Panda Posted August 4, 2024 Posted August 4, 2024 (edited) Hello People, I Bring to you the Lemfo HK1 RBOX K8S 4G/64G. This box came with Android 13 and can be rooted easy, follow some specs of the box: Processor: Rockchip RK3528 GPU: Mali 450 Memory: 4Gb (micron) Storage: 64Gb (eMMC 5.1 Samsung) Network: PHY Integrated stmmac-0:02 Driver RK630 100Mbps Wireless: 5G driver: rtl8822cs on gpio Bluetooth: 5.1 USB 3.0: 01 5Gbps USB 2.0: 01 HDMI: 01 TV-Out: 01 Power: 5v 2A Aliexpress link: Lemfo HK1 Rbox K8S What is Working: HDMI: partial (read bellow) Network: partial (read bellow) Bluetooth: no Wifi: no USB 3.0: yes Sound: yes over HDMI Obs: You need to use hinlink-ht2 image, but no wireless, nor ethernet, only HDMI work, and you need to turn on monitor around 15 seconds after turn on the TVBox I get the FDT from Android, and this FDT with hilink-ht2 images boot without HDMI, but with network, if you boot with hinlink-ht2 make the initial configs and start the desktop you can replace the rk-3528-hinlink-ht2.dtb with the android FDT and the box will boot, wait around 30 seconds and turn on the monitor and you have the HDMI and network working. I have build the image with xfce and include some drivers (mail450, RK630, rtl8822cs) and enable some DRM options (under test yet) I Have the Andoid boot partition dump, and other partions, I will share the files later (need some dropbox os gdrive to share) I have attached the Android.DTB and dmesg from android and armbian, if someone want take a look. Any help and sugestion will be great! Some pictures of the board: Lemfo-hk1rbox-k8s.dtb android_dmesg.log linux_dmesg.log linux-syslog Edited August 5, 2024 by Panda 2 Quote
Ioannis Georgantakis Posted August 6, 2024 Posted August 6, 2024 Hello , how we can update the firmware on this unit? 0 Quote
Panda Posted August 6, 2024 Author Posted August 6, 2024 Do you want update android ? or flash Armbian to emmc? I had a small chat with Lemfo and they do not share an Android image to reflash the device. I'm waitting my USB-A Male Male arrive, so I can dump the entire firmware from device, soon I get the dumped firmware I can share. what I have done is dump the emmc using ADB, but I'm not sure if it can be used to flash the device. If you want to try I can share the image. About flashing armbian to EMMC I do not recomend since it's not full working on SD Card yet and you can brick you device. Regards Panda 0 Quote
Panda Posted August 8, 2024 Author Posted August 8, 2024 News from the front... 🙂 HDMI 90% Operational now, Mali with lima drivers working well, now the Frame Buffer is working, so you can turn your monitor 10 seconds after the box. IR remote controller working (Unbelievable, but it's true) I'm struggling to make Wifi and bluetooth work, bluetooth is detected and appear on rfkill, but when you try to enable rfkill unblock and the interface disappear until your block again on rfkill, but cannot be enabled, any suggestion? Wifi is detected but rfkill not bring the device up, I get the erro -237 when iw try to set powermanagent on wireless-platdata. (No ideas of how to procced) What is making me crazy is the need to power the monitor 10 seconds of the box. I search over the internet, and try to change the eid on armbianArgs.txt, try to set framebuffer to 1024x768, but nothing work. Any advice? I will continue to poke the kernel and the dtb to try to solve the issues, so if someone can share some ideas or docs, please, this will help a lot. Regards Panda 0 Quote
Hacktarus13 Posted August 21, 2024 Posted August 21, 2024 Hi Panda, Any news ? And there is an "opensource" device which use RK3528, the Radxa Rock 2F Regards 0 Quote
Panda Posted August 22, 2024 Author Posted August 22, 2024 @Hacktarus13 I'm Currently travelling without access to the box, I'm returning next week, so I will start to it poke again. About the "opensource", I believe it's not opensource once the RK3528 was developed only for TvBox, even in the Rockchip site you didn't found any information about the processor or any board. I only found information in 2 sites about a press release of RK3528 where they say it's for TvBox, Even the Chinese have issues with the RK3528 for a lack of information. Best Regards Panda 0 Quote
Hqnicolas Posted August 22, 2024 Posted August 22, 2024 On 8/21/2024 at 5:25 AM, Hacktarus13 said: And there is an "opensource" device which use RK3528, the Radxa Rock 2F You can use the Radxa Rock 2F as a base, remove all USB ports from DTS/DTB by commenting the code inside DTS text remove wifi/bluetooth by commenting the code inside DTS text check for the EMMC0 EMMC1 EMMC2 SDHCI device boot position compile the armbian for Radxa Rock 2F and test it 0 Quote
Panda Posted September 3, 2024 Author Posted September 3, 2024 I'm returning from my travel, and start to poke again the board, and I'm very disappointed, my first objective is to use the box like a ThinClient, I have a big server at home with several VM. But after putting armbian running OK in the box the connection is very very very slow, I start to think it's an armbian problem, so, I return to Android and make some tests, and is even worse. It is impossible to use? No it is not, but you have several Lag for pointer and keyboard the image is OK no lag at all using 1920x1080, with 4k we have several image lagging. I'm using Ethernet, if I use wifi it's impossible to use, many lag in Android. So SAD, my plan will not gonna work, but I will keep poking the board just for fun. What is working: HDMI with sound (4k and bellow) Remote Controller Ethernet The clock (more or less) GPU What is not working: When you boot there is no image you need turn on the monitor in the exact moment or connect over network and restart X Some GPIO power (I see some errors in DMESG) WIFI (I believe is missing firmware or GPIO power) Bluetooth (detected, but when you try to enable disappear, RFKILL put in locked state) I don't know how to share my progress using github ( I only use git clone, I'm not a programmer), if someone share some documents or give some directions I can share without problem. I want to try to write armbian to emmc, I have the USB cable, but I don't know how to backup the android to restore in case of failure (and be sure, it will failure) Any help are welcome. Regards Panda 0 Quote
sicxnull Posted September 3, 2024 Posted September 3, 2024 4 hours ago, Panda said: I want to try to write armbian to emmc, I have the USB cable, but I don't know how to backup the android to restore in case of failure (and be sure, it will failure) FYI flashing to EMMC causes a u-boot loop that's impossible to break out of. i was lucky enough to find an android image that works and flashed it back with AndroidTool to get the box working again. Not sure if it's expecting a specific partition structure or what. I did not go too far into it. I built an image with rk3528-evb3-lp4x-v10.dtb that seemed to work somewhat. 0 Quote
Energokom Posted September 21, 2024 Posted September 21, 2024 On 9/3/2024 at 8:50 PM, Panda said: What is working: HDMI with sound (4k and bellow) Remote Controller Ethernet The clock (more or less) GPU You can upload your dts or img? 0 Quote
DreamDreams Posted November 4, 2024 Posted November 4, 2024 I have a working setup that you don't have to write image to emmc. As long as you have a working uboot you can boot your box. It relies on a server that hosts kernel and initrd through HTTP. And host roofs through nbd/squashfs. I will post my solution shortly. 0 Quote
DreamDreams Posted November 4, 2024 Posted November 4, 2024 Here is what you need to do: Chain from uboot to GRUB, so that you can download kernel and initrd through HTTP. If you are OK with tftp speed, you can skip this. Create a file called minimal-grub.cfg insmod efinet insmod net net_bootp configfile (http,192.168.60.118)/grub/grub.cfg Generate grub image grub-mkimage -D rk3399-firefly.dtb -o grubnet.efi -O arm64-efi -p /boot/grub --config=./minimal-grub.cfg tftp http efinet normal configfile linux video video_fb video_colors videoinfo all_video help archelp terminal terminfo gettext gfxmenu gfxterm_background gfxterm_menu gfxterm net boot reboot part_gpt part_msdos ext2 msdospart load grub from u-boot bootcmd=load mmc 0:1 ${kernel_addr_r} grub/grubnet.efi; bootefi ${kernel_addr_r} Host your grub.cfg at http://192.168.60.118/grub/grub.cfg. Modify IP address according to your setup. Don't forget to change minimal-grub.cfg file. My grub.cfg looks like this set menu_visible=false set timeout=0 set kern_param='ip=dhcp console=tty0 console=ttyS2,1500000 no_console_suspend consoleblank=0 net.ifnames=0 plymouth.ignore-serial-consoles nbd_server=192.168.60.118' set default='KDE Live' insmod http menuentry 'KDE' { linux (http,$server_ip)/firefly/vmlinuz-6.11.5-edge-rockchip64 boot=squashfs root=kde $kern_param devicetree (http,$server_ip)/firefly/rk.dtb } Run your nbd server, my looks like this [generic] group = nbd includedir = /etc/nbd-server/conf.d allowlist = true [kde.squashfs] exportname = /nas/pve/armbian/squash/kde.squashfs name = armbian_fs readonly = true cow = true chunksize = 128M maxconnections = 100 [kde.overlay] exportname = /nas/pve/armbian/squash/kde.overlay readonly = false chunksize = 128M maxconnections = 100 Prepare your squashfs image and overlay image. Squashfs image is your normal rootfs, you can even copy it from say Ubuntu liveCD iso. Overlay image is an empty ext4 image. I create it like this dd if=/dev/zero of=kde.overlay bs=4M count=0 seek=1000 mkfs.ext4 kde.overlay chmod oa+w kde.overlay mkdir rw mount kde.overlay rw/ mkdir rw/work rw/upper umount rw Now you are all set. My own testing shows it's faster than NFS root. I can see KDE programs launch faster with my naked eyes. 0 Quote
DreamDreams Posted November 4, 2024 Posted November 4, 2024 (edited) The initrd script is here: https://gist.github.com/awsong/bf8e054105899cb30a09b2151f722935 Copy it to /etc/initramfs-tools/scripts/ and regenerate your initrd. File name needs to be 'squashfs' to match kernel command line. Edited November 4, 2024 by DreamDreams 0 Quote
leXia Posted November 23 Posted November 23 I purchased the device after reading your thread and am currently porting it to my hardware with Copilot (Claude Sonnet 4.5). You can refer to my work results in the repository below. So far, the following parts have been confirmed to work: HDMI (no need to reconnect after Linux kernel boot) Ethernet Built-in eMMC Currently working on: Wi-Fi / Bluetooth (in my case, the model uses AIC8800D80) Not yet verified: GPU Install to eMMC As suggested in your thread, I based my work on the Hinlink HT2 and Radxa Rock 2F, using the DTB extracted from my device’s firmware and processing it with Copilot. I’d appreciate it if you could take a look if you’re interested. IMG_1597.HEIC https://github.com/wwwhana/armbian-build 0 Quote
leXia Posted November 30 Posted November 30 I have verified that Wi-Fi is working, and I have also figured out how to install to eMMC. However, after running armbian-install, the system only boots if I put MiniLoaderAll.bin into the firmware field of the “Upgrade Firmware” session in Rockchip-AndroidTool while the device is in Maskrom mode, and then press the Upgrade button. MiniLoaderAll.bin It appears to be an SPI-related issue, but at the moment I don’t see any way to resolve it. I am also having difficulty getting Bluetooth to work. If you have any information on this, your assistance would be appreciated. 0 Quote
WINEDS Posted November 30 Posted November 30 (edited) As the wifi device is the same please see my last post in this thread : Viz : Also to fix BT : sudo crontab -e then add the line : @reboot sudo hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep It could also be your dtb though. You could decompile my dtb from this thread and use the Bluetooth related section. Edited November 30 by WINEDS 0 Quote
leXia Posted December 13 Posted December 13 After installing the firmware shown in the link and requesting modifications by decompiling your dtb, there's been some progress, but it's still not working yet. However, I'm hopeful that with a little more effort, it should work. 1 Quote
leXia Posted December 13 Posted December 13 For this device, ttyS2 is used for BT, but the problem was that the system was trying to use it for logging. After modifying that part in boot.cmd and rebooting, the firmware came up. 1 Quote
