OttawaHacker Posted May 26, 2024 Posted May 26, 2024 I tried both the 6.8.10 and 6.1.43 releases from CI pipeline and none of these has the ap6275p wifi option in the armbian-config tool. There was a previous post that mentioned that the module got merged for the new kernels but is there an ETA to have this one in the CI releases? I'm curious to try vlc but haven't been able to install that one yet with the new releases. 0 Quote
Efe Çetin Posted May 26, 2024 Posted May 26, 2024 You need something like https://github.com/armbian/build/blob/main/patch/kernel/rockchip-rk3588-edge/dt/rk3588s-orangepi-5b.dts#L32 to enable it on mainline. I don't know the situation because of i don't have ap6275p module for opi5 but it works with Khadas edge 2. And we have an overlay for opi5 in 6.1 https://github.com/armbian/linux-rockchip/blob/rk-5.10-rkr6/arch/arm64/boot/dts/rockchip/overlay/orangepi-5-ap6275p.dts 0 Quote
OttawaHacker Posted May 27, 2024 Author Posted May 27, 2024 On 5/26/2024 at 6:31 AM, Efe Çetin said: And we have an overlay for opi5 in 6.1 https://github.com/armbian/linux-rockchip/blob/rk-5.10-rkr6/arch/arm64/boot/dts/rockchip/overlay/orangepi-5-ap6275p.dts Would you know by any chance what is missing to have this one show up in the hardware section in armbian-config? In 6.1, there are only two options available. Or is this a pre-release thing? I will try that other change for the 6.8 to enable it, but any reason this is not included in the current build? 0 Quote
Efe Çetin Posted May 28, 2024 Posted May 28, 2024 15 hours ago, OttawaHacker said: In 6.1, there are only two options available. Or is this a pre-release thing? It's interesting. I'll check it out to see what's missing 0 Quote
