cad 435 Posted May 5, 2024 Posted May 5, 2024 (edited) Armbianmonitor: https://paste.armbian.com/vezafimilo Hello all, I noticed that since recently (TM) I got loads of spam from panfrost in my dmesg output: I understand that this has something todo with graphics. The only "graphic" thing I'm doing is running standard Klipper-Screen through HDMI and this seems to be working as always... It definately wasn't there like half a year ago. can I get rid of it? Is it something to worry about? my armbian is running on a Banana-Pi CM4 module of of the eMMC. It's a rather standard installation with Klipper installed via KIAUH. sincerely - cad435 Edited May 5, 2024 by cad 435 0 Quote
c0rnelius Posted May 5, 2024 Posted May 5, 2024 This has already been fixed upstream and backported to 6.6.y LTS. https://lore.kernel.org/lkml/20240322164525.2617508-1-christianshewitt@gmail.com/ My suggestion is to update the kernel. If you don't wanna update you may just be able to blacklist the driver, which was what I did until it was fixed. It comes down to what is required by Klipper in your case. 0 Quote
cad 435 Posted May 6, 2024 Author Posted May 6, 2024 Hello! I tried update the kernel vai armbian-config --> System --> Other. There was only one option available, which I chose. System installed something, rebooted. Problem still persists so. What am I missing? https://paste.armbian.com/zojomiciwu Thanks in advance - cad435 0 Quote
c0rnelius Posted May 6, 2024 Posted May 6, 2024 Hmm. It appears ur still on 6.6.16-current-meson64 which does not include the fix. 0 Quote
cad 435 Posted May 6, 2024 Author Posted May 6, 2024 (edited) Any Ideas how I can get my installation to update? Edit: I just rebooted the system one more time after the autoreboot and now I only get some errors and pxelinux is booting... Guess my installation just is f'ed and neets full repair (aka new flashing with SD-Card and copying to eMMC) Guess this topic can be also closed... Edited May 6, 2024 by cad 435 0 Quote
c0rnelius Posted May 6, 2024 Posted May 6, 2024 22 minutes ago, cad 435 said: Any Ideas how I can get my installation to update? Edit: I just rebooted the system one more time after the autoreboot and now I only get some errors and pxelinux is booting... Guess my installation just is f'ed and neets full repair (aka new flashing with SD-Card and copying to eMMC) Guess this topic can be also closed... I'll see if I can get those release imgs updated to something more recent and inquire about the breakage. 0 Quote
cad 435 Posted May 6, 2024 Author Posted May 6, 2024 (edited) I reinstalled armbian, uname -r gets me: 6.6.16-current-meson64 with reinstalled I mean I downloaded the image from the armbian website Edited May 6, 2024 by cad 435 0 Quote
c0rnelius Posted May 6, 2024 Posted May 6, 2024 10 hours ago, cad 435 said: I reinstalled armbian, uname -r gets me: 6.6.16-current-meson64 with reinstalled I mean I downloaded the image from the armbian website Edited 10 hours ago by cad 435 New imgs are now available. 6.6.30-current-meson64 https://www.armbian.com/bananapicm4io/ 0 Quote
cad 435 Posted May 6, 2024 Author Posted May 6, 2024 Is it possible to upgrade? I upgraded the system and the kernel via armbian-config, but now I'm on 6.7.4-edge-meson64... I have no idea how to get to newest "latest release" from within the running system tbh... Is it even possible? sudo apt-get dist-upgrade also did really nothing.... I feel like I'm missing some kind of big point here which just hangs before my face, but I don't see it... 0 Quote
SteeMan Posted May 6, 2024 Posted May 6, 2024 @cad 435 No you aren't really missing anything. In the stable channel, kernel .debs generally only get pushed out every three months when a new stable release is put out (24.05 will be out the end of this month for example). If you want to get regular updates of kernels you need to switch to the nightly builds repository in armbian-config. Right now there is no in between. 0 Quote
