p789 Posted August 1, 2024 Posted August 1, 2024 Hi, I am trying to get a led matrix to work via the SPI interface but cannot get it to work. I have enabled the interface and have an spi-device under /dev and there is a spi-module loaded. I have tried to connect MOSI and MISO to run spidev-test and everything seems to be fine but when I connect the led-matrix simply nothing happens. I can run the example-scripts from the luma-matrix library without getting an error - but there is simply nothing appearing on the matrix - however it does light up when I touch it on the backside... i have tried to use different values for param_spidev_spi_bus and param_spidev_spi_cs in armbianenv.txt but to no avail... Does anybody have an idea what I could try? many thanks! 0 Quote
robertoj Posted August 2, 2024 Posted August 2, 2024 Post the model of the led-matrix and its user manual. Does it give any feedback on the SPI port? Is the example script able to detect errors? Re-check all the cables Try the things tried in these threads: https://forum.armbian.com/topic/29657-orange-pi-zero-2-and-spi-ili9341-touchscreen-fbtft-legacy-kernel-partial-success/#comment-169775 https://forum.armbian.com/topic/41365-orange-pi-zero-2w-overlay-i2c-spi-help/#comment-195256 0 Quote
p789 Posted August 2, 2024 Author Posted August 2, 2024 (edited) Hi, thanks for replying. It is a MAX7219, the manual can be found here: https://cdn.shopify.com/s/files/1/1509/1638/files/AZ039_A_7-13_EN_B07CRF13ZQ_214c9067-2dde-4ce9-9f90-943eb3046e57.pdf?v=1721043187 The module does not show any reaction to scripts that run without errors. The scripts however do report errors when eg I use the wrong device. When I touch the backside of the led-matrix it lights up, so it seems my fingers simulate somehow data incoming that it does not seem to get otherwise. I don't understand the SPI interface very well but could it be that there is something wrong with the cs-signal, so that the pi sends out data but the matrix thinks another slave would be the recipient? Could it be an issue with a device tree overlay? And in armbian-config I have a choice of spidev_0_0, spidev_1_0, spidev_1_1, spidev_1_2 and spi_spidev.... What is here the proper selection? Edited August 2, 2024 by p789 0 Quote
p789 Posted August 5, 2024 Author Posted August 5, 2024 I now have tried the led-matrix with an arduino and it works perfectly. So the problem seems indeed to be on the armbian-side. Any suggestions on how to proceed? 0 Quote
