Hello everyone, today I would like to show you how to compile Clementine on an Orange Pi PC  (or PC Plus). I'm writing this because I couldn't find anything related to this topic on the internet, so I wrote this not very detailed guide.
Step 1: Install all required dependencies for Clementine
sudo apt-get update
sudo apt-get install liblastfm-dev libtag1-dev gettext libboost-dev \
    libboost-serialization-dev libqt4-dev qt4-dev-tools libqt4-opengl-dev \
    cmake libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev \
    libglew1.5-dev libqjson-dev libgpod-dev libplist-dev \
    libusbmuxd-dev libmtp-dev libcdio-dev \
    protobuf-compiler libprotobuf-dev libcrypto++-dev \
    libfftw3-dev libsparsehash-dev libsqlite3-dev libpulse-dev \
    libqtwebkit-dev libechonest-dev libchromaprint-dev libqca2-dev
Optionally install ccache to speed up the build process (recommended)
sudo apt-get install ccache
Step 2: Get the source files
git clone https://github.com/clementine-player/Clementine.git && cd Clementine
Step 3: Enable temporary swap (for some reason make allways failed without it)
sudo dd if=/dev/zero of=swapfile bs=1M count=1024
sudo mkswap swapfile
sudo swapon swapfile
Step 4: Edit some source files...
Edit the "src/analyzers/analyzerbase.h" file. Find this part and edit it like this:
Before:
#include <QGLWidget>
#ifdef Q_WS_MACX
#include <OpenGL/gl.h>
#include <OpenGL/glu.h>
#else
#include <GL/gl.h>
#include <GL/glu.h>
#endif
After:
#ifdef Q_WS_MACX
#else
#include <GLES2/gl2.h>
#endif
And the "src/visualisations/projectmvisualisation.cpp" file:
Before:
#ifdef Q_OS_MAC
#include "core/mac_startup.h"
#else
#include <GL/gl.h>
#endif
After:
#ifdef Q_OS_MAC
#else
#endif
Step 5: Compiling (this will take a long time)
Go to the bin directory and run the following commands:
cmake ../
sudo make
sudo make install
Step 6: Install Gstreamer plugins (clementine will crash without them)
sudo apt-get install gstreamer1.0-plugins-*
Step 7:  Remove swap
sudo swapoff swapfile
sudo rm swapfile
And that's it! Hope this works for you too.
