tomter Posted April 25, 2017 Posted April 25, 2017 Hello, I am opening new topic because I simply cannot get monitor running on 1280x800. I only get shrinked picture, that isn't that I am looking. I also cannot understand how to add new resolution to kernel. Please help, thanks all in advance
Tido Posted April 26, 2017 Posted April 26, 2017 Hi Tomter, If you not already have done it, in the very right corner on top, hit search and look for: resolution There are a couple threads to that topic (and custom resolution) already that might guide you. Cheers Tido
tomter Posted April 28, 2017 Author Posted April 28, 2017 Hello, I have another issue, only on 720p and 1080p is picture with normal colours. On other is green and pink, so it doesn't work. Reply on previous comments: I have checked this topics, but I haven't found where is this patch put? In which directory? I have also tried SD card with h3 disp helper, but it didn't boot, probably because is made in VM. Is there another solution for Windows image burner? I am complete newbie on LCD timings, so please help me.
tomter Posted April 28, 2017 Author Posted April 28, 2017 On PC with AMD graphics I get detailed report of LCD, if helps: Horizontal Timing Total - 1688 Horizontal Timing Display - 1280 Horizontal Timing Front Porch - 48 Horizontal Timing Sync Width - 112 Vertical Timing Total - 1066 Vertical Timing Display - 1024 Vertical Timing Front Porch - 1 Vertical Timing Sync Width - 3 Horizontal Timing Polarity - Positive Vertical Timing Polarity - Positive Interlaced/Progressive - Progressive G.Pixel Clock (KHz) - 108000 G.Refresh Rate (Hz) - 60.0197 Current HDCP Status - Disabled Current Link Settings - Not Available
