Why not to add lirc_gpio support to NanoPiNeo Air ?
Even if it is not planned, I try to use this patch :
https://github.com/igorpecovnik/lib/blob/master/patch/kernel/sun7i-default/0050-lircgpio_and_raw.patch
Kernel compilation is ok for me :
apt-get -y install git git clone
https://github.com/igorpecovnik/lib --depth 1
cp lib/compile.sh .
./compile.sh
I try to apply this patch now :
~/crosscompile/lib/patch/kernel/sun7i-default/0050-lircgpio_and_raw.patch
I expected to have a lircgpio.ko somewhere, but nothing.
Is there a procedure or a tutorial or some help to build a driver ?
You didn't compile the drivers, because you didn't enable them in kernel config file. You need this:
CONFIG_LIRC_GPIO=y
CONFIG_LIRC_SUNXI_RAW=y
It is written that I can't modify these kernel config files :
lib/config/kernel/linux-sun4i-default.config
lib/config/kernel/linux-sun7i-default.config
# Automatically generated file; DO NOT EDIT.
# Linux/arm 3.4.113 Kernel Configuration
I modified these files anyway but there is still no lirc_gpio.ko
When KERNEL_CONFIGURE="yes" I can set options :
Pressing <Y> includes, <N> excludes, <M> modularizes
Press <Esc><Esc> to exit, <?> for Help, </> for Search.  Legend: [*] built-in  [ ] excluded  <M> module  < > module capable
There is no lirc_gpio config near
<M> "SUNXI IR remote control"
What must be do ?
This line gives you dependencies, which must be also enabled in order to be able to compile that (assuming patch is compatible with kernel source).
Yes this patch is here :
How can can it be applied ?
In first post you said you applied the patch, e.g. copied it in right folder. What I linked is specific line in that patch (line 11, orange color if you use link above), which tells you what you have to enable before you can enable new functionality, e.g. on which kernel functionalities driver depends.
No, I said I try. I asked "Is there a procedure or a tutorial or some help to build a driver ?"
Now I see the patch is applied :
[ o.k. ] Looking for user patches in [ userpatches/kernel/sun8i-default ]
There is stil no *.ko What must be do ?
uh, sorry, for .ko you must set to "m", not "y". Former will produce module and the later it will embed driver into kernel.
Still no lirc_gpio.ko into the debs packages generated.
Maybe I forgot something
[ o.k. ] ... [c] 0050-lircgpio_and_raw.patch [ succeeded ]
@jernej I don't really underestand what you say...
What must be do ?
cp lib/compile.sh .
cp lib/patch/kernel/sun7i-default/0050-lircgpio_and_raw.patch userpatches/kernel/
Add
CONFIG_LIRC_GPIO=y CONFIG_LIRC_SUNXI_RAW=y
to
output/linux-sun8i-default.config
./compile.sh (without kernel configure in order to not delete config file)
What else
Please excuse my rant:
Most of the time, when I don't give the direct answer on this forum (and elsewhere), it is done in a good faith that my answer will serve as a pointer where the answer could be found and that the person will learn in the process something about that particular topic. This is also the reason why I usually don't provide the binaries or at least not very often. It seems that this often backfire and I'm accussed that I'm not being clear enough or even that I ask too much question (?!, once). Maybe I'm just too optimistic and my image is distorted after having reverse engineering as a hobby for more than 10 years, where every clue is golden.
Now I will deviate from my standard behaviour and I will provide step by step overview:
1. Figure out which symbols needs to be enabled:
line 35 and 36 tells you that you have to add this to the config file:
CONFIG_LIRC_GPIO=m
CONFIG_LIRC_SUNXI_RAW=m
Note that "m" means as a module, which will produce two .ko files.
2. Figure out if dependencies are satisfied:
line 11 and line 19 gives you following dependencies:
  • LIRC
  • GPIOLIB
Quick search trought sun8i kernel config file suggest that those options are already enabled here and here.
3. Start compiling and hope for the best.
4. When finished, search for lirc_gpio.ko and sunxi-lirc.ko.
Note 1: You must set "m" or else driver will be embedded in kernel binary and there will not be separate .ko files.
Note 2: I'm not completely sure how armbian build system handles the files. It is much better to use configuration through user interface as you already tried. Those options should be under "drivers/staging/media" menu.
Every link is a pointer where I found the information and I didn't include exhaustive explanation of my last suggestion, because it is just check if everything went as planned.
11 hours ago, sirob said:
Add
to
And please check the build script documentation again about preferred method of changing the kernel config and proper file path for the customized user provided config.
I didn't saw building submenu in https://docs.armbian.com/
I clicked "Building Armbian" and I thought it was ended, the submenu is hidden after click ...... FFF
Thank you Zador, haha :D
@Jernej I don't think people wants to reverse your engineering as a hobby a mind far away from open source that we all use, do not waste your time to lose to others
No because, I have some problems compiling kernel :
[ o.k. ] This script will try to update
Already up-to-date.
Already on 'master'
Your branch is up-to-date with 'origin/master'.
/root/crosscompile/lib/general.sh: line 499: syntax error near unexpected token `('
/root/crosscompile/lib/general.sh: line 499: `        grep -q i386 <(dpkg --print-foreign-architectures) || dpkg --add-architecture i386'
Yesterday it was compiling well.....
I opened an issue, I hope I did a right thing :
https://github.com/igorpecovnik/lib/issues
It's ok now for me I don't know why, without update
Maybe a github problem, I don't know.
