Hi!
I am trying to compile a kernel for my banana pi with different configuration but I get error saying that kernel was not built.
I am using Ubuntu 14.04. Below are the steps I make:
1) create a compile.sh file with contents from http://forum.armbian.com/index.php/topic/6-sdk-how-to-compile-your-own-kernel-and-sd-image/
2) Change KERNEL_CONFIGURE= to yes
3) run the file with sudo ./compile.sh
and after this it starts to work, download files, I choose that I need to create banana pi image, then I choose mainline linux and after it finishes downloading, the menuconfig appears, I make one change [ mark "Device Drivers -> Multimedia support -> Media USB Adapters -> USB Video Class" ]
4) Then save and exit and the process is resumed, and I get 2 errors after this, while compiling, and the process is stopped.
(in compile.sh, I tried SOURCE_COMPILE="yes" and SOURCE_COMPILE="no" but the still is the same error.)
I have posted a screenshot of the compiling process. It is begins from the downloading of git archive and shows all process until the error of compilation.
Link to the screenshot: http://postimg.org/image/n2i6z3ylj/
O.K. I believe you ;)
It's working here but yes it's possible that something is not quite right. I am doing code inspection ...
