Hello, I've just switched from bananian to armbian (as many others here as I've seen), and successfully finished migrating everything. I use the Banana as a little home server, NAS, sane/cups printer sharer and home cloud. I want to use docker on it, but I'm finding some difficulties to make it run. I'm currently on 4.9.12-sunxi. I've tried installing docker from the ubuntu repo but it doesn't seem to work. I've seen some topics about building a custom kernel for this, is this necessary?
Did someone managed to make docker run?
Thanks.
Sorry for double posting.
More info:
Installation with
curl -sSL get.docker.com | sh
seems to be ok, but I get this error message when i run hello-world:
standard_init_linux.go:178: exec user process caused "exec format error"
This is my system:
ARMBIAN 5.25 stable Ubuntu 16.04.2 LTS 4.9.12-sunxi
Just did a forum search for "Docker", on the first page of search results:
It shouldn't be necessary with the mainline kernel, but you can always use check-config.sh to verify.
Thanks.
The kernel required seems ok:
info: reading kernel config from /proc/config.gz ...
Generally Necessary:
- cgroup hierarchy: properly mounted [/sys/fs/cgroup]
- CONFIG_NAMESPACES: enabled
- CONFIG_NET_NS: enabled
- CONFIG_PID_NS: enabled
- CONFIG_IPC_NS: enabled
- CONFIG_UTS_NS: enabled
- CONFIG_CGROUPS: enabled
- CONFIG_CGROUP_CPUACCT: enabled
- CONFIG_CGROUP_DEVICE: enabled
- CONFIG_CGROUP_FREEZER: enabled
- CONFIG_CGROUP_SCHED: enabled
- CONFIG_CPUSETS: enabled
- CONFIG_MEMCG: enabled
- CONFIG_KEYS: enabled
- CONFIG_VETH: enabled (as module)
- CONFIG_BRIDGE: enabled (as module)
- CONFIG_BRIDGE_NETFILTER: enabled (as module)
- CONFIG_NF_NAT_IPV4: enabled (as module)
- CONFIG_IP_NF_FILTER: enabled (as module)
- CONFIG_IP_NF_TARGET_MASQUERADE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_IPVS: enabled (as module)
- CONFIG_IP_NF_NAT: enabled (as module)
- CONFIG_NF_NAT: enabled (as module)
- CONFIG_NF_NAT_NEEDED: enabled
- CONFIG_POSIX_MQUEUE: enabled
Optional Features:
- CONFIG_USER_NS: enabled
- CONFIG_SECCOMP: enabled
- CONFIG_CGROUP_PIDS: enabled
- CONFIG_MEMCG_SWAP: enabled
- CONFIG_MEMCG_SWAP_ENABLED: missing
    (cgroup swap accounting is currently enabled)
- CONFIG_BLK_CGROUP: enabled
- CONFIG_BLK_DEV_THROTTLING: enabled
- CONFIG_IOSCHED_CFQ: enabled
- CONFIG_CFQ_GROUP_IOSCHED: enabled
- CONFIG_CGROUP_PERF: enabled
- CONFIG_CGROUP_HUGETLB: missing
- CONFIG_NET_CLS_CGROUP: enabled (as module)
- CONFIG_CGROUP_NET_PRIO: enabled
- CONFIG_CFS_BANDWIDTH: enabled
- CONFIG_FAIR_GROUP_SCHED: enabled
- CONFIG_RT_GROUP_SCHED: enabled
- CONFIG_IP_VS: enabled (as module)
- CONFIG_IP_VS_NFCT: enabled
- CONFIG_IP_VS_RR: enabled (as module)
- CONFIG_EXT4_FS: enabled
- CONFIG_EXT4_FS_POSIX_ACL: enabled
- CONFIG_EXT4_FS_SECURITY: enabled
- Network Drivers:
  - "overlay":
    - CONFIG_VXLAN: enabled (as module)
      Optional (for encrypted networks):
      - CONFIG_CRYPTO: enabled
      - CONFIG_CRYPTO_AEAD: enabled
      - CONFIG_CRYPTO_GCM: enabled (as module)
      - CONFIG_CRYPTO_SEQIV: enabled
      - CONFIG_CRYPTO_GHASH: enabled (as module)
      - CONFIG_XFRM: enabled
      - CONFIG_XFRM_USER: enabled (as module)
      - CONFIG_XFRM_ALGO: enabled (as module)
      - CONFIG_INET_ESP: enabled (as module)
      - CONFIG_INET_XFRM_MODE_TRANSPORT: enabled (as module)
  - "ipvlan":
    - CONFIG_IPVLAN: enabled (as module)
  - "macvlan":
    - CONFIG_MACVLAN: enabled (as module)
    - CONFIG_DUMMY: enabled (as module)
  - "ftp,tftp client in container":
    - CONFIG_NF_NAT_FTP: enabled (as module)
    - CONFIG_NF_CONNTRACK_FTP: enabled (as module)
    - CONFIG_NF_NAT_TFTP: enabled (as module)
    - CONFIG_NF_CONNTRACK_TFTP: enabled (as module)
- Storage Drivers:
  - "aufs":
    - CONFIG_AUFS_FS: enabled (as module)
  - "btrfs":
    - CONFIG_BTRFS_FS: enabled
    - CONFIG_BTRFS_FS_POSIX_ACL: enabled
  - "devicemapper":
    - CONFIG_BLK_DEV_DM: enabled (as module)
    - CONFIG_DM_THIN_PROVISIONING: enabled (as module)
  - "overlay":
    - CONFIG_OVERLAY_FS: enabled (as module)
  - "zfs":
    - /dev/zfs: missing
    - zfs command: missing
    - zpool command: missing
Limits:
- /proc/sys/kernel/keys/root_maxkeys: 1000000
I will try armhf containers
