Share UART7 GPIO i20/i21 pins
Go to solution Solved by alr,
Hello, I have a custom board with A20 and I like to share the UART7(I20/I21) pins. I mean sometimes used as UART and other times used as output ports.
Should I always change the FEX file to use one u other functionality.  The perfect way is using both option without restart the system.
Thanks!
40 minutes ago, zador.blood.stained said:
You should be able to reconfigure the pin controller "live" (without a reboot) using devmem2 (or something similar) by writing directly to the port control registers.
You may want to check PyA20 or other GPIO libraries for the code examples.
Thanks for the answer!
So you are saying that with devmem2 I can set the memory value to the 0x01C20800 + 0x128 (offset) = PI_CFG2 and change the 22:20 and 18:16 bits from 0b001 to 0b011 and 0b011 to 0b001. To use as output pins or UART7 pins. Should I change anything else to allow the UART7 functionality ?. I assume that I also must to change the PI_PULL0 Offset: 0x13C to match the pullup configs into the FEX file :
uart_tx = port:PI20<3><1><default><default>
uart_rx = port:PI21<3><1><default><default>
Thanks for the hint!
Yes, something like this. But I would probably keep them as UART by default (or rather they will be configured for the UART if you have UART7 enabled in FEX), and then you should be able to switch them to functions 0 or 1 when needed.
Most likely yes if there are no external pull-ups on these lines
Meanwhile I remembered that sunxi-pio is better as an example and may even work as is as a standalone command line tool: https://github.com/linux-sunxi/sunxi-tools/blob/master/pio.c
  • Solution
Thanks again for the idea!
I finally got the UART7/GPIO shared pins working without problems. I´m using gpio_lib.
