I downloaded the image of nanopi R6s from the official website[https://www.armbian.com/nanopi-r6s/](https://www.armbian.com/nanopi-r6s/), but it failed to start no matter burning to sd card or emmc. I know a lot of people have this problem, like this page [https://forum.armbian.com/topic/27904-armbian-images-for-r6s-r6c/?do=findComment&comment=164029](https://forum.armbian.com/topic/27904-armbian-images-for-r6s-r6c/?do=findComment&comment=164029)
 This is the log printed by the serial port:
DDR V1.12 52218f4949 cym 23/07/06-19:46:50
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
Manufacturer ID:0x1
CH0 RX Vref:27.5%, TX Vref:20.8%,19.8%
CH1 RX Vref:26.3%, TX Vref:19.8%,20.8%
CH2 RX Vref:27.5%, TX Vref:19.8%,19.8%
CH3 RX Vref:27.1%, TX Vref:21.8%,21.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-g82417168bf-230508 #root (Sep 08 2023 - 20:53:43)
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
No misc partition
spl: partition error
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK
## Checking uboot 0x00200000 ... sha256(278bbce123...) + OK
## Checking fdt 0x0031f058 ... sha256(a4fd4b8eff...) + OK
## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK
## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 323.167/474.348 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45
NOTICE:  BL31: Built : 10:11:21, Dec 27 2023
INFO:    spec: 0x13
INFO:    code: 0x88
INFO:    ext 32k is valid
INFO:    ddr: stride-en 4CH
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO:    l3 cache partition cfg-0
INFO:    system boots from cpu-hwid-0
INFO:    disable memory repair
INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
ERROR:   dfs get fsp_params[0] error, 0xfead0003 != 0xfead0004
ERROR:   dfs get fsp_params[1] error, 0xa2c != 0xfead0004
ERROR:   dfs get fsp_params[2] error, 0xa34 != 0xfead0004
ERROR:   dfs get fsp_params[3] error, 0xadc != 0xfead0004
ERROR:   loader&trust unmatch!!! Please update loader if need enable dmc
ERROR:   current trust bl31 need match with loader ddr bin V1.13 or newer
ERROR:   current loader need match with trust bl31 V1.38-V1.40
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-armbian (Jun 25 2024 - 01:32:49 +0000)
Model: NanoPi R6S
MPIDR: 0x81000000
PreSerial: 2, raw, 0xfeb50000
DRAM:  8 GiB
Sysmem: init
Relocation Offset: eda3e000
Relocation fdt: eb9f9d20 - eb9fecc8
CR: M/C/I
Using default environment
optee check api revision fail: -1.0
optee api revision is too low
### ERROR ### Please RESET the board ###
Edited by MX Wang
Note that there are no "official" images for this board.  Armbian doesn't support this board.  This board is "Community Maintained".  Which means that someone at some time had it working and submitted it to the armbian build framework and it gets built weekly automatically.  No support or testing is done by Armbian on this.  As long as it builds without error it can exist as a Community Maintained board.  But note that most community maintained boards have no one actively working with them.  Looking at the forum activity on this board, it doesn't seem like much in the last 9 months or so.
