I seem to have lost the SPI while versions have changed. Tried installing a new "zero" with latest kernel...
root@orangepizero:~# uname -a
Linux orangepizero 4.19.57-sunxi #5.90 SMP Fri Jul 5 17:58:43 CEST 2019 armv7l armv7l armv7l GNU/Linux
root@orangepizero:~# more /boot/armbianEnv.txt
verbosity=1
logo=disabled
console=serial
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=spi-spidev usbhost2 usbhost3
rootdev=UUID=63cd3251-93f4-4395-a5c0-6d25301ea2ff
rootfstype=ext4
param_spidev_spi_bus=0
Reboot...
But, no /dev/spidev.....
I have read this string, and my understanding is that this should be sufficient with recent kernel....
Humbly,
Gullik
Hmmm....
Dumping the contents of the overlay file, /boot/dtb/overlay/sun8i-h3-spi-spidev.dtbo there ARE commands for the spi, but these
are disabled. So, would it make more sense to have possible conflicting devices disabled ( as of now ) and the overlay file
enabling selected, by the armbianEnv.txt mechanism?
Gullik
So, boldly decompiled the spi-spidev dtbo, edited the dts to enable spi's, compiled back, replaced the dtbo, rebooted....
Nah....did not work....so obviously my brain did not filter out the correct structure of this....
No trace of anything interesting in dmesg.....
Gullik
Why SPI0, do you try to access the spi-flash ?
If not, if you wish to get SPI on the header, then you should have "param_spidev_spi_bus=1" instead ...
Thanks,
That's right, but bus=1 does not create any spi device either....so it is something more fundamental...
there is a ko named spidev, but modprobe does not make any change either....
Gullik
No needs to do "modprobe", if loading overlay succeed, module will be loaded automatically.
During early boot, using USB-TTL Serial dongle on debug port, what do you see when overlay is loaded and applying fixup script ?
Early boot:
looks like it is applying sun8i-h3-spi-spidev.dtbo, it is "stock" except I changed "disabled" to "okay" in two places....
there is no /boot/boot.env on my SD, cannot see it mentioned earlier.
U-Boot SPL 2019.04-armbian (Jul 06 2019 - 00:40:48 +0200)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2019.04-armbian (Jul 06 2019 - 00:40:48 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Zero
DRAM:  512 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
scanning bus 5 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3798 bytes read in 2 ms (1.8 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
265 bytes read in 1 ms (258.8 KiB/s)
8127296 bytes read in 624 ms (12.4 MiB/s)
7494704 bytes read in 578 ms (12.4 MiB/s)
29807 bytes read in 11 ms (2.6 MiB/s)
772 bytes read in 5 ms (150.4 KiB/s)
Applying kernel provided DT overlay sun8i-h3-spi-spidev.dtbo
504 bytes read in 7 ms (70.3 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4155 bytes read in 8 ms (506.8 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
## Loading init Ramdisk from Legacy Image at 43300000 ...
You don't have to change that, the fixup script will take care of applying an "okay" to the specified "param_spidev_spi_bus=1".
That is the error which seem to be the cause of the problem...
Do you still have this error if you revert to the original overlay ?
(I've just tested on my OPiZero with DEV 5.2.y, and everything just ran fine ...)
And this is the spidev dts, that i processed with dts and stored under it's default name in /boot/dtb/overlays/
It is 772 bytes, as opposed to 780 original, two times disabled changed to okay.
od -a shows "okay" in the dtbo now....
root@orangepizero:~# more test1.dts
/dts-v1/;
        compatible = "allwinner,sun8i-h3";
        fragment@0 {
                target-path = "/aliases";
                __overlay__ {
                        spi0 = "/soc/spi@1c68000";
                        spi1 = "/soc/spi@1c69000";
        fragment@1 {
                target = <0xffffffff>;
                __overlay__ {
                        #address-cells = <0x1>;
                        #size-cells = <0x0>;
                        spidev {
                                compatible = "spidev";
                                status = "okay";
                                reg = <0x0>;
                                spi-max-frequency = <0xf4240>;
        fragment@2 {
                __overlay__ {
                        spidev {
                                status = "okay";
                                reg = <0x0>;
        __fixups__ {
                spi0 = "/fragment@1:target:0";
                spi1 = "/fragment@2:target:0";
Same error with original dtbo
265 bytes read in 2 ms (128.9 KiB/s)
8127296 bytes read in 629 ms (12.3 MiB/s)
7494704 bytes read in 577 ms (12.4 MiB/s)
780 bytes read in 6 ms (127 KiB/s)
504 bytes read in 6 ms (82 KiB/s)
4155 bytes read in 7 ms (579.1 KiB/s)
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    8127232 Bytes = 7.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
EHCI failed to shut down host controller.
   Loading Ramdisk to 4983f000, end 49fff300 ... OK
   Loading Device Tree to 497cf000, end 4983efff ... OK
Starting kernel ...
picked up from the armbian download page
I could probably build myself, but am not set up for that. I have an older OPI Z with working SPI, will look at
what kernel it has. All my devices are loaded from armbian download page....
Regards,
Gullik
The old working spi system had
Linux orangepizero 3.4.113-sun8i #68 SMP PREEMPT Wed Sep 19 10:23:30 CEST 2018 armv7l GNU/Linux
Quite a time lapse, eh?
Regards,
Gullik
I've downloaded this image : https://dl.armbian.com/orangepizero/archive/Armbian_5.90_Orangepizero_Debian_buster_next_4.19.57.7z
Written to SD, booted, setup passwd and new user, and finally added SPI1 overlay in /boot/armbianEnv.txt and rebooted : /dev/spidev1.0 is working out-of-the-box !
So, it lead me to think that you SD or image is somehow corrupted ... :wacko:
Re-install usig the above link and report back here ! :P
Thank you very much martinayotte, that worked like a charm :-)
I misspelled spi_spidev at first, and got the same error, I might try the other image again, and triple verify spelling,
something nonprintable?? anyway, the debian buster image is perfect for my use, and once the keyword was right
it behaved exactly as documented / per your instructions.
Best Regards,
Gullik
Hi again,
No, first time I tried ( when it failed ) I surely did a cut'n'paste from the web into armbianEnv.txt with these parameters.
This time with the image you pointed me at, I wrote
overlays=spi_spidev usbhost2 usbhost3
instead of
by manual editing. Then before I posted the results (fail) , I double-checked, and found the mistake.
After that all worked as expected. This lead me to believe that I *might* get a good result if I test again and re-edit the
Env.txt, I cannot understand why it did not work as described, I guess I will do that and post again, just to close this issue properly
If that fails, then there *is* an issue with the OS image I used. I have not observed anything else wrong with that image though.
But Debian Buster is fine with me.
Regards & Thanx
Gullik
Respected Martinayotte.
I have Cubieboard2, Armbian 21.02.2.
:~# uname -r => 5.10.16 - sunxi.
I have checked up and has adjusted all
but SPI0 not working.!!!
/boot/armbianEnv.txt^
overlays=spi-spidev
param_spidev_spi_cs=0
param_spidev_max_freq = 1000000
/dev/spidev0.0 is OK
find /dev -name spidev* => /dev/spidev0.0
Log from ttyS0^
Applying kernel provided DT overlay sun7i-a20-spi-spidev.dtbo
5532 bytes read in 12 ms (450.2 KiB/s)
Applying kernel provided DT fixup script (sun7i-a20-fixup.scr)
dmesg =>
[    4.171379] spidev spi0.0: probing from DT
sun7i-a20-cubieboard2.dts =>
                spi@1c05000 {
                        compatible = "allwinner,sun4i-a10-spi";
                        reg = < 0x1c05000 0x1000 >;
                        interrupts = < 0x00 0x0a 0x04 >;
                        clocks = < 0x02 0x2c 0x02 0x70 >;
                        clock-names = "ahb\0mod";
                        dmas = < 0x0c 0x01 0x1b 0x0c 0x01 0x1a >;
                        dma-names = "rx\0tx";
                        status = "okay";
                        #address-cells = < 0x01 >;
                        #size-cells = < 0x00 >;
                        num-cs = < 0x04 >;
                        phandle = < 0x41 >;
                pinctrl@1c20800 {
                        compatible = "allwinner,sun7i-a20-pinctrl";
                        reg = < 0x1c20800 0x400 >;
                       spi0-pi-pins {
                                pins = "PI11\0PI12\0PI13";
                                function = "spi0";
                                phandle = < 0x73 >;
                        spi0-cs0-pi-pin {
                                pins = "PI10";
                                function = "spi0";
                                phandle = < 0x74 >;
                        spi0-cs1-pi-pin {
                                pins = "PI14";
                                function = "spi0";
                                phandle = < 0x75 >;
Out of programm spidev_test.c: (MOSI connect to MISO)
root@cubieboard2:~/Public# ./spidev_test
spi mode: 0
bits per word: 8
max speed: 500000 Hz (500 KHz)
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00
Out programm mcp3008test.cpp:
root@cubieboard2:~/Public# ./testspi
writing command 1 1 0
transmit failed spi data ... ioctl failed : Invalid argument   ---?
reading data 0 0 0
count = 0 voltage 0.0000
reading data 0 0 0
reading data 0 0 0
reading data 0 0 0
reading data 0 0 0
^C
Not error, SPI0 not working.
Help me please^)
Edited by TashaGrabovski
need edit
Small update on this:
I've tried for hours to get this to work with the 5.10 series kernel: no chance.
So I installed an old armbian with 4.19 kernel and it worked on the first try.
Same here. No SPI device. My Linux nanopineo 5.15.25-sunxi #22.02.1 breaks SPI!
How do I downgrade to a previous kernel? Please help!
Update:
apt install linux-image-legacy-sunxi (kernel 5.4.88) just killed my NanoPi Neo... Does not boot anymore... :angry:
Update 2:
Follow ups to this issue here to have a clean new discussion...
