="baseparameter" PARTUUID="5b6c0000-0000-424a-8000-6fa2000072f0" /dev/mmcblk1p9: PARTLABEL="backup" PARTUUID="74600000-0000-4a1e-8000-3b0700007340" /dev/mmcblk1p7: PARTLABEL="boot" PARTUUID="927d0000-0000-4354-8000-060700007162" /dev/mmcblk1p5: PARTLABEL="dtbo" PARTUUID="1c5d0000-0000-4b75-8000-66bb0000653c" /dev/sda1: LABEL="New Volume" BLOCK_SIZE="512" UUID="2070DF2870DF0406" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="17cffda1-bd82-44b9-8fc4-6e7175882b3a" Edited May 8 by fedes_gl 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted May 8 Share Posted May 8 10 hours ago, fedes_gl said: SD card the /boot folder is empty You need to Mount the boot partition to edit it. ├─mmcblk0p1 179:97 0 256M 0 part /boot Put the SD card on a x86 linux and edit the DTB file 0 Quote Link to comment Share on other sites More sharing options...
fedes_gl Posted May 9 Share Posted May 9 On 5/8/2024 at 12:47 PM, Hqnicolas said: You need to Mount the boot partition to edit it. Thank youuu, this was helpful! However I still need some help (I'm beginner within linux) I mounted the boot partition but I have not permission to write on it. I booted Ubuntu 22.04 LTS on a x86 system (I permantly installed this version for Armbian compilnig ) Inserted SD card and opened up a Terminal and run the following: sudo mount -t auto -v /dev/sdd1 /mnt/Armbian_boot Where "/dev/sdd1" points to the SD card boot partition. (had to run lsblk with the inserted SD card to odentify it) Now I can open the mounted folder with "Files" app and navigate it. I can see the dtb/rockchip folder, and the ArmbianEnv.txt file. There is also a dtb-5.10.160-legacy-rk35xx/rockchip folder. When I try to put the 4 .dtb files I have into dtb folder (or 5.10.160-legacy-rk35xx folder), or inside Rockchip folder (in each case), I am not allowed. It says "Permissions do not allow pasting files in this directory" I can't either edit and save ArmbianEnv.txt file! I did some internet search and tried with this command: (chad is my user and Armbian_boot the mouted folder) chown -R chad /mnt/Armbian_boot or chown -R 775 /mnt/Armbian_boot And it says "Operation not permited" I checked the SD card is not physically write-protected (I'm using MicroSD to SD adaptor). What I'm missing? 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted May 10 Share Posted May 10 18 hours ago, fedes_gl said: I mounted the boot partition but I have not permission to write on it. on debian distro : sudo nautilus 18 hours ago, fedes_gl said: There is also a dtb-5.10.160-legacy-rk35xx/rockchip folder. This folder and dtb folder is the same folder it's just an short link 1 Quote Link to comment Share on other sites More sharing options...
