Wittenborg Posted April 29, 2017 Posted April 29, 2017 Hi! I had serveral errors with my Cubietruck running Ubuntu 16.04 Vanilla Kernel. The system is installed on a hard-disc. There were some filesystem-error which fsck could repair. But I still have some errors. root@cubianx:~# systemctl --failed UNIT LOAD ACTIVE SUB DESCRIPTION ● apparmor.service loaded failed failed LSB: AppArmor initialization ● systemd-modules-load.service loaded failed failed Load Kernel Modules LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 2 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. root@cubianx:~# root@cubianx:~# /lib/systemd/systemd-modules-load Failed to find module 'gpio_sunxi' Failed to find module 'sunxi-ir' Failed to find module 'spi_sun7i' Failed to find module 'ap6210' root@cubianx:~# I don't know what these errors mean and how to repair them.
zador.blood.stained Posted April 29, 2017 Posted April 29, 2017 Did you switch kernel branch from legacy/default to mainline? These module names match default/legacy configuration, so you should remove them from /etc/modules
Wittenborg Posted April 29, 2017 Author Posted April 29, 2017 Yes, I think i switched a time ago. So these modules are now integrated? What about apparmor? Can I remove this?
Wittenborg Posted April 30, 2017 Author Posted April 30, 2017 12 hours ago, Wittenborg said: What about apparmor? Can I remove this? No, I can't. When I try to remove this, mysql-server will also be removed. I tried apt-get install --reinstall apparmor but I still got this error. Anybody knows how to repair apparmor? Maybe this is the source of the crashes up to 3 times a day.
zador.blood.stained Posted April 30, 2017 Posted April 30, 2017 You can just disable apparmor service. Most likely it's missing some required kernel options to start properly, but it may as well be ignored.
Wittenborg Posted May 1, 2017 Author Posted May 1, 2017 So these crashes didn't stop. Because I wasn't able to connect via SSH when the CT crashed and I didn't find something usefull in the syslog, I connected the CT to a monitor. The next crash happend 4,5 hours later, with this matrix-like screen: Can anyone find the source of the problem? On this device there is a nextcloud running on nginx and mysql and also a tvheadend server. The SAT-IP-tuner is connected via LAN. tvheadend is HTS Tvheadend 4.1-2533~g80c52b2 compiled with: AUTOBUILD_CONFIGURE_EXTRA=--disable-bintray_cache\ --disable-hdhomerun_static\ --disable-ffmpeg_static\ --disable-dvbscan ./Autobuild.sh
