jimg Posted July 10, 2024 Posted July 10, 2024 (edited) The build instructions `README` suggest it's possible to build an image using Github actions. So, I created a new repository and created the following file under `.github/workflows/orangepizero3_build.yml` name: Build Orange Pi Zero 3 server image on: workflow_dispatch: jobs: build-armbian: runs-on: ubuntu-latest steps: - uses: armbian/build@main with: armbian_token: "${{ secrets.GITHUB_TOKEN }}" # GitHub token armbian_release: "bookworm" # userspace armbian_target: "build" # build=image, kernel=kernel armbian_board: "orangepizero3" # build target armbian_ui: "server" But when I tried to run this action, I received this error: Error: Could not find file '/home/runner/work/_actions/_temp_52217267-7314-4a20-996d-95b7097793e8/_staging/armbian-build-de030c7/patch/kernel/rockchip-rk3588-collabora/dt/rk3588-nanopc-cm3588-nas.dts'. Am I doing something wrong? Is there some aspect to building an image using Github Actions I'm missing? Edited July 10, 2024 by jimg correct misspelling 0 Quote
MaxT Posted July 18, 2024 Posted July 18, 2024 I second the question- some workflow description for novices would be highly appreciated! 0 Quote
