kuraimangetsu Posted June 12 Share Posted June 12 Hi i installed an armbian img dirictly to the emmc, and i want to make a backup img file of it after installing and config few things on it! i can't use the "ddbr" command cuz it's already installed directly to the emmc. is there any other way? 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted June 12 Share Posted June 12 You can use ddbr. You just need to boot from an SD card so the emmc isn't being used and then run ddbr from the SD card to make the backup. 0 Quote Link to comment Share on other sites More sharing options...
kuraimangetsu Posted June 13 Author Share Posted June 13 Quote 17 hours ago, SteeMan said: You can use ddbr. You just need to boot from an SD card so the emmc isn't being used and then run ddbr from the SD card to make the backup. but i already installed the IMG on emmc how can i boot now from the SD card? 0 Quote Link to comment Share on other sites More sharing options...
kuraimangetsu Posted June 13 Author Share Posted June 13 i use the SD card with multitool and stop the auto boot for U-boot but i don't know how to make it boot from SD card 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted June 13 Share Posted June 13 No you need to boot a full armbian from the SD card. If you have an armbian image on the SD card, it should boot from that before booting from emmc. 0 Quote Link to comment Share on other sites More sharing options...
kuraimangetsu Posted June 14 Author Share Posted June 14 20 hours ago, SteeMan said: No you need to boot a full armbian from the SD card. If you have an armbian image on the SD card, it should boot from that before booting from emmc. tried different Sd card with different ver of multitool. but, it still boots directly from EMMC 0 Quote Link to comment Share on other sites More sharing options...
Ahmed Jabbar Posted Friday at 05:37 AM Share Posted Friday at 05:37 AM (edited) Can i run Armbian without Multitool ? Just with the SD card? Thanks. Edited Friday at 12:18 PM by Ahmed Jabbar 0 Quote Link to comment Share on other sites More sharing options...
