alex001gg1 Posted November 25, 2025 Posted November 25, 2025 Will it work on the H96 max RK3528 4gb ram 64gb rom? 0 Quote
Hqnicolas Posted December 1, 2025 Posted December 1, 2025 On 11/24/2025 at 2:21 PM, alex001gg1 said: Will i have malware if i installed it on my tv box H96 max On 11/24/2025 at 9:07 PM, fensoft said: moreover, you probably already have on your stock firmware, like a lot of chinese android tvbox Please STOP installing android Stock ROM's in this devices It's full of malware https://www.youtube.com/watch?v=1vpepaQ-VQQ On 11/24/2025 at 9:07 PM, fensoft said: "no". but don't trust anybody, that was the point. you don't know me. There's no malware, but you need to review all the code before using it. We're talking about Linux, the code is there, review it, don't trust it. 0 Quote
zm112008 Posted March 10 Posted March 10 Good afternoon, I can't compile the cores for this TV box. https://paste.armbian.com/ziyasupeka 0 Quote
zm112008 Posted March 10 Posted March 10 when using your fork, it worked https://github.com/fensoft/rk3528-tvbox 1 Quote
sr4armbian Posted April 24 Posted April 24 @fensoft I am using your current image 3.0.0_r2 in H96 Max M1 with USB Hub + USB to Ethernet adapter successfully. Its really energy efficient solution which can run 24 x 7 without costing much. However I am trying to set this up on a dq08 box with 4 GB/64 GB Model. I am able to install dq08_ha_supervised_3.0.0_r2.zip without any issue. However due to recent support changes from the application, I am unable to continue further with the setup. I tried to install docker version to set this up but getting error "invalid argument: in-kernel BTF is malformed (1 line(s) omitted)". Not seeing much on this error in the interwebs but there are suggestions that this could be due to old kernels/. Is there a way we can update this kernel and OS to Armbian Trixie or will it brick the dq08? Have you got a chance to look at the updated installer image? 0 Quote
