Using USB OTG port as regular USB2.0 - Rock64
Hi,
First of all I am posting in Rockpro64 section because I am not seeing one for Rock64
What I need is like the title says: use OTG USB port as regular USB 2.0 port (so I can connect another device). Currently I need the 2 USB 2.0 ports (USB 3.0 is already being used with a external disk).
Is this possible?
OS version: Armbian 24.2.1 Jammy - Linux 6.6.16-current-rockchip64
Thanks in advance.
Moved to the correct forum.  Armbian does not support the Rock64.  It is Community Maintained, moved to the Community Maintained forums and added the correct board tag.
