Skip to content
View in the app
Armbian Community Forums
  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
Featured Replies
Hi everybody,
I just bought an X96 X6 TV box (8G/64G) to run Home Assistant. However it is not popular so there is no Armina for it. Home Assistant requires Debian 11/12 (linux kernel, no desktop version) to operate. Hope everyone can help me. Thank you very much. I only need 1 file *.img file to install Home Assistant, no need: USB, wifi, Bluetooth... because it can be difficult.
Thank you very much!
I try to run a Armbian server on this nice RK3566 box.
I use the Station M2 image Armbian_community_24.11.0-trunk.167_Station-m2_bookworm_current_6.6.52_minimal.img.xz
with the rk3566-box-demo.dtb dtb and this boots ๐Ÿ™‚
But there is only one of the three USB ports working (the middle one).
Is this the best image to use ?
Is there a dtb more accurate to this box ?
Thanks for any help
Quote
I have extracted the Android dtb but, of course, it doesn't work as is.
Has somebody had full success with this box ?
ย
At least with USB ?
ย
I retrieved the DTB rk3566-box-demo_x96_x6.dtb in the thread dedicated to the H96 Max and... all the USB ports are ok ๐Ÿ™‚
But on the other hand the ethernet port does not work anymore : it is up and the negotiation is done well (1000baseT) but, if what the router emits is well received by the box, the latter does not see what it emits.
Strange: if we start with the dtb rk3566-box-demo.dtb and we restart with rk3566-box-demo_x96_x6.dtb (without power cut) ethernet continues to work!
It is as if an initialization was missing, present in rk3566-box-demo.dtb, absent in rk3566-box-demo_x96_x6.dtb.
I'm trying to find the differences between rk3566-box-demo and rk3566-box-demo_x96_x6 but there are hundreds of them and it's hard to identify the real semantic differences ๐Ÿ˜ž
Any help appreciated...
ย
Kernel log :
Quote
rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
rk_gmac-dwmac fe010000.ethernet: IRQ sfty not found
rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
rk_gmac-dwmac fe010000.ethernet: RX delay(0x2d).
rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
rk_gmac-dwmac fe010000.ethernet: clock input from PHY
rk_gmac-dwmac fe010000.ethernet: init for RGMII
rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
rk_gmac-dwmac fe010000.ethernet: ย  ย  ย  ย DWMAC4/5
rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
rk_gmac-dwmac fe010000.ethernet: TSO supported
rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0
rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
dwmac4: Master AXI performs any burst length
rk_gmac-dwmac fe010000.ethernet end0: No Safety Features support found
rk_gmac-dwmac fe010000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported
rk_gmac-dwmac fe010000.ethernet end0: registered PTP clock
rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii link mode
rk_gmac-dwmac fe010000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx
rk_gmac-dwmac fe010000.ethernet end0: Link is Down
ย
Tx and Rx delay maybe wrong, compare with the android dtb if It worked or change to the box- demo values.
ย
Have you tried the icplus dtb?
ย
Edited by maka
HI,
TX and RX delays are the same between rk3566-box-demo which works and rk3566-box-demo_x96_x6 which don't.
I tried with Androidย  values, slightly different (2b/4b vs 2d/4f), without success.
I tried rk3566-box-demo_x96_ip1001m.dtb with same results : the box receive packets but hers are not received/emitted.
Here are the differences of dwmac logs between rk3566-box-demo_x96_x6 and rk3566-box-demo_x96_ip1001m :
ย
Quote
# diff dwmac-box-demo-x96-x6.txt dwmac-rk3566-box-demo_x96_ip1001m.txt
4c4
< rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
> rk_gmac-dwmac fe010000.ethernet: clock input or output? (output).
8,9c8
< rk_gmac-dwmac fe010000.ethernet: clock input from PHY
< rk_gmac-dwmac fe010000.ethernet: init for RGMII
> rk_gmac-dwmac fe010000.ethernet: init for RGMII_TXID
23c22
< rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
> rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:01] driver [ICPlus IP1001] (irq=POLL)
28c27
< rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii link mode
> rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii-txid link mode
mii-tool box-demo :
ย
Quote
Using SIOCGMIIPHY=0x8947
end0: negotiated 1000baseT-FD flow-control, link ok
ย  registers for MII PHY 1:
ย ย ย  1040 79ad 001c c916 0de1 cde1 006f 0000
ย ย ย  0000 0200 4800 0000 0000 0000 0000 2000
ย ย ย  0000 0000 0000 0000 0000 0400 0f00 0f00
ย ย ย  2118 0863 39ee 0002 0000 0000 0000 0000
ย  product info: vendor 00:e0:4c or 00:07:32, model 17 rev 6
ย  basic mode:ย ย  autonegotiation enabled
ย  basic status: autonegotiation complete, link ok
ย  capabilities: 1000baseT-FD 100baseTx-FD 100baseTx-HD 10baseT-FD 10baseT-HD
ย  advertising:ย  1000baseT-FD 100baseTx-FD 100baseTx-HD 10baseT-FD 10baseT-HD flow-control
ย  link partner: 1000baseT-FD 100baseTx-FD 100baseTx-HD 10baseT-FD 10baseT-HD flow-control
mii-tool box-demo-x96-x6 :
ย
Quote
ย ย ย  1040 79ad 001c c916 0de1 cde1 006d 0000
ย ย ย  0000 0200 0800 0000 0000 0000 0000 2000
ย ย ย  2118 0863 31ee 0002 6295 0000 0000 0000
Only the registers are different.
Interestingly if one connect the box (with box-demo-x96-x6 dtb) on a 100baseT interface, the behavior is the same (one way communication) while the delays are much less important.
What could be missing in the box-demo-x96-x6 dtb to prevent outputย  communication? a power supply ?
ย
Maybe the kernel has made the old dtbs broken. Must be that because rockchip get patches every day.
ย
You have one USB otg. Its not that enough?
Edited by maka
I bought this box because it has an external antenna (good wifi performance), a fast ethernet portย  and 3 USB ports for a SSD, aย  SDR and a monitoring system (without external hub ๐Ÿ˜‰)...
Ethernet works on your X96 X6 box ?
Yes but is ICPLUS chip
ย
You can try this, maybe the chip is awaked
ย
mdio {
ย ย  ย ย ย  ย ย ย  ย compatible = "snps,dwmac-mdio";
ย ย  ย ย ย  ย ย ย  ย #address-cells = < 0x01 >;
ย ย  ย ย ย  ย ย ย  ย #size-cells = < 0x00 >;
ย ย  ย ย ย  ย ย ย  ย ethernet-phy@1 {
ย ย  ย ย ย  ย ย ย  ย ย ย  ย compatible = "ethernet-phy-ieee802.3-c22"; ====> compatible = "ethernet-phy-id001c.c916", "ethernet-phy-ieee802.3-c22";
ย
Edited by maka
ย
mdio {
ย
Thanks for your advice but there is no difference: the box receives packets but don't emit.
The logs are identical as those of box-demo and if we boot with box-demo then reboot (without power off) with box-demo_x96_x6 modified, ethernet continues to work !
It seems box-demo does something, which survives reboot, which is missing in box-demo_x96_x6.
Any idea to find that ?
ย
I'm lucky and you are great !
ethernet works two way now (936 Mbits/sec) ๐Ÿ™‚
what was the trick ?
Now I'll look what is needed for bluetooth and the led display...
Many thanks @maka
For bluetooth it's just a matter of
ย
Quote
< ย ย  ย ย ย  ย ย ย  ย compatible = "brcm,bcm43438-bt";
> ย ย  ย ย ย  ย ย ย  ย compatible = "realtek,rtl8822cs-bt";
ย
ย
Account
Navigation
Search
Search
Chrome (Android)
  2. Tap Permissions โ†’ Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
