I have a 4x20 LCD display (with an HD44780 compatible adaptor) connected to my Banana Pi. It is running (freshly installed, switched from Bananian) on the mainline kernel:
Linux bpi 4.9.7-sunxi #1 SMP Thu Feb 2 01:52:06 CET 2017 armv7l GNU/Linux
However, the display is not recognized. I checked the wire connections multiple times, they're okay and the backlight is on.
So I assume this is a software issue. The output of "i2cdetect -y 1" is:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
which leads me to the consideration that it is not even recognized by the system.
I did the following things - without success:
  • run "apt-get dist-upgrade" (where some 404 errors occured, see this topic for details)
  • installed "i2c-tools" and "python-smbus"
  • loaded "i2c-dev" kernel module
According to the documentation https://docs.armbian.com/Hardware_Allwinner/#connect-your-lcd-display, the I2C stuff should work out of the box in the mainline kernel.
Any help would be appreciated. :)
Best regards and thanks in advance,
Norbert Kahl
Which BananaPi are you using ?
Because maybe you are not looking at the right I2C bus, did you look at other buses ?
On A20_BananaPi, the I2C on the header is /dev/i2c-3 (i2c-1 is the camera).
I am using a "normal" Banana Pi, not a Pro or M2 model.
There are two I2C-busses here:
root@bpi:/dev# ls /dev/i2c-*
/dev/i2c-0  /dev/i2c-1
On the 0-bus, there is "something" detected but I guess it belongs to the system or internal hardware, not to the display:
30: -- -- -- -- UU -- -- -- -- -- -- -- -- -- -- --
The 1-bus is just blank. :(
Yes, I2C-0 has the PMIC attached to it.
Since you don't see the i2c-3, it is probably not enabled in the DT, you will have to tweak it by decompile the DTB, edit it, and recompile it. (Of course, after having done a backup of the previous one)
Sorry for all the rush. It was the length of the cable (> 2 metres) which caused this error, since pull-up resistors and terminators are required at that length. Just another I2C-Newbie... :)
When using jumper wire (~ 20cm), it works, the LCD display appears as 0x27 on I2C-1.
Thanks for all the help!
Best regards,
Norbert Kahl
