h96 max 8k ultra hd rk3528 dtb dump
please, can everyone help me make dtb for h96 max 8k ultra hd rk3528 from my dump file ?
source file of the second file boot.img in the firmware
snippet of file contents
Quote
/dts-v1/;
    compatible = "rockchip,rk3528-evb2-ddr3-v10\0rockchip,rk3528";
    interrupt-parent = <0x01>;
    #address-cells = <0x02>;
    #size-cells = <0x02>;
    model = "Rockchip RK3528 EVB2 DDR3 V10 Board";
    aliases {
        ethernet0 = "/ethernet@ffbd0000";
        ethernet1 = "/ethernet@ffbe0000";
        gpio0 = "/pinctrl/gpio@ff610000";
        gpio1 = "/pinctrl/gpio@ffaf0000";
        gpio2 = "/pinctrl/gpio@ffb00000";
        gpio3 = "/pinctrl/gpio@ffb10000";
        gpio4 = "/pinctrl/gpio@ffb20000";
        i2c0 = "/i2c@ffa50000";
        i2c1 = "/i2c@ffa58000";
        i2c2 = "/i2c@ffa60000";
        i2c3 = "/i2c@ffa68000";
For full dump, please download the file below
If anyone succeeds please tag me
thanks
dump_rk3528.dts warning process.txt
Posted (edited)
@Hqnicolas
case
Quote
board
Quote
so hard to upload board, always error
I uploaded it elsewhere
full board image
up side >> https://mega.nz/file/G98k1BAT#QafubfxNI6_Wk9yg8_yvxELPMQb0C5b2uRo0RvAccpk
back side >> https://mega.nz/file/XhFUUIyQ#KKrdvWjesq_cGGEVuAKWdSK71BAHWcZ8dN0BjIsT35A
chipset inside
firmware
Quote
Edited by ulumid
Did you try this images?
https://github.com/armbian/community/releases/tag/24.5.0-trunk.367
You can try flash this image with balena
onto an SD card
https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_legacy_5.10.160_minimal.img.xz
https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop.img.xz
Using linux you also can drop the DTB file inside /boot/dtb/rockchip
and do
$ nano armbianEnv.txt
edit the file to reconize dtfile=rockchip/dump_rk3528.dtb
the following kernel 6 images wont work with android DTB but maybe can work withou editing
https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_vendor_6.1.43_minimal.img.xz
https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_vendor_6.1.43_gnome_desktop.img.xz
Edited by Hqnicolas
i have one of those boards, the silkprint on the PCB says RK3528_DDR3, that's the one I used to bring up the mutltool for rk3528.
A major "problem" I have it is that the board does not boot from sdcard when the eMMC is blanked. I had no time to understand what is the reason behind. Though it should boot when a bootloader is available in eMMC.
you need to find a Original ROM from your 8gb device
"ROM.img"
extract the image using this "windows" application " imgRePackerRK
@ulumid Please make a backup from you bootloader!
https://drive.google.com/file/d/1mtENAzLQ9J0eszeKG21NWIeqZCBcORQW/view?usp=sharing
https://drive.google.com/file/d/1GKwjPepDoBIQHTafcOVEthfmkxy8EC6O/view?usp=sharing
https://drive.google.com/file/d/1tIaW30UiAER1wGF0r3q2ldVvL55Gv-t3/view?usp=sharing
Use one of these to backup your bootloader from your image
to repair this loader you can follow this steps:
Linux desktop
$ sudo -i
$ apt update
$ apt-get rkdeveloptool
connect the device "Press bootloader button"
$ rkdeveloptool -h
$ rkdeveloptool db MiniLoaderAll.bin
Windows Desktop
Rockchip_DriverAssitant_v5.1.1
RKDevTool_Release_v2.86
click "Download" "Dev Partition"
Check the "write by address" checkbox
Check the "Loader" checkbox
"run"
Would you please explain me how did you make the dump file? I tried to dump the entire firmware of my device (I'm the owner of the Rupa that Hqnicolas mentioned) using "rkdumper" but it seems that device is read-protected. Anyway, I THINK that the dtb was dumped ok.
I attach screenshot of the results from rkdumper. As I udnerstand, all those partition with  "unknown" format, were not correctly dumped because of read-protection
I don't want to be off-topic with this but I recommend to resize and recompress your images with some imaging tool like Irfanview. I did that to upload my Rupa images and had no problems. Each image recompressd had a file size of around 200kb, yours are 1.5Mb or bigger, that's probably overloading the server.
@Hqnicolas thanks for the instructions, but I already have a backup of my box I had taken with multitool.
The problem that is puzzling me is why the box does not boot from sdcard when the emmc is empty, something which is absolutely normal for other rockchip devices.
I could manage to flash the SD card and boot Armbian in my device. I'm happy with that first step :)
I used: Armbian_community_24.5.0-trunk.367_Hinlink-ht2_jammy_legacy_5.10.160_gnome_desktop.img.xz
However, I noticed (and was expected) many things not working:
HDMI output is ok, for 1080p (that's the max my TV supports)
The HDMI output has no audio. In settings, audio device is "Dummy"...
WiFi is not detected. I couldn't test LAN yet, but I can give it a try later. However Bluetooth at least appeared (I understand is the same hardware for BT and Wifi, isn't it?), but I didn't connect anything
USB port 2.0 worked OK: the receiver of keyboard and mouse was connected there, working
USB port 3.0 worked: i connected a flash drive with some video files
The video file played with lot of stuttering, nothing smooth, using the "Celluloid" player. Probabbly not HW accelerated by the mali GPU?
The remote control did nothing, no response. I guess it my requiere some setting up, map buttons or sth like that.
And when I turned it off, actually it rebooted.
What can I do now for trying, testing, or modify things to try yo make this work? I would like to start with audio output, video playback and wifi
Edit: If any documentation I can read I would be pleased.
Edited by fedes_gl
added in Edit line (last one)
Posted (edited)
@Hqnicolas
Quote
Posted Sunday at 08:21 PM (edited)
onto an SD card
and do
in my case dtb was on > usr/lib/linux-image5.10.160legacy-rk35xx/rockchip and armbianEnv.txt on > usr/share/armbian
inside armbianEnv.txt
verbosity=1
bootlogo=false
to direct new dtb just add "dtfile=rockchip/dump_rk3528.dtb" or add code to other file ???
Edited by ulumid
Hello
I have got the LEMFO RBOX HK1RBOX with rk3528 (https://de.aliexpress.com/item/1005006654505780.html?spm=a2g0o.order_list.order_list_main.32.7cbf5c5fIj4Quv&gatewayAdapt=glo2deu)
Is there any img and dtb, that works with this TV-Box. I tried  Armbian_24.5.0_rockchip_h28k_jammy_5.10.160_server_2024.04.25.img.gz from ophub with rk3528-hlink-ht2.dtb, unfortunately the LAN did not work, even with all rk3528 dtb's
I have tried the image recommended above
but I was lost, since the folder structure is different from the ones I am familiar with. I copied the rockchip folder to the boot folder and as well the a armbianEnv.txt adding dtfile=rockchip/rk3528-hlink-ht2.dtb. The original armbianEnv.txt was modified the same way.
that did not work. Did you miss any other steps?
I would appreciate any hint?
Edited by giga
Posted (edited)
On 4/27/2024 at 11:35 AM, Hqnicolas said:
Can you share the:
$ lsblk
$ df -h
$ blkid
May this tell you something?
Edit: In my case, on the SD card the /boot folder is empty. So I don't know how to use DTS files.
Also, a flash drive was plugged: sda1 device.
I can see Armbian sees the internal memory of my device (mmcblk1p1...p2...)
lsblk:
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda            8:0    1  57,7G  0 disk
└─sda1         8:1    1  57,7G  0 part /media/chad/New Volume
mmcblk1      179:0    0  14,7G  0 disk
├─mmcblk1p1  179:1    0     4M  0 part
├─mmcblk1p2  179:2    0     4M  0 part
├─mmcblk1p3  179:3    0     4M  0 part
├─mmcblk1p4  179:4    0     4M  0 part
├─mmcblk1p5  179:5    0     4M  0 part
├─mmcblk1p6  179:6    0     1M  0 part
├─mmcblk1p7  179:7    0    64M  0 part
├─mmcblk1p8  179:8    0    96M  0 part
├─mmcblk1p9  179:9    0   384M  0 part
├─mmcblk1p10 179:10   0   384M  0 part
├─mmcblk1p11 179:11   0    16M  0 part
├─mmcblk1p12 179:12   0     1M  0 part
├─mmcblk1p13 179:13   0     4G  0 part
└─mmcblk1p14 179:14   0   9,7G  0 part
mmcblk1boot0 179:32   0     4M  1 disk
mmcblk1boot1 179:64   0     4M  1 disk
mmcblk0      179:96   0    29G  0 disk
├─mmcblk0p1  179:97   0   256M  0 part /boot
└─mmcblk0p2  179:98   0  28,4G  0 part /var/log.hdd
zram0        254:0    0 989,3M  0 disk [SWAP]
zram1        254:1    0    50M  0 disk /var/log
df -h
Filesystem      Size  Used Avail Use% Mounted on
tmpfs           198M  6,3M  192M   4% /run
/dev/mmcblk0p2   28G  4,7G   23G  17% /
tmpfs           990M     0  990M   0% /dev/shm
tmpfs           5,0M     0  5,0M   0% /run/lock
tmpfs           990M   12K  990M   1% /tmp
/dev/mmcblk0p1  224M  122M   92M  58% /boot
/dev/zram1       47M  1,6M   42M   4% /var/log
tmpfs           198M  104K  198M   1% /run/user/1000
/dev/sda1        58G   28G   31G  48% /media/chad/New Volume
blkid
/dev/mmcblk0p1: LABEL="armbi_boot" UUID="b7da92dc-e8d6-4f98-bc78-2c2d26cb0e58" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="bootfs" PARTUUID="5ebaa50c-e6a2-ef4b-bdc0-42959c284dac"
/dev/mmcblk0p2: LABEL="armbi_root" UUID="15ad00eb-944a-4829-8ff0-a0d0b211226c" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="a6783103-918f-fc44-b9ba-b8c9fc8915e4"
/dev/mmcblk1p11: UUID="c6ed55dd-55ba-4fb3-81ed-e341a836e379" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="metadata" PARTUUID="015f0000-0000-4131-8000-2af900001415"
/dev/mmcblk1p14: UUID="4548798e-a22e-48de-8b75-9fcbd508481a" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="userdata" PARTUUID="216e0000-0000-471b-8000-1139000006f0"
/dev/mmcblk1p10: UUID="d90fb683-12be-438a-a851-85bb4899d594" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="cache" PARTUUID="a1470000-0000-4b4a-8000-335e00002f47"
/dev/zram0: UUID="f4ddf41e-a476-410c-927e-7d1ad4814472" TYPE="swap"
/dev/zram1: LABEL="log2ram" UUID="e37fe586-baaf-498e-980e-cdd667b954c2" BLOCK_SIZE="4096" TYPE="ext4"
/dev/mmcblk1p3: PARTLABEL="trust" PARTUUID="d1630000-0000-4261-8000-78e300006a8d"
/dev/mmcblk1p13: PARTLABEL="super" PARTUUID="78170000-0000-462e-8000-351f00003b21"
/dev/mmcblk1p1: PARTLABEL="security" PARTUUID="72340000-0000-4939-8000-1a3d00005715"
/dev/mmcblk1p8: PARTLABEL="recovery" PARTUUID="b2460000-0000-455b-8000-592d000036b6"
/dev/mmcblk1p6: PARTLABEL="vbmeta" PARTUUID="4e6c0000-0000-4d7e-8000-1fcf000040fc"
/dev/mmcblk1p4: PARTLABEL="misc" PARTUUID="357e0000-0000-4575-8000-0005000045d9"
/dev/mmcblk1p2: PARTLABEL="uboot" PARTUUID="28010000-0000-4b3f-8000-3b8d00007f0e"
/dev/mmcblk1p12: PARTLABEL="baseparameter" PARTUUID="5b6c0000-0000-424a-8000-6fa2000072f0"
/dev/mmcblk1p9: PARTLABEL="backup" PARTUUID="74600000-0000-4a1e-8000-3b0700007340"
/dev/mmcblk1p7: PARTLABEL="boot" PARTUUID="927d0000-0000-4354-8000-060700007162"
/dev/mmcblk1p5: PARTLABEL="dtbo" PARTUUID="1c5d0000-0000-4b75-8000-66bb0000653c"
/dev/sda1: LABEL="New Volume" BLOCK_SIZE="512" UUID="2070DF2870DF0406" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="17cffda1-bd82-44b9-8fc4-6e7175882b3a"
Edited by fedes_gl
You need to Mount the boot partition to edit it.
Put the SD card on a x86 linux and edit the DTB file
Thank youuu, this was helpful! However I still need some help (I'm beginner within linux)
I mounted the boot partition but I have not permission to write on it.
I booted Ubuntu 22.04 LTS on a x86 system (I permantly installed this version for Armbian compilnig :) )
Inserted SD card and opened up a Terminal and run the following:
sudo mount -t auto -v /dev/sdd1 /mnt/Armbian_boot
Where "/dev/sdd1" points to the SD card boot partition. (had to run lsblk with the inserted SD card to odentify it)
Now I can open the mounted folder with "Files" app and navigate it. I can see the dtb/rockchip folder, and the ArmbianEnv.txt file.
There is also a dtb-5.10.160-legacy-rk35xx/rockchip folder.
When I try to put the 4 .dtb files I have into dtb folder (or 5.10.160-legacy-rk35xx folder), or inside Rockchip folder (in each case), I am not allowed. It says "Permissions do not allow pasting files in this directory"
I can't either edit and save ArmbianEnv.txt file!
I did some internet search and tried with this command: (chad is my user and Armbian_boot the mouted folder)
chown -R chad /mnt/Armbian_boot
or
chown -R 775 /mnt/Armbian_boot
And it says "Operation not permited"
I checked the SD card is not physically write-protected (I'm using MicroSD to SD adaptor).
What I'm missing?
on debian distro :
sudo nautilus
This folder and dtb folder is the same folder
it's just an short link
