MX Wang Posted July 6 Posted July 6 (edited) I downloaded the image of nanopi R6s from the official website[https://www.armbian.com/nanopi-r6s/](https://www.armbian.com/nanopi-r6s/), but it failed to start no matter burning to sd card or emmc. I know a lot of people have this problem, like this page [https://forum.armbian.com/topic/27904-armbian-images-for-r6s-r6c/?do=findComment&comment=164029](https://forum.armbian.com/topic/27904-armbian-images-for-r6s-r6c/?do=findComment&comment=164029) This is the log printed by the serial port: ``` DDR V1.12 52218f4949 cym 23/07/06-19:46:50 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB Manufacturer ID:0x1 CH0 RX Vref:27.5%, TX Vref:20.8%,19.8% CH1 RX Vref:26.3%, TX Vref:19.8%,20.8% CH2 RX Vref:27.5%, TX Vref:19.8%,19.8% CH3 RX Vref:27.1%, TX Vref:21.8%,21.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-g82417168bf-230508 #root (Sep 08 2023 - 20:53:43) unknown raw ID 0 0 0 unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 No misc partition spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK ## Checking uboot 0x00200000 ... sha256(278bbce123...) + OK ## Checking fdt 0x0031f058 ... sha256(a4fd4b8eff...) + OK ## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK ## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 323.167/474.348 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45 NOTICE: BL31: Built : 10:11:21, Dec 27 2023 INFO: spec: 0x13 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 ERROR: dfs get fsp_params[0] error, 0xfead0003 != 0xfead0004 ERROR: dfs get fsp_params[1] error, 0xa2c != 0xfead0004 ERROR: dfs get fsp_params[2] error, 0xa34 != 0xfead0004 ERROR: dfs get fsp_params[3] error, 0xadc != 0xfead0004 ERROR: loader&trust unmatch!!! Please update loader if need enable dmc ERROR: current trust bl31 need match with loader ddr bin V1.13 or newer ERROR: current loader need match with trust bl31 V1.38-V1.40 INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Jun 25 2024 - 01:32:49 +0000) Model: NanoPi R6S MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 8 GiB Sysmem: init Relocation Offset: eda3e000 Relocation fdt: eb9f9d20 - eb9fecc8 CR: M/C/I Using default environment optee check api revision fail: -1.0 optee api revision is too low ### ERROR ### Please RESET the board ### ``` Edited July 6 by MX Wang 0 Quote
SteeMan Posted July 6 Posted July 6 Note that there are no "official" images for this board. Armbian doesn't support this board. This board is "Community Maintained". Which means that someone at some time had it working and submitted it to the armbian build framework and it gets built weekly automatically. No support or testing is done by Armbian on this. As long as it builds without error it can exist as a Community Maintained board. But note that most community maintained boards have no one actively working with them. Looking at the forum activity on this board, it doesn't seem like much in the last 9 months or so. 0 Quote
ColorfulRhino Posted July 7 Posted July 7 Please check again after this PR has been merged and a new image has been published. You can get the latest images at https://github.com/armbian/os/releases 0 Quote
