Hello everyone
I own some noname chinese Android stick, which has Allwinner A20 CPU. Unfortunately, long time ago seller cheated me and device has 512 MB ram instead of 1GB (4 gigabit chips..). It has some "Android" firmware (which shows 1GB), but I cannot find nor backup, neither upgrade firmware. Not a big deal, since device not in active use.
I tried Armbian Cubeiboard2 and pcDuino3 builds - everything working like a charm, desktop starts, so I want to run sata-nand install for Armbian for legacy kernel - /dev/nand is here, and I can even dump a "backup" of NAND to have it "just in case".
Some help is really appreciated (some questions):
  1. I run "sata-nand-install" or whatever it called - it will erase/repartition nand and install the system... Is there a catch ? Assuming NAND is detected, working and writable - what bad things can happen ?
  2. If (1) will run smoothly, can I prepare system on microSD (like replace firefox to something more robust, enable ZRAM, etc) and will settings/applications will be transferred to NAND via install script  ?
  3. I tried only Cubieboard 2 and pcDuino3 - but there are more devices A20 in download section. May be some other device image is more suitable for such experiments ?
  4. How I can disable ethernet - via editing script.bin or should I recompile kernel ? pcDuino build tries to enable gmac, fails and I can continue, but Cubieboard2 builds keeps probing until I will say "ifdown eth0". I tried sunxi kernels longtime ago (before active Armbian development) and script.bin patching helped... If script.bin is good way to do this, please point me please to armbian-style-compatible tutorail :)
Thanks a lot for your answers in advance.
Android->Linux switching may requre writing a Linux image with PhoenixSuit/LiveSuite first
Yes.
The only differences are u-boot compile-time configuration and script.bin, so it doesn't matter much
script.bin editing should be enough, but the only way to say for sure would be checking the kernel code or actually trying to fiddle with script.bin
https://linux-sunxi.org/Fex_Guide
and in general just bin2fex, edit, fex2bin it back.
Please note that you may want to remove Armbian repository from /etc/apt/sources.list.d or pin some packages to prevent upgrades from overwriting your changes. And in general upgrading kernel on NAND is not recommended as it is prone to breaking the system.
Yes, I have seen it in Cubieboard2 description... Just curious - does pcDuino have same issue ?
For the rest - good news anyway, will give a try someday. Thanks for all your efforts for making this project brilliant!
Hi znoxx, I'm running Armbian in a different device a mele a2000, and for luck of me, my device , uboot or the dts is suported in mainline, and I was able to build a image for my device with armbian script with minimal changes,
you can check if your device is at wiki of linux-sunxi.org and if there are some uboot mainline support.
http://linux-sunxi.org/Category:Devices
or if not exists, you can add it at the list
http://linux-sunxi.org/New_Device_howto
or compare your script.bin in your android image with the cubieboard or pcuino what are the differences.
its a great wiki to check allwinner socs and boards, and it helps others with the same problem.
@calhemp, thanks!
Looks like i successfully disabled sata and emac  in script bin and changed to 720p resolution, and no errors so far. But since device is 512mb only, my only choice is Midori as a browser (and qupzilla sometimes).
Looks like DTS approach (mainline) is not for me, since I'm chasing hardware acceleration for mpv...
Time for may be stupid question - if I will install to NANd successfully, does it mean I won't need an SD ? I mean bootloader will be also installed to NAND ?
Digging my old topic.
I successfully patched script.bin for my legacy kernel - no problem with this.
Now I'm looking into "mainline". Looks like I found dtb file for my device - sun7i-a20-mk808c.dtb
The only thing that bugs me with using "cubieboard2" image - I'm getting errors about eth0 (since well, android stick does not have eth0 :)
So I edited armbianEnv.txt and added this:
fdtfile=sun7i-a20-mk808c.dtb
Looks like it's now working correctly!
My question: Is it right approach ? Or I must change device type somehow differently ?
And what to read if I want to build my own dtb ?
So I need to build my own uboot from source ? Or it can be applied somehow without recompilation ?
