@prahal There are two versions of the bootloader in the repository (edge and current).
I just tried the current u-boot from the repository. It works but dmesg outputs seven of the following messages:
[    9.674633] rockchip-i2s ff8a0000.i2s: Could not register PCM
This note mentions that such error messages could mean that DMA and sound are missing in the linux kernel, could this be ignored ?
P.S.: Those messages are not thrown if the recommended bootloader (linux-u-boot-edge-helios64_22.02.1_arm64) is flashed to emmc.
Edited by ebin-dev
download link added to linux-u-boot-edge-helios64_22.02.1_arm64​​​​​​​
Adding more clues from your issue:
current u-boot from the repository (linux-u-boot-helios64-current_24.5.0-trunk.608_arm64__2022.07-Se092-Pe990-H8c72-V65aa-Bf5f6-R448a)
Expand
this u-boot is I  guess, mainlain u-boot and ATF with rockchip DDR blob.
linux-u-boot-edge-helios64_22.02.1 is likely the rockchip ATF, miniloader and DDR blob.
Seems linux-u-boot-edge-helios64_22.02.1_arm64 is not available to download anymore? EIther way, this is a binary blob so could only be used to test feature parity.
apt policy linux-u-boot-helios64-edge
linux-u-boot-helios64-edge:
  Installé : 24.5.1
  Candidat : 24.5.1
 Table de version :
 *** 24.5.1 500
        500 http://apt.armbian.com bookworm/main arm64 Packages
        100 /var/lib/dpkg/status
     24.2.1 500
the link you provided looks like a match for this issue.
I noted that
is printed each time a USB device is plugged in (probably also when probed at boot).
also, it has been a long time I noticed:
juin 08 16:18:53 helios64 kernel: platform ff1e0000.spi: deferred probe pending: (reason unknown)
juin 08 16:18:53 helios64 kernel: platform ff200000.spi: deferred probe pending: (reason unknown)
juin 08 16:18:53 helios64 kernel: platform ff8a0000.i2s: deferred probe pending: (reason unknown)
juin 08 16:18:53 helios64 kernel: amba ff6d0000.dma-controller: deferred probe pending: (reason unknown)
juin 08 16:18:53 helios64 kernel: amba ff6e0000.dma-controller: deferred probe pending: (reason unknown)
juin 08 16:18:53 helios64 kernel: platform ff1d0000.spi: deferred probe pending: (reason unknown)
at the end of the kernel boot log. (ie kernel giving up trying to load the drivers for these).
Seems related too.
