VaRusLAN Posted May 30, 2024 Posted May 30, 2024 I installed latest vendor image and because of the wifi issues I switched to the edge kernel. I messed up my fstab, couldn't connect with ssh, so I plugged it to my monitor and a keyboard, but there was no video. Eventually, I fixed it by booting vendor image from my sd card, but I got curious. I know, that vendor image just works, so I flashed edge image to my sd card to see what's wrong. The monitor recognizes the presence of the board, but it's just a black screen. I can ssh to the board, so the image definitely booted, but there's just no video. Here's the log from my original installation. I kept 6.8 kernel because the video is not important to me. 0 Quote
Hqnicolas Posted May 30, 2024 Posted May 30, 2024 (edited) On 5/30/2024 at 1:19 PM, VaRusLAN said: but there's just no video. Expand I think you need to check VOP config over DTS [ 7.670534] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 7.670617] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 7.670647] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 8.064408] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 8.064415] rockchip-dmc dmc: failed to get vop pn to msch rl Edited May 30, 2024 by Hqnicolas 0 Quote
ricardo_brz Posted May 31, 2024 Posted May 31, 2024 On 5/30/2024 at 1:19 PM, VaRusLAN said: there was no video Expand Which HDMI port did you connect? I was testing it today and it only showed some video in the midle HDMI port. One thing I noticed is that it's still not working with Ultra Wide monitors. I was able to work with it in 1080p, but not in 2k@21x9. 0 Quote
Hqnicolas Posted June 1, 2024 Posted June 1, 2024 On 5/31/2024 at 8:27 PM, ricardo_brz said: I was testing it today and it only showed some video in the midle HDMI port. Expand I dont have this board, but i think you can check your vp routing and vop &vp0 { rockchip,plane-mask = <(1 << ROCKCHIP_VOP2_CLUSTER0 | 1 << ROCKCHIP_VOP2_ESMART0 | 1 << ROCKCHIP_VOP2_SMART0 | 1 << ROCKCHIP_VOP2_CLUSTER1 | 1 << ROCKCHIP_VOP2_ESMART1 | 1 << ROCKCHIP_VOP2_SMART1)>; rockchip,primary-plane = <ROCKCHIP_VOP2_SMART0>; }; &hdmi_in_vp0 { status = "okay"; }; &hdmi_in_vp1 { status = "okay"; }; 0 Quote
VaRusLAN Posted June 1, 2024 Author Posted June 1, 2024 On 5/31/2024 at 8:27 PM, ricardo_brz said: I was able to work with it in 1080p, but not in 2k@21x9. Expand Huh, I actually tested it with 2k@21x9 monitor. Never thought that would be a problem. And I tried both HDMI 1 and 2. I think I'm going to stay with 6.1 kernel for a while 0 Quote
VaRusLAN Posted June 1, 2024 Author Posted June 1, 2024 On 6/1/2024 at 3:34 AM, Hqnicolas said: &hdmi_in_vp0 { status = "okay"; }; &hdmi_in_vp1 { status = "okay"; }; Expand Interesting. I wanted to decompile dtb's for 6.1 and 6.8, but then I found an overlay called orangepi-5-plus-hdmi2-8k.dtbo (2k!) for the 6.1 kernel, but not for the 6.8 kernel. And this overlay in linux-orangepi vendor repo indeed just enables hdmi nodes. I guess I just need to add this overlay to 6.8 and see if it works. rk3588-orangepi-5-plus 6.1.dtsFetching info... rk3588-orangepi-5-plus 6.8.dtsFetching info... orangepi-5-plus-hdmi2-8k.dtsoFetching info... 0 Quote
ricardo_brz Posted June 4, 2024 Posted June 4, 2024 On 6/1/2024 at 5:32 AM, VaRusLAN said: I guess I just need to add this overlay to 6.8 and see if it works. Expand Did you get any luck with this? I tried adding the files to /boot/overlay-user/ and set the user_overlays in armbianEnv.txt but I didn't succeeded. I followed this guide: https://docs.armbian.com/User-Guide_Armbian_overlays/ 0 Quote
VaRusLAN Posted June 5, 2024 Author Posted June 5, 2024 On 6/4/2024 at 11:57 AM, ricardo_brz said: Did you get any luck with this? I tried adding the files to /boot/overlay-user/ and set the user_overlays in armbianEnv.txt but I didn't succeeded. Expand Sorry, I haven't got time to tinker with it. I'm staying with vendor kernel and trying to get nextcloud running, so 6.8 is not a priority for me now. I don't think it's possible to just add this overlay at boot time. I wanted to recompile the kernel with modified dts and then include this overlay. Why I think it's necessery is because of the __symbols__ node in decompiled versions of dtb's. 6.1 dp0_in_vp1 = "/dp@fde50000/ports/port@0/endpoint@1"; dp0_in_vp2 = "/dp@fde50000/ports/port@0/endpoint@2"; dp0_out = "/dp@fde50000/ports/port@1/endpoint"; hdcp1 = "/hdcp@fde70000"; hdmi0 = "/hdmi@fde80000"; hdmi0_in = "/hdmi@fde80000/ports/port@0"; hdmi0_in_vp0 = "/hdmi@fde80000/ports/port@0/endpoint@0"; hdmi0_in_vp1 = "/hdmi@fde80000/ports/port@0/endpoint@1"; hdmi0_in_vp2 = "/hdmi@fde80000/ports/port@0/endpoint@2"; edp0 = "/edp@fdec0000"; edp0_in_vp0 = "/edp@fdec0000/ports/port@0/endpoint@0"; edp0_in_vp1 = "/edp@fdec0000/ports/port@0/endpoint@1"; edp0_in_vp2 = "/edp@fdec0000/ports/port@0/endpoint@2"; dp1 = "/dp@fde60000"; dp1_in_vp0 = "/dp@fde60000/ports/port@0/endpoint@0"; dp1_in_vp1 = "/dp@fde60000/ports/port@0/endpoint@1"; dp1_in_vp2 = "/dp@fde60000/ports/port@0/endpoint@2"; dp1_out = "/dp@fde60000/ports/port@1/endpoint"; hdmi1 = "/hdmi@fdea0000"; hdmi1_in = "/hdmi@fdea0000/ports/port@0"; hdmi1_in_vp0 = "/hdmi@fdea0000/ports/port@0/endpoint@0"; hdmi1_in_vp1 = "/hdmi@fdea0000/ports/port@0/endpoint@1"; hdmi1_in_vp2 = "/hdmi@fdea0000/ports/port@0/endpoint@2"; edp1 = "/edp@fded0000"; edp1_in_vp0 = "/edp@fded0000/ports/port@0/endpoint@0"; edp1_in_vp1 = "/edp@fded0000/ports/port@0/endpoint@1"; edp1_in_vp2 = "/edp@fded0000/ports/port@0/endpoint@2"; 6.8 sys_grf = "/syscon@fd58c000"; hdptxphy0_grf = "/syscon@fd5e0000"; hdmi0 = "/hdmi@fde80000"; hdmi0_in = "/hdmi@fde80000/ports/port@0"; hdmi0_in_vp0 = "/hdmi@fde80000/ports/port@0/endpoint"; hdmi0_out = "/hdmi@fde80000/ports/port@1"; hdmi0_out_con = "/hdmi@fde80000/ports/port@1/endpoint"; vop_grf = "/syscon@fd5a4000"; vo0_grf = "/syscon@fd5a6000"; vo1_grf = "/syscon@fd5a8000"; usb_grf = "/syscon@fd5ac000"; And overlay patches __fixups__ { hdmi0_in_vp0 = "/fragment@0:target:0"; hdmi0_in_vp1 = "/fragment@1:target:0"; hdmi1_in_vp0 = "/fragment@2:target:0"; hdmi1_in_vp1 = "/fragment@3:target:0"; }; 6.8 does not even have hdm1* nodes, so we either need to somehow change the overlay or modify dts and rebuild kernel 0 Quote
