Hey! i've been browsing and reading this thread for the past couple of days but i cant seem to find any version3 images. if i try to boot from sdcard, most of the times the led stays red, or turns blue but doesnt give any picture. Can i get some help with this?
Hi @sicxnull, @Nick A
thank you very much for your support. Probably last night I was very confused when I wrote my post. Of course the v5.1 updated will be nice to have but looking better I can say to you and to @ventara that the armbian image suggested from Nick to Trauma (https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop.img.xz) works fine on X96Q vs 5.1 only things the led in front remain always red and that why I was thinking it doesn't boot. Ethernet port works but wifi doesn't work. Never mind ethernet is enough. On the other side when I compare the two release (sicxnull and Nick) I didn't realize that I copy two times the same image on two different sd (I was really too tired) so don't consider the indication that I give you apart the wifi chip. That is right!
@sicxnullI was curious if you would be able to make an image for v1.1 boards? I ask because v1.3 doesnt work for these older 1.1 boards and I am not as skilled as you at making images haha
Posted (edited)
Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img
This works for my 1.1 board :)
Edited by Sponzo
Unfortunately i do not have this board to compile/test on
Posted (edited)
@djoness
I have burned the image "Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz" using Balena Etcher to an SD card, then put it in the box and the light is blue, but the screen is black. and lan just blinks, ip address not detected. please help me, thank you
this is a photo of the board I used
Edited by ajwan
hello, i need some help with this box, i have tried a lot of image but only stayed red light or just blue light and shown nothing, my version using ddr3
Posted (edited)
Hi everyone
I Have an different Version of this Clones.
The Cpu is has an weird printing. It has S905W engraved but DeviceInfoHW shows an CortexA53. Maybe an H313?
Version 1.4
Not booting from SD Card from many Version of armbian tested with an genue Sandisk 16gb.
Serial Output on normal Android boot:
Spoiler
GXLX2:BL1:3cfee7:42a5ae;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 113598
BL2 Built : 17:21:16, Mar 19 2021.
gxl g767b31d - longyong.chen@droid02-sz
Board ID = 7, adc=578
set vcck to 1070 mv
set vddee to 1070 mv
CPU clk: 1200MHz
LPDDR3
LPDDR3 chl: Rank0+1 @ 720MHz - FAIL
LPDDR3 chl: Rank0 @ 720MHz
bist_test rank: 0 30 12 4f 3f 20 5f 31 11 52 3b 19 5d 38 1c 55 3b 1c 5b 34 10 59                                             3c 18 61 598   - PASS
Rank0: 1024MB(auto)-2T-3
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x013c0000, size: 0x00007600
Load bl301 from eMMC, src: 0x00018200, des: 0x01380000, size: 0x00002400
Load bl31 from eMMC, src: 0x0001c200, des: 0x10100000, size: 0x00019600
Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x0004da00
NOTICE:  BL3-1: v1.0(debug):98abdeb4b
NOTICE:  BL3-1: Built : 13:55:40, Oct 30 2020
NOTICE:  BL31: GXL normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: gxl_v1.1.3103-923400455-dirty 2020-12-28 18:42:52 xingyu.chen@droid12-sz                                            ]
efuse init ops = c5
efuse init hdcp = c, cf9=7
x2_hp_e = 0
bl30: check_permit, count is 1
bl30: check_permit: ok!
chipid: 0 0 3 c c 0 8f b3 a8 a0 0 c5 not ES chip
[0.710060 Inits done]
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g0d95d91cc4-dirty (Feb 21 2023 - 16:35:00), Build: jenkins-S905L3                                            -default-359
DRAM:  1 GiB
Relocation Offset is: 36edf000
gpio: pin GPIODV_25 (gpio 44) value is 1
register usb cfg[0][1] = 0000000037f5d370
[CANVAS]canvas init
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
MMC:   aml_priv->desc_buf = 0x0000000033ecfac0
aml_priv->desc_buf = 0x0000000033ed1de0
SDIO Port B: 0, SDIO Port 😄 1
emmc/sd response timeout, cmd8, status=0x3ff2800
emmc/sd response timeout, cmd55, status=0x3ff2800
init_part() 293: PART_TYPE_AML
[mmc_init] mmc init success
dtb magic 00088b1f
      Amlogic multi-dtb tool
      GZIP format, decompress...
      Multi dtb detected
      2layers board, board id use 7
      Multi dtb tool version: v2 .
      Support 6 dtbs.
        aml_dt soc: gxlx2 platform: p291 variant: 1g
        dtb 0 soc: gxlx2   plat: p291   vari: 1g
        dtb 1 soc: gxlx2   plat: p291   vari: 2g
        dtb 2 soc: gxlx2   plat: p291   vari: 3g
        dtb 3 soc: gxlx2   plat: p295   vari: 1g
        dtb 4 soc: gxlx2   plat: p295   vari: 2g
        dtb 5 soc: gxlx2   plat: p295   vari: 3g
      Find match dtb: 0
start dts,buffer=0000000033ed4610,dt_addr=0000000033ed4610
      Single dtb detected
parts: 17
00:      logo   0000000000800000 1
01:  recovery   0000000001800000 1
02:      misc   0000000000800000 1
03:      dtbo   0000000000800000 1
04:  cri_data   0000000000800000 2
05:     param   0000000001000000 2
06:      boot   0000000001000000 1
07:       rsv   0000000001000000 1
08:  metadata   0000000001000000 1
09:    vbmeta   0000000000200000 1
10:       tee   0000000002000000 1
11:    vendor   0000000014000000 1
12:       odm   0000000008000000 1
13:    system   0000000080000000 1
14:   product   0000000008000000 1
15:     cache   0000000040000000 2
16:      data   ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
check pattern success
mmc env offset: 0x47400000
In:    serial
Out:   serial
Err:   serial
board id is : 7
hpd_state=0
do_hpd_detect: hdmimode=1080p60hz
do_hpd_detect: colorattribute=444,8bit
cvbs performance type = 7, table = 2
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-924: calc f46d4e8, store f46d4e8
dtb_read()-1046: total valid 2
dtb_read()-1113: do nothing
      Multi dtb detected
      Support 6 dtbs.
      Find match dtb: 0
Net:   eth_initialize:396 dwmac.c9410000 idx:0
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
wipe_data=successful
wipe_cache=successful
ext4logoLoadCmd=ext4load mmc 1:${logoPart} ${logoLoadAddr} ${ext4LogoPath}
4147272 bytes read in 121 ms (32.7 MiB/s)
[imgread]load bmp from ext4 part okay
bmp pixel: 16
[OSD]load fb addr from dts
[OSD]fb_addr for logo: 0x3f800000
[CANVAS]addr=0x3f800000 width=3840, height=2160
[OSD]ERR: 16 bit/pixel mode2, but BMP has 16 bit/pixel
upgrade_step=2
amlkey_init() 70: already init!
[BL31]: tee size: 0
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[cmei] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[authkey] not programed yet
syntax error
Hit any key to stop autoboot:  0
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
Kernel command line: androidboot.dtbo_idx=0 buildvariant=userdebug
      Single dtb detected
load dtb from 0x1000000 ......
   Loading Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x01a03670
   Loading Ramdisk to 09e93000, end 09fff172 ... OK
   Loading Device Tree to 0000000009e81000, end 0000000009e92698 ... OK
fdt_instaboot: get header err
Starting kernel ...
uboot time: 2026952 us
get_dvfs_info 0007
[    0.000000@0]        07400000 - 07500000,     1024 KB, ramoops@0x07400000
[    0.000000@0]        10000000 - 10400000,     4096 KB, linux,secmon
[    0.000000@0]        3f800000 - 40000000,     8192 KB, linux,meson-fb
[    0.000000@0]        2b400000 - 30000000,    77824 KB, linux,ion-dev
[    0.000000@0]        1b000000 - 2b400000,   266240 KB, linux,codec_mm_cma
[    0.000000@0]        3f800000 - 3f800000,        0 KB, linux,codec_mm_reserve                                            d
[    0.000000@0]        19c00000 - 1b000000,    20480 KB, linux,vdin1_cma
Have somebody an idea what iam missing ?
The Rkdumper tool will not find this device.
Thanks
Edited by kingbecher
Hi, can anyone help me with my board, I tried all 4 images from the github releases for the x96q, flashing them into sd card on windows using belenaetcher, then pluging into the box and booting it, it gets stuck at red light, the moment I eject the sd card it boots into android.
am I doing something wrong or I need a specific image?
WhatsAppImage2026-01-27at8_49_06PM.thumb.jpeg.b69bb4bf30d241e6af5e7a1c8797598f.jpegWhatsAppImage2026-01-27at8_49.06PM(1).thumb.jpeg.ea3c57648cf0e9b984727cecf404105d.jpegWhatsAppImage2026-01-27at8_49_01PM.thumb.jpeg.2ee3b4a1e82250fa365a38d92ec4ab34.jpeg
Hi there this is not an x96 but a 'Q10 android TV' the mb looks the same as x96 i have tried some miniarch and your armbians versions (thanks for sharing) but nothing works, anyone can identificate if this mb is compatible ? There is no information about this exact model since it looks very recent.
thanks in advance
@Nick A
Could you create a current version image? I’ve tested all the images I could find, and only yours runs perfectly.
Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_server.img.xz
However, since this is an "edge" build, it doesn’t include MT7601U wifi card support, while the current version does. I tried compiling it myself, but ran into many errors and couldn’t complete the build.
If you could create a "current" branch image, that would be ideal. Thanks in advance!
@Kevin suIf the build error was due to a base files installation error, rerun the build with the same options. It should complete the image compilation. I haven't found a proper fix yet, but rerunning the build should resolve it.
I'll update the server image soon.
Posted (edited)
@210518-nick-a
Thanks for the reply. I don’t have enough Linux knowledge, so should I just wait for your new release?
My box isn’t an X96Q — it’s a generic no-name one — but after trying many, many images, I found that the version you compiled happens to work perfectly and runs smoothly. So far I haven’t found any issues (the only thing missing is Wi-Fi, but that’s not a problem with your build: SV6256P). Even other images made for X96Q LPDDR3 by different people have all kinds of problems.
Another small issue:
your current compilation option is fully preemptive scheduling. This option is not suitable for server use. I suggest changing it to voluntary preemption or non-preemptive, thank you.
The option of your images:
CONFIG_PREEMPT_BUILD=y
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
# CONFIG_PREEMPT_RT is not set
CONFIG_PREEMPT_COUNT=y
CONFIG_PREEMPTION=y
# CONFIG_PREEMPT_DYNAMIC is not set
# CONFIG_SCHED_CORE is not set
# CONFIG_SCHED_CLASS_EXT is not set
Edited by Kevin su
