FYI
I've found a problem with the nand-sata-install script after building a 4.6 version for my pcduino, nand-part does not exist in /usr/sbin. Did a full, default compile. Seems the command its in the PATH but if i try to run nand-part i get "/usr/sbin/nand-part now found"
lf I go manually in there and do a "ls " its there, but even if im in the folder and do ./nand-part same error appears.
The error that I'm getting from nand-sata-install is not enough space on nand2, because nand-part is not able to run and aprtition the disk its trying to copy all root to 16MB(old partitioning from stock linksprite image). To make it work for myself i manually compiled nand-part and partitioned the nand properly.
Hope it helps,
Thanks!
You are using self compiled image?
What about fex2bin bin2fex utilities?
I noticed few weeks ago that those utilities failed to build so I fix the git pointer to specific commit. Since than it should work ... I'll check.
