Hi all,
I was able to make my H96 MAX M9S running on armbian (beta) Linux 6.19.0-rc8-edge-rockchip64.
Using:
- armbian u-boot, installed by armbian-config
- root fs on emmc
Working:
- both USB ports
- HDMI (audio+video)
- Ethernet port
- Wifi using aic8800 DKMS drivers provided by https://github.com/radxa-pkg/aic8800/releases
- Leds
Not working:
- GPU/NPU
- Bluetooth
- any HW acceleration
- many other things as in attached dmesg
Known issues:
- no USB port is working in usb3 mode (5000M)
- missing hci port for Bluetooth
- driver aic8800_btlpm_sdio hast to be loaded manually
- other as in attached dmesg
Attached you can find:
- my working dts for armbian Linux 6.19.0-rc8-edge-rockchip64
- my original dts extracted from the box
- dmesg
Hope some will be able to help with other things :)
rk3576-evb1-v10-main-h96-v3.dts rk3576-evb1-v10_org.dts dmesg.txt
I've made some improvements of .dts for H96 MAX M9S, tested on Linux version 6.19.0-edge-rockchip64 (build@armbian)
What's new:
  • GPU working
  • USB 3.0 mode working
Currently working:
Not working:
  • NPU
  • Bluetooth
  • S/PDIF
rk3576-evb1-v10-main-h96-v5.dts dmesg-19.0.txt
