@Nick A TY very much for your reply, I've managed to create my first build but I am a bit confused because it made an IMG with a FAT32 boot partition, is it right or did I miss something?
On 11/18/2025 at 11:38 AM, Nick A said:
 Hello i hope everone is good, i have this X96Q with motherboard reference BA301_141 V4.1 20244 and after trying this image Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz led turned blue but nothing on screen when i tried to connect uart to read data, for some reason it did boot and work but when i turned off and turn on the device this time with lan attached it didnt want to boot again only blue led, this remember me of miniarch image i have to turn on and off de device like 15 to 20 times for the image to boot, this is what happen with this Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz maybe because you use miniarch patches, but i found other images that works so good at first time here is the images that works on this device and i hope this might help fix this boot problem with armbian image
https://github.com/velvet-os/imagebuilder/releases/tag/230910-02
and this
https://mega.nz/file/DBUHiZRZ#F_wx89EJ9i4LvCsO2VrTYglx5SrfQGrLxs_DLr6mTUo
Hello, i've just tried https://github.com/velvet-os/imagebuilder/releases/tag/230910-02 image, and boots perfectly from sd card in my x96q tv box, allwinner h313 v4.0, is the only image that worked... i've tried them all....my question is how to install it on the internal memory of the box? i've tried from the terminal with root access, but when i hit cd /root/ and ls, nothing happens.... if anybody can give any ideas i will appreciate it... thanks in advance.
