I have an Rock64 v2.0 and after update to trunk 24.8.0-trunk.369 to 24.8.0-trunk.399 the OS stop to starting process with this kernel error:
U-Boot 2022.07-armbian (Mar 14 2024 - 00:34:55 +0000)
Model: Pine64 Rock64
DRAM:  4 GiB
PMIC:  RK8050 (on=0x40, off=0x00)
Core:  229 devices, 25 uclasses, devicetree: separate
MMC:   mmc@ff500000: 1, mmc@ff520000: 0
Loading Environment from MMC... Card did not respond to voltage select! : -110
*** Warning - No block device, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   eth0: ethernet@ff540000
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
3920 bytes read in 4 ms (957 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0:1
166 bytes read in 4 ms (40 KiB/s)
18182239 bytes read in 408 ms (42.5 MiB/s)
30030336 bytes read in 671 ms (42.7 MiB/s)
53582 bytes read in 13 ms (3.9 MiB/s)
2825 bytes read in 13 ms (211.9 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
Moving Image from 0x2080000 to 0x2200000, end=3f40000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Data Size:    18182175 Bytes = 17.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to fbdca000, end fcf2101f ... OK
   Loading Device Tree to 00000000fbd54000, end 00000000fbdc9fff ... OK
Starting kernel ...
efi_free_pool: illegal free 0x00000000fbf23040
efi_free_pool: illegal free 0x00000000fbf20040
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.6.39-current-rockchip64 (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PR                                              EEMPT Thu Jul 11 10:49:22 UTC 2024
[    0.000000] Machine model: Pine64 Rock64
[    0.000000] efi: UEFI not found.
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000feffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xfe7b9980-0xfe7bbfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000feffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000feffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000feffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
[    0.000000] cma: Reserved 128 MiB at 0x00000000efc00000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 31 pages/cpu s88296 r8192 d30488 u126976
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: root=UUID=b7daa1a9-9cd9-4cf7-8de6-79f3a229a5cb rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 logleve                                              l=7 ubootpart=a08d4006-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=a08d4006-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
[    0.000000] Policy zone: DMA
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 3MB
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fdd27000-0x00000000fe127000] (4MB)
[    0.000000] Memory: 3912228K/4175872K available (16960K kernel code, 2318K rwdata, 5244K rodata, 4672K init, 604K bss, 132572K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000835] Console: colour dummy device 80x25
[    0.000854] printk: console [tty1] enabled
[    0.001936] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001984] pid_max: default: 32768 minimum: 301
[    0.002127] LSM: initializing lsm=capability,yama,apparmor,integrity
[    0.002199] Yama: becoming mindful.
[    0.002350] AppArmor: AppArmor initialized
[    0.002523] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002580] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005755] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.005952] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.006364] rcu: Hierarchical SRCU implementation.
[    0.006392] rcu:     Max phase no-delay instances is 1000.
[    0.009573] EFI services will not be available.
[    0.010200] smp: Bringing up secondary CPUs ...
[    0.011185] Detected VIPT I-cache on CPU1
[    0.011327] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.012534] Detected VIPT I-cache on CPU2
[    0.012677] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.013799] Detected VIPT I-cache on CPU3
[    0.013940] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.014103] smp: Brought up 1 node, 4 CPUs
[    0.014234] SMP: Total of 4 processors activated.
[    0.014258] CPU features: detected: 32-bit EL0 Support
[    0.014279] CPU features: detected: 32-bit EL1 Support
[    0.014304] CPU features: detected: CRC32 instructions
[    0.014447] CPU: All CPU(s) started at EL2
[    0.014480] alternatives: applying system-wide alternatives
[    0.017940] devtmpfs: initialized
[    0.033786] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.033874] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.039538] pinctrl core: initialized pinctrl subsystem
[    0.040410] DMI not present or invalid.
[    0.041528] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.043945] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.045140] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.046206] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.046352] audit: initializing netlink subsys (disabled)
[    0.046725] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
[    0.047916] thermal_sys: Registered thermal governor 'fair_share'
[    0.047929] thermal_sys: Registered thermal governor 'bang_bang'
[    0.047960] thermal_sys: Registered thermal governor 'step_wise'
[    0.047984] thermal_sys: Registered thermal governor 'user_space'
[    0.048133] cpuidle: using governor menu
[    0.048709] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.048904] ASID allocator initialised with 65536 entries
[    0.050414] Serial: AMBA PL011 UART driver
[    0.061914] platform ff370000.vop: Fixed dependency cycle(s) with /hdmi@ff3c0000
[    0.062087] platform ff3c0000.hdmi: Fixed dependency cycle(s) with /vop@ff370000
[    0.074197] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.074734] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
[    0.075392] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.075851] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
[    0.076551] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.077014] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
[    0.077543] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.077970] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
[    0.082525] Modules: 25280 pages in range for non-PLT usage
[    0.082543] Modules: 516800 pages in range for PLT usage
[    0.083824] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.083887] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.083915] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.083941] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.083967] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.083994] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.084020] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.084045] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.085808] cryptd: max_cpu_qlen set to 1000
[    0.152413] raid6: neonx8   gen()  1067 MB/s
[    0.220525] raid6: neonx4   gen()  1099 MB/s
[    0.288629] raid6: neonx2   gen()  1039 MB/s
[    0.356741] raid6: neonx1   gen()   888 MB/s
[    0.424859] raid6: int64x8  gen()   683 MB/s
[    0.492957] raid6: int64x4  gen()   800 MB/s
[    0.561054] raid6: int64x2  gen()   698 MB/s
[    0.629157] raid6: int64x1  gen()   516 MB/s
[    0.629182] raid6: using algorithm neonx4 gen() 1099 MB/s
[    0.697248] raid6: .... xor() 781 MB/s, rmw enabled
[    0.697275] raid6: using neon recovery algorithm
[    0.698389] iommu: Default domain type: Translated
[    0.698433] iommu: DMA domain TLB invalidation policy: strict mode
[    0.699184] SCSI subsystem initialized
[    0.699916] usbcore: registered new interface driver usbfs
[    0.699999] usbcore: registered new interface driver hub
[    0.700079] usbcore: registered new device driver usb
[    0.700685] pps_core: LinuxPPS API ver. 1 registered
[    0.700713] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.700770] PTP clock support registered
[    0.701024] EDAC MC: Ver: 3.0.0
[    0.701981] scmi_core: SCMI protocol bus registered
[    0.703830] NetLabel: Initializing
[    0.703869] NetLabel:  domain hash size = 128
[    0.703890] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.704022] NetLabel:  unlabeled traffic allowed by default
[    0.704310] vgaarb: loaded
[    0.705173] clocksource: Switched to clocksource arch_sys_counter
[    0.708499] VFS: Disk quotas dquot_6.6.0
[    0.708601] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.709626] AppArmor: AppArmor Filesystem Enabled
[    0.722601] NET: Registered PF_INET protocol family
[    0.722971] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.729115] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.729395] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.729521] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.730191] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.731571] TCP: Hash tables configured (established 32768 bind 32768)
[    0.731809] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.732010] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.732467] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.732550] NET: Registered PF_XDP protocol family
[    0.732590] PCI: CLS 0 bytes, default 64
[    0.732960] Trying to unpack rootfs image as initramfs...
[    0.737530] kvm [1]: IPA Size Limit: 40 bits
[    0.739707] kvm [1]: vgic interrupt IRQ9
[    0.739788] kvm [1]: Hyp mode initialized successfully
[    0.743045] Initialise system trusted keyrings
[    0.743155] Key type blacklist registered
[    0.743544] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    0.743657] zbud: loaded
[    0.744577] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.745289] fuse: init (API version 7.39)
[    0.747697] integrity: Platform Keyring initialized
[    0.805623] jitterentropy: Initialization failed with host not compliant with requirements: 9
[    0.805691] xor: measuring software checksum speed
[    0.813564]    8regs           :  1261 MB/sec
[    0.821435]    32regs          :  1261 MB/sec
[    0.829961]    arm64_neon      :  1162 MB/sec
[    0.829996] xor: using function: 32regs (1261 MB/sec)
[    0.830031] Key type asymmetric registered
[    0.830054] Asymmetric key parser 'x509' registered
[    0.830218] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.830553] io scheduler mq-deadline registered
[    0.830586] io scheduler kyber registered
[    0.830672] io scheduler bfq registered
[    0.840782] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.840842] dma-pl330 ff1f0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.843541] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.850416] printk: console [ttyS2] disabled
[    0.851142] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 21, base_baud = 1500000) is a 16550A
[    0.851281] printk: console [ttyS2] enabled
[    0.953465] Serial: AMBA driver
[    0.957675] rockchip-vop ff370000.vop: Adding to iommu group 2
[    0.975135] loop: module loaded
[    0.981356] spi-nor spi0.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[    0.984299] tun: Universal TUN/TAP device driver, 1.6
[    0.985984] thunder_xcv, ver 1.0
[    0.986374] thunder_bgx, ver 1.0
[    0.986723] nicpf, ver 1.0
[    0.987631] e1000e: Intel(R) PRO/1000 Network Driver
[    0.988097] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.988689] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.989218] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.989789] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.990364] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.991141] sky2: driver version 1.30
[    0.994041] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    0.994949] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    1.008604] dwc2 ff580000.usb: DWC OTG Controller
[    1.009105] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    1.009836] dwc2 ff580000.usb: irq 28, io mem 0xff580000
[    1.010633] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    1.011401] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.012065] usb usb1: Product: DWC OTG Controller
[    1.012503] usb usb1: Manufacturer: Linux 6.6.39-current-rockchip64 dwc2_hsotg
[    1.013218] usb usb1: SerialNumber: ff580000.usb
[    1.014622] hub 1-0:1.0: USB hub found
[    1.015048] hub 1-0:1.0: 1 port detected
[    1.017892] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.018453] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    1.019347] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000008002000010
[    1.019797] ehci-platform ff5c0000.usb: EHCI Host Controller
[    1.019824] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    1.019874] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[    1.020051] ohci-platform ff5d0000.usb: irq 30, io mem 0xff5d0000
[    1.020253] xhci-hcd xhci-hcd.0.auto: irq 27, io mem 0xff600000
[    1.020771] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 4
[    1.021659] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.022275] ehci-platform ff5c0000.usb: irq 29, io mem 0xff5c0000
[    1.022662] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    1.025873] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.026738] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    1.027505] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.028170] usb usb2: Product: xHCI Host Controller
[    1.028621] usb usb2: Manufacturer: Linux 6.6.39-current-rockchip64 xhci-hcd
[    1.029302] usb usb2: SerialNumber: xhci-hcd.0.auto
[    1.030685] hub 2-0:1.0: USB hub found
[    1.031115] hub 2-0:1.0: 1 port detected
[    1.032120] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.033063] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[    1.033861] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.034530] usb usb5: Product: xHCI Host Controller
[    1.034983] usb usb5: Manufacturer: Linux 6.6.39-current-rockchip64 xhci-hcd
[    1.035627] usb usb5: SerialNumber: xhci-hcd.0.auto
[    1.037038] hub 5-0:1.0: USB hub found
[    1.037495] hub 5-0:1.0: 1 port detected
[    1.038649] usbcore: registered new interface driver usb-storage
[    1.041203] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    1.041308] mousedev: PS/2 mouse device common for all mice
[    1.042168] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    1.043060] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.043337] i2c_dev: i2c /dev entries driver
[    1.043729] usb usb4: Product: EHCI Host Controller
[    1.044571] usb usb4: Manufacturer: Linux 6.6.39-current-rockchip64 ehci_hcd
[    1.045263] usb usb4: SerialNumber: ff5c0000.usb
[    1.046748] i2c 1-0018: Fixed dependency cycle(s) with /i2c@ff160000/pmic@18/regulators/DCDC_REG4
[    1.047847] hub 4-0:1.0: USB hub found
[    1.048304] hub 4-0:1.0: 1 port detected
[    1.055997] rk808-regulator rk808-regulator.2.auto: there is no dvs0 gpio
[    1.056671] rk808-regulator rk808-regulator.2.auto: there is no dvs1 gpio
[    1.057327] rk808-regulator rk808-regulator.2.auto: max buck steps per change: 8
[    1.081519] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[    1.082306] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.082973] usb usb3: Product: Generic Platform OHCI controller
[    1.083518] usb usb3: Manufacturer: Linux 6.6.39-current-rockchip64 ohci_hcd
[    1.084162] usb usb3: SerialNumber: ff5d0000.usb
[    1.085746] hub 3-0:1.0: USB hub found
[    1.086125] rk808-rtc rk808-rtc.4.auto: registered as rtc0
[    1.086209] hub 3-0:1.0: 1 port detected
[    1.088464] rk808-rtc rk808-rtc.4.auto: setting system clock to 2016-01-21T08:50:08 UTC (1453366208)
[    1.091461] input: rk805 pwrkey as /devices/platform/ff160000.i2c/i2c-1/1-0018/rk805-pwrkey.6.auto/input/input0
[    1.097547] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
[    1.101755] sdhci: Secure Digital Host Controller Interface driver
[    1.102345] sdhci: Copyright(c) Pierre Ossman
[    1.102804] Synopsys Designware Multimedia Card Interface Driver
[    1.104203] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.105241] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
[    1.105955] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
[    1.106578] dwmmc_rockchip ff520000.mmc: Version ID is 270a
[    1.107167] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 43,32 bit host data width,256 deep fifo
[    1.109379] mmc_host mmc1: card is non-removable.
[    1.110231] ledtrig-cpu: registered to indicate activity on CPUs
[    1.111561] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.112394] hid: raw HID events driver (C) Jiri Kosina
[    1.113029] usbcore: registered new interface driver usbhid
[    1.113587] usbhid: USB HID core driver
[    1.117672] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.120844] drop_monitor: Initializing network drop monitor service
[    1.121412] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.122110] NET: Registered PF_INET6 protocol family
[    2.085361] mmc1: switch to bus width 8 failed
[    2.093072] mmc1: mmc_select_hs200 failed, error -110
[    2.093656] mmc1: error -110 whilst initialising MMC card
[    2.117348] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    2.344406] Freeing initrd memory: 17756K
[    2.412003] Segment Routing with IPv6
[    2.412489] In-situ OAM (IOAM) with IPv6
[    2.412998] NET: Registered PF_PACKET protocol family
[    2.413862] 8021q: 802.1Q VLAN Support v1.8
[    2.414357] Key type dns_resolver registered
[    2.432128] registered taskstats version 1
[    2.432767] Loading compiled-in X.509 certificates
[    2.450926] zswap: loaded using pool zstd/z3fold
[    2.472299] Key type .fscrypt registered
[    2.472691] Key type fscrypt-provisioning registered
[    2.476799] Btrfs loaded, zoned=yes, fsverity=yes
[    2.477509] Key type encrypted registered
[    2.477901] AppArmor: AppArmor sha1 policy hashing enabled
[    2.511378] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffff8000811d64a0)
[    2.512225] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-0v9 not found, using dummy regulator
[    2.513259] dwhdmi-rockchip ff3c0000.hdmi: supply avdd-1v8 not found, using dummy regulator
[    2.514437] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[    2.516473] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.517758] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffff8000811da6a8)
[    2.519710] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[    2.520588] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    2.521437] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    2.523570] WCN: marlin_init entry!
[    2.524419] of_cfs_init
[    2.524419] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
[    2.524462] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
[    2.524703] of_cfs_init: OK
[    2.525350] dwmmc_rockchip ff500000.mmc: Version ID is 270a
[    2.525438] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 50,32 bit host data width,256 deep fifo
[    2.526169] clk: Disabling unused clocks
[    2.537224] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.551678] Freeing unused kernel memory: 4672K
[    2.552307] Run /init as init process
[    3.081702] mmc1: switch to bus width 8 failed
[    3.091425] mmc1: mmc_select_hs200 failed, error -110
[    3.091934] mmc1: error -110 whilst initialising MMC card
[    3.117307] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    3.336405] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
[    3.409089] rk_gmac-dwmac ff540000.ethernet: IRQ eth_wake_irq not found
[    3.409793] rk_gmac-dwmac ff540000.ethernet: IRQ eth_lpi not found
[    3.410514] rk_gmac-dwmac ff540000.ethernet: PTP uses main clock
[    3.411385] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input).
[    3.412040] rk_gmac-dwmac ff540000.ethernet: TX delay(0x24).
[    3.412564] rk_gmac-dwmac ff540000.ethernet: RX delay(0x18).
[    3.413098] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no).
[    3.413766] rk_gmac-dwmac ff540000.ethernet: clock input from PHY
[    3.419358] rk_gmac-dwmac ff540000.ethernet: init for RGMII
[    3.420317] rk_gmac-dwmac ff540000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    3.421011] rk_gmac-dwmac ff540000.ethernet:         DWMAC1000
[    3.421556] rk_gmac-dwmac ff540000.ethernet: DMA HW capability register supported
[    3.422260] rk_gmac-dwmac ff540000.ethernet: RX Checksum Offload Engine supported
[    3.422951] rk_gmac-dwmac ff540000.ethernet: COE Type 2
[    3.423440] rk_gmac-dwmac ff540000.ethernet: Wake-Up On Lan supported
[    3.424165] rk_gmac-dwmac ff540000.ethernet: Normal descriptors
[    3.424729] rk_gmac-dwmac ff540000.ethernet: Ring mode enabled
[    3.425354] rk_gmac-dwmac ff540000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.637295] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    3.638258] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    3.725500] rk_gmac-dwmac ff540000.ethernet end0: renamed from eth0
[    3.887873] async_tx: api initialized (async)
[    4.101386] mmc1: switch to bus width 8 failed
[    4.115376] mmc1: mmc_select_hs200 failed, error -110
[    4.115867] mmc1: error -110 whilst initialising MMC card
[    4.141358] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[    5.189315] mmc1: switch to bus width 8 failed
[    5.216118] mmc1: mmc_select_hs200 failed, error -110
[    5.216625] mmc1: error -110 whilst initialising MMC card
[    5.230517] mmc1: Failed to initialize a non-removable card
[    8.574559] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'hevc', val=0x88220
I try to searchr on web similar problem and I found this 2 threads that try to fix problem:
The problem is an correction to emmc device driver for Rock64. This is the solution: pinctrl: rockchip: correct RK3328 iomux width flag for GPIO2-B pins
@clee Can you add this fix for Rock64? Thanks
Edited by Boia11
