Gullik Posted July 30, 2019 Posted July 30, 2019 I seem to have lost the SPI while versions have changed. Tried installing a new "zero" with latest kernel... root@orangepizero:~# uname -a Linux orangepizero 4.19.57-sunxi #5.90 SMP Fri Jul 5 17:58:43 CEST 2019 armv7l armv7l armv7l GNU/Linux root@orangepizero:~# more /boot/armbianEnv.txt verbosity=1 logo=disabled console=serial disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=spi-spidev usbhost2 usbhost3 rootdev=UUID=63cd3251-93f4-4395-a5c0-6d25301ea2ff rootfstype=ext4 param_spidev_spi_bus=0 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Reboot... But, no /dev/spidev..... I have read this string, and my understanding is that this should be sufficient with recent kernel.... Humbly, Gullik 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 Hmmm.... Dumping the contents of the overlay file, /boot/dtb/overlay/sun8i-h3-spi-spidev.dtbo there ARE commands for the spi, but these are disabled. So, would it make more sense to have possible conflicting devices disabled ( as of now ) and the overlay file enabling selected, by the armbianEnv.txt mechanism? Gullik 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 So, boldly decompiled the spi-spidev dtbo, edited the dts to enable spi's, compiled back, replaced the dtbo, rebooted.... Nah....did not work....so obviously my brain did not filter out the correct structure of this.... No trace of anything interesting in dmesg..... Gullik 0 Quote
martinayotte Posted July 30, 2019 Posted July 30, 2019 On 7/30/2019 at 10:22 AM, Gullik said: param_spidev_spi_bus=0 Expand Why SPI0, do you try to access the spi-flash ? If not, if you wish to get SPI on the header, then you should have "param_spidev_spi_bus=1" instead ... 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 Thanks, That's right, but bus=1 does not create any spi device either....so it is something more fundamental... there is a ko named spidev, but modprobe does not make any change either.... Gullik 0 Quote
martinayotte Posted July 30, 2019 Posted July 30, 2019 On 7/30/2019 at 1:55 PM, Gullik said: there is a ko named spidev, but modprobe does not make any change either.... Expand No needs to do "modprobe", if loading overlay succeed, module will be loaded automatically. During early boot, using USB-TTL Serial dongle on debug port, what do you see when overlay is loaded and applying fixup script ? 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 Early boot: looks like it is applying sun8i-h3-spi-spidev.dtbo, it is "stock" except I changed "disabled" to "okay" in two places.... there is no /boot/boot.env on my SD, cannot see it mentioned earlier. U-Boot SPL 2019.04-armbian (Jul 06 2019 - 00:40:48 +0200) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2019.04-armbian (Jul 06 2019 - 00:40:48 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 512 MiB MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 USB4: USB EHCI 1.00 USB5: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 3 for devices... 1 USB Device(s) found scanning bus 4 for devices... 1 USB Device(s) found scanning bus 5 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3798 bytes read in 2 ms (1.8 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 265 bytes read in 1 ms (258.8 KiB/s) 8127296 bytes read in 624 ms (12.4 MiB/s) 7494704 bytes read in 578 ms (12.4 MiB/s) Found mainline kernel configuration 29807 bytes read in 11 ms (2.6 MiB/s) 772 bytes read in 5 ms (150.4 KiB/s) Applying kernel provided DT overlay sun8i-h3-spi-spidev.dtbo 504 bytes read in 7 ms (70.3 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo 504 bytes read in 7 ms (70.3 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo 4155 bytes read in 8 ms (506.8 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND ## Loading init Ramdisk from Legacy Image at 43300000 ... 0 Quote
martinayotte Posted July 30, 2019 Posted July 30, 2019 On 7/30/2019 at 2:40 PM, Gullik said: looks like it is applying sun8i-h3-spi-spidev.dtbo, it is "stock" except I changed "disabled" to "okay" in two places.... Expand You don't have to change that, the fixup script will take care of applying an "okay" to the specified "param_spidev_spi_bus=1". On 7/30/2019 at 2:40 PM, Gullik said: libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND Expand That is the error which seem to be the cause of the problem... Do you still have this error if you revert to the original overlay ? (I've just tested on my OPiZero with DEV 5.2.y, and everything just ran fine ...) 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 And this is the spidev dts, that i processed with dts and stored under it's default name in /boot/dtb/overlays/ sun8i-h3-spi-spidev.dtbo It is 772 bytes, as opposed to 780 original, two times disabled changed to okay. od -a shows "okay" in the dtbo now.... root@orangepizero:~# more test1.dts /dts-v1/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target-path = "/aliases"; __overlay__ { spi0 = "/soc/spi@1c68000"; spi1 = "/soc/spi@1c69000"; }; }; fragment@1 { target = <0xffffffff>; __overlay__ { #address-cells = <0x1>; #size-cells = <0x0>; spidev { compatible = "spidev"; status = "okay"; reg = <0x0>; spi-max-frequency = <0xf4240>; }; }; }; fragment@2 { target = <0xffffffff>; __overlay__ { #address-cells = <0x1>; #size-cells = <0x0>; spidev { compatible = "spidev"; status = "okay"; reg = <0x0>; spi-max-frequency = <0xf4240>; }; }; }; __fixups__ { spi0 = "/fragment@1:target:0"; spi1 = "/fragment@2:target:0"; }; }; 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 Same error with original dtbo ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 265 bytes read in 2 ms (128.9 KiB/s) 8127296 bytes read in 629 ms (12.3 MiB/s) 7494704 bytes read in 577 ms (12.4 MiB/s) Found mainline kernel configuration 29807 bytes read in 11 ms (2.6 MiB/s) 780 bytes read in 6 ms (127 KiB/s) Applying kernel provided DT overlay sun8i-h3-spi-spidev.dtbo 504 bytes read in 7 ms (70.3 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo 504 bytes read in 6 ms (82 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo 4155 bytes read in 7 ms (579.1 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 8127232 Bytes = 7.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 4983f000, end 49fff300 ... OK Loading Device Tree to 497cf000, end 4983efff ... OK Starting kernel ... 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 and the fixup script is there /boot/dtb/overlay/sun8i-h3-fixup.scr Regards, Gullik 0 Quote
martinayotte Posted July 30, 2019 Posted July 30, 2019 On 7/30/2019 at 2:58 PM, Gullik said: Same error with original dtbo Expand Which kernel image it is ? (I will give it a try myself) Are you able to do your own build using DEV 5.2.y ? 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 root@orangepizero:~# uname -a Linux orangepizero 4.19.57-sunxi #5.90 SMP Fri Jul 5 17:58:43 CEST 2019 armv7l armv7l armv7l GNU/Linux picked up from the armbian download page I could probably build myself, but am not set up for that. I have an older OPI Z with working SPI, will look at what kernel it has. All my devices are loaded from armbian download page.... Regards, Gullik 0 Quote
Gullik Posted July 30, 2019 Posted July 30, 2019 The old working spi system had Linux orangepizero 3.4.113-sun8i #68 SMP PREEMPT Wed Sep 19 10:23:30 CEST 2018 armv7l GNU/Linux Quite a time lapse, eh? Regards, Gullik 0 Quote
martinayotte Posted July 30, 2019 Posted July 30, 2019 On 7/30/2019 at 5:27 PM, Gullik said: picked up from the armbian download page Expand I've downloaded this image : https://dl.armbian.com/orangepizero/archive/Armbian_5.90_Orangepizero_Debian_buster_next_4.19.57.7z Written to SD, booted, setup passwd and new user, and finally added SPI1 overlay in /boot/armbianEnv.txt and rebooted : /dev/spidev1.0 is working out-of-the-box ! So, it lead me to think that you SD or image is somehow corrupted ... Re-install usig the above link and report back here ! 0 Quote
Gullik Posted July 31, 2019 Posted July 31, 2019 Thank you very much martinayotte, that worked like a charm :-) I misspelled spi_spidev at first, and got the same error, I might try the other image again, and triple verify spelling, something nonprintable?? anyway, the debian buster image is perfect for my use, and once the keyword was right it behaved exactly as documented / per your instructions. Best Regards, Gullik 0 Quote
martinayotte Posted July 31, 2019 Posted July 31, 2019 On 7/31/2019 at 8:34 AM, Gullik said: I misspelled spi_spidev at first Expand Do you mean that you've misspelled the parameter "param_spidev_spi_bus=1" by using "param_spi_spidev_bus=1" instead ? 0 Quote
Gullik Posted July 31, 2019 Posted July 31, 2019 Hi again, No, first time I tried ( when it failed ) I surely did a cut'n'paste from the web into armbianEnv.txt with these parameters. This time with the image you pointed me at, I wrote overlays=spi_spidev usbhost2 usbhost3 instead of overlays=spi-spidev usbhost2 usbhost3 by manual editing. Then before I posted the results (fail) , I double-checked, and found the mistake. After that all worked as expected. This lead me to believe that I *might* get a good result if I test again and re-edit the Env.txt, I cannot understand why it did not work as described, I guess I will do that and post again, just to close this issue properly If that fails, then there *is* an issue with the OS image I used. I have not observed anything else wrong with that image though. But Debian Buster is fine with me. Regards & Thanx Gullik 0 Quote
anton.miroshnichenko Posted November 13, 2020 Posted November 13, 2020 Hi, guys Sorry for disrupting from the main theme, my question is also about SPI. Could you please give me an advice on how to setup W5500 Ethernet board on Armbian. I created thread for this. Thank you in advance! 0 Quote
TashaGrabovski Posted February 28, 2021 Posted February 28, 2021 (edited) Respected Martinayotte. I have Cubieboard2, Armbian 21.02.2. :~# uname -r => 5.10.16 - sunxi. I have checked up and has adjusted all but SPI0 not working.!!! /boot/armbianEnv.txt^ .... overlays=spi-spidev param_spidev_spi_bus=0 param_spidev_spi_cs=0 param_spidev_max_freq = 1000000 .... /dev/spidev0.0 is OK find /dev -name spidev* => /dev/spidev0.0 Log from ttyS0^ .... Applying kernel provided DT overlay sun7i-a20-spi-spidev.dtbo 5532 bytes read in 12 ms (450.2 KiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) .... dmesg => [ 4.171379] spidev spi0.0: probing from DT sun7i-a20-cubieboard2.dts => ... spi@1c05000 { compatible = "allwinner,sun4i-a10-spi"; reg = < 0x1c05000 0x1000 >; interrupts = < 0x00 0x0a 0x04 >; clocks = < 0x02 0x2c 0x02 0x70 >; clock-names = "ahb\0mod"; dmas = < 0x0c 0x01 0x1b 0x0c 0x01 0x1a >; dma-names = "rx\0tx"; status = "okay"; #address-cells = < 0x01 >; #size-cells = < 0x00 >; num-cs = < 0x04 >; phandle = < 0x41 >; }; ... pinctrl@1c20800 { compatible = "allwinner,sun7i-a20-pinctrl"; reg = < 0x1c20800 0x400 >; ... spi0-pi-pins { pins = "PI11\0PI12\0PI13"; function = "spi0"; phandle = < 0x73 >; }; spi0-cs0-pi-pin { pins = "PI10"; function = "spi0"; phandle = < 0x74 >; }; spi0-cs1-pi-pin { pins = "PI14"; function = "spi0"; phandle = < 0x75 >; }; ... Out of programm spidev_test.c: (MOSI connect to MISO) root@cubieboard2:~/Public# ./spidev_test spi mode: 0 bits per word: 8 max speed: 500000 Hz (500 KHz) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Out programm mcp3008test.cpp: root@cubieboard2:~/Public# ./testspi writing command 1 1 0 transmit failed spi data ... ioctl failed : Invalid argument ---? root@cubieboard2:~/Public# ./testspi writing command 1 1 0 transmit failed spi data ... ioctl failed : Invalid argument ---? root@cubieboard2:~/Public# ./testspi writing command 1 1 0 transmit failed spi data ... ioctl failed : Invalid argument ---? root@cubieboard2:~/Public# ./testspi writing command 1 1 0 reading data 0 0 0 count = 0 voltage 0.0000 writing command 1 1 0 reading data 0 0 0 count = 0 voltage 0.0000 writing command 1 1 0 reading data 0 0 0 count = 0 voltage 0.0000 writing command 1 1 0 reading data 0 0 0 count = 0 voltage 0.0000 writing command 1 1 0 reading data 0 0 0 count = 0 voltage 0.0000 ^C root@cubieboard2:~/Public# ... Not error, SPI0 not working. Help me please^) Edited February 28, 2021 by TashaGrabovski need edit 0 Quote
Cheru Posted March 5, 2022 Posted March 5, 2022 Small update on this: I've tried for hours to get this to work with the 5.10 series kernel: no chance. So I installed an old armbian with 4.19 kernel and it worked on the first try. 0 Quote
mdrmdr Posted March 10, 2022 Posted March 10, 2022 Same here. No SPI device. My Linux nanopineo 5.15.25-sunxi #22.02.1 breaks SPI! How do I downgrade to a previous kernel? Please help! Update: apt install linux-image-legacy-sunxi (kernel 5.4.88) just killed my NanoPi Neo... Does not boot anymore... Update 2: Follow ups to this issue here to have a clean new discussion... 0 Quote
lport3 Posted March 11, 2022 Posted March 11, 2022 (edited) I'll tell you what helped me - using a flash drive XC U1. Perhaps this is just a coincidence. Edited March 11, 2022 by lport3 0 Quote
