Cidirom Regrabable Posted April 26, 2017 Posted April 26, 2017 @Igor, I started a new topic because is more clear. I compiled with the last files in your github and remove the ".disabled" of the file 30-real-time143-full-plus-rt-fixes.patch . I choose the option 5 (full real time) but crashes. I attach the screen of the error. I compiled two times. One in lubuntu 16 and other in Ubuntu 16. The error is the same. Very Thanks!!!
Igor Posted April 26, 2017 Posted April 26, 2017 Quote I choose the option 5 (full real time) but crashes. Expand Yes, it's known that it crashes at some option. I don't recall which one is correct but I believe you can find it on forum ... or just do experiment. This problem is unrelated to your host infrastructure.
Cidirom Regrabable Posted April 26, 2017 Author Posted April 26, 2017 Yes, The problem is that the 5th option is the very interesting because is the full RT, the other are RT but partial. I found this patch https://www.kernel.org/pub/linux/kernel/projects/rt/3.4/patch-3.4.113-rt145.patch.xz how i can patch the kernel of armbian with this patch? I put on the folder sun8i-default but the process fail. Thanks
Igor Posted April 27, 2017 Posted April 27, 2017 On 4/26/2017 at 11:28 PM, Cidirom Regrabable said: I put on the folder sun8i-default but the process fail. Expand That's the source of our patch too and ours is already (almost) aligned with kernel source. Perhaps starting from a clean patch is a right way, but you need some expertise for doing this since patch will need adjustments and can't be just put in. Dig in or find a person who can.
