How to build images using Github Actions?
jimg
The build instructions `README` suggest it's possible to build an image using Github actions.  So, I created a new repository and created the following file under `.github/workflows/orangepizero3_build.yml`
name: Build Orange Pi Zero 3 server image
on:
  workflow_dispatch:
jobs:
  build-armbian:
    runs-on: ubuntu-latest
    steps:
      - uses: armbian/build@main
        with:
          armbian_token: "${{ secrets.GITHUB_TOKEN }}"  # GitHub token
          armbian_release: "bookworm"                        # userspace
          armbian_target: "build"                        # build=image, kernel=kernel
          armbian_board: "orangepizero3"                   # build target
          armbian_ui: "server"
But when I tried to run this action, I received this error:
Error: Could not find file '/home/runner/work/_actions/_temp_52217267-7314-4a20-996d-95b7097793e8/_staging/armbian-build-de030c7/patch/kernel/rockchip-rk3588-collabora/dt/rk3588-nanopc-cm3588-nas.dts'.
Am I doing something wrong?  Is there some aspect to building an image using Github Actions I'm missing?
Edited by jimg
correct misspelling
