arnaudf Posted June 21 Share Posted June 21 (edited) Armbianmonitor: https://paste.armbian.com/evajafekoh Hello, After several days of debug I put the finger on a very strange issue using integrated Ethernet. I use my Rockpro64 mostly as a Samba and DNS server. In my network context I implement 2 vlans as vlan interfaces (eth0.10 and eth0.20). Each of these interfaces needs to use a specific mac address that differs from physical eth0 mac address (it is an important point). If I use only the physical mac my router is not be able to route correctly between vlans (probably an ivl/svl issue). Under this context I first noticed that when I bring down eth0.20 although using vlan 10 (so eth0.10) connectivity is lost. I then write a script to gather all needed information (ie. ip link/addr/route/rule/neigh, ping, arping, netstat, ...) ==> no peculiar problem I then add a background tcpdump and, guess what, the connectivity loss didn't occur anymore ! After thinking a bit, I made the assumption that the main difference is the use of promiscuous mode during tcpdump. ==> and "bingo" : setting 'promisc' flag on eth0 acts as a workaround. Also if I do not set a specific mac for vlan and use physical mac leads to no connectivity issue, despite the wrong routing. The key point seems that bringing down a vlan interface unregisters all macaddress from listening process instead only the needed, so the connectivity problem. I don't know if it's a hardware limitation, a driver bug or Armbian issue, but I am open to any fix or at least, any debug hint that helps to narrow down the root cause. Regards. Edited Friday at 09:36 PM by arnaudf 0 Quote Link to comment Share on other sites More sharing options...
