GoldenBIOS Posted January 11 Posted January 11 Hey! i've been browsing and reading this thread for the past couple of days but i cant seem to find any version3 images. if i try to boot from sdcard, most of the times the led stays red, or turns blue but doesnt give any picture. Can i get some help with this? 0 Quote
Maurizio Finesso Posted January 11 Posted January 11 Hi @sicxnull, @Nick A thank you very much for your support. Probably last night I was very confused when I wrote my post. Of course the v5.1 updated will be nice to have but looking better I can say to you and to @ventara that the armbian image suggested from Nick to Trauma (https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop.img.xz) works fine on X96Q vs 5.1 only things the led in front remain always red and that why I was thinking it doesn't boot. Ethernet port works but wifi doesn't work. Never mind ethernet is enough. On the other side when I compare the two release (sicxnull and Nick) I didn't realize that I copy two times the same image on two different sd (I was really too tired) so don't consider the indication that I give you apart the wifi chip. That is right! 0 Quote
saf7001 Posted January 15 Posted January 15 @sicxnullI was curious if you would be able to make an image for v1.1 boards? I ask because v1.3 doesnt work for these older 1.1 boards and I am not as skilled as you at making images haha 0 Quote
Sponzo Posted January 15 Posted January 15 (edited) Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img This works for my 1.1 board Edited January 15 by Sponzo 0 Quote
sicxnull Posted January 16 Author Posted January 16 9 hours ago, saf7001 said: @sicxnullI was curious if you would be able to make an image for v1.1 boards? I ask because v1.3 doesnt work for these older 1.1 boards and I am not as skilled as you at making images haha Unfortunately i do not have this board to compile/test on 0 Quote
ajwan Posted January 19 Posted January 19 (edited) @djoness I have burned the image "Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz" using Balena Etcher to an SD card, then put it in the box and the light is blue, but the screen is black. and lan just blinks, ip address not detected. please help me, thank you this is a photo of the board I used Edited January 19 by ajwan 0 Quote
huengwibf Posted January 23 Posted January 23 hello, i need some help with this box, i have tried a lot of image but only stayed red light or just blue light and shown nothing, my version using ddr3 0 Quote
Maurizio Finesso Posted January 25 Posted January 25 I would like to say thank you very much to @sicxnull for the latest images of X96Q V5.1. They work really well and allow me to install HA as well as use it like a PC. You really did a great job! 1 Quote
kingbecher Posted January 25 Posted January 25 (edited) Hi everyone I Have an different Version of this Clones. The Cpu is has an weird printing. It has S905W engraved but DeviceInfoHW shows an CortexA53. Maybe an H313? Version 1.4 Not booting from SD Card from many Version of armbian tested with an genue Sandisk 16gb. Serial Output on normal Android boot: Spoiler GXLX2:BL1:3cfee7:42a5ae;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 113598 BL2 Built : 17:21:16, Mar 19 2021. gxl g767b31d - longyong.chen@droid02-sz Board ID = 7, adc=578 set vcck to 1070 mv set vddee to 1070 mv CPU clk: 1200MHz LPDDR3 LPDDR3 chl: Rank0+1 @ 720MHz - FAIL LPDDR3 chl: Rank0 @ 720MHz bist_test rank: 0 30 12 4f 3f 20 5f 31 11 52 3b 19 5d 38 1c 55 3b 1c 5b 34 10 59 3c 18 61 598 - PASS Rank0: 1024MB(auto)-2T-3 AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x013c0000, size: 0x00007600 Load bl301 from eMMC, src: 0x00018200, des: 0x01380000, size: 0x00002400 Load bl31 from eMMC, src: 0x0001c200, des: 0x10100000, size: 0x00019600 Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x0004da00 NOTICE: BL3-1: v1.0(debug):98abdeb4b NOTICE: BL3-1: Built : 13:55:40, Oct 30 2020 NOTICE: BL31: GXL normal boot! NOTICE: BL31: BL33 decompress pass [Image: gxl_v1.1.3103-923400455-dirty 2020-12-28 18:42:52 xingyu.chen@droid12-sz ] efuse init ops = c5 efuse init hdcp = c, cf9=7 x2_hp_e = 0 bl30: check_permit, count is 1 bl30: check_permit: ok! chipid: 0 0 3 c c 0 8f b3 a8 a0 0 c5 not ES chip [0.710060 Inits done] INFO: BL3-1: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader ERROR: Error initializing runtime service opteed_fast INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01-g0d95d91cc4-dirty (Feb 21 2023 - 16:35:00), Build: jenkins-S905L3 -default-359 DRAM: 1 GiB Relocation Offset is: 36edf000 gpio: pin GPIODV_25 (gpio 44) value is 1 register usb cfg[0][1] = 0000000037f5d370 [CANVAS]canvas init vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: clk_level = 7 vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300) vpp: vpp_init MMC: aml_priv->desc_buf = 0x0000000033ecfac0 aml_priv->desc_buf = 0x0000000033ed1de0 SDIO Port B: 0, SDIO Port 😄 1 emmc/sd response timeout, cmd8, status=0x3ff2800 emmc/sd response timeout, cmd55, status=0x3ff2800 init_part() 293: PART_TYPE_AML [mmc_init] mmc init success dtb magic 00088b1f Amlogic multi-dtb tool GZIP format, decompress... Multi dtb detected 2layers board, board id use 7 Multi dtb tool version: v2 . Support 6 dtbs. aml_dt soc: gxlx2 platform: p291 variant: 1g dtb 0 soc: gxlx2 plat: p291 vari: 1g dtb 1 soc: gxlx2 plat: p291 vari: 2g dtb 2 soc: gxlx2 plat: p291 vari: 3g dtb 3 soc: gxlx2 plat: p295 vari: 1g dtb 4 soc: gxlx2 plat: p295 vari: 2g dtb 5 soc: gxlx2 plat: p295 vari: 3g Find match dtb: 0 start dts,buffer=0000000033ed4610,dt_addr=0000000033ed4610 Amlogic multi-dtb tool Single dtb detected parts: 17 00: logo 0000000000800000 1 01: recovery 0000000001800000 1 02: misc 0000000000800000 1 03: dtbo 0000000000800000 1 04: cri_data 0000000000800000 2 05: param 0000000001000000 2 06: boot 0000000001000000 1 07: rsv 0000000001000000 1 08: metadata 0000000001000000 1 09: vbmeta 0000000000200000 1 10: tee 0000000002000000 1 11: vendor 0000000014000000 1 12: odm 0000000008000000 1 13: system 0000000080000000 1 14: product 0000000008000000 1 15: cache 0000000040000000 2 16: data ffffffffffffffff 4 init_part() 293: PART_TYPE_AML eMMC/TSD partition table have been checked OK! check pattern success mmc env offset: 0x47400000 In: serial Out: serial Err: serial board id is : 7 hpd_state=0 do_hpd_detect: hdmimode=1080p60hz do_hpd_detect: colorattribute=444,8bit cvbs performance type = 7, table = 2 [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-924: calc f46d4e8, store f46d4e8 _verify_dtb_checksum()-924: calc f46d4e8, store f46d4e8 dtb_read()-1046: total valid 2 dtb_read()-1113: do nothing Amlogic multi-dtb tool GZIP format, decompress... Multi dtb detected 2layers board, board id use 7 Multi dtb tool version: v2 . Support 6 dtbs. aml_dt soc: gxlx2 platform: p291 variant: 1g dtb 0 soc: gxlx2 plat: p291 vari: 1g dtb 1 soc: gxlx2 plat: p291 vari: 2g dtb 2 soc: gxlx2 plat: p291 vari: 3g dtb 3 soc: gxlx2 plat: p295 vari: 1g dtb 4 soc: gxlx2 plat: p295 vari: 2g dtb 5 soc: gxlx2 plat: p295 vari: 3g Find match dtb: 0 Net: eth_initialize:396 dwmac.c9410000 idx:0 amlkey_init() enter! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 wipe_data=successful wipe_cache=successful ext4logoLoadCmd=ext4load mmc 1:${logoPart} ${logoLoadAddr} ${ext4LogoPath} 4147272 bytes read in 121 ms (32.7 MiB/s) [imgread]load bmp from ext4 part okay bmp pixel: 16 [OSD]load fb addr from dts [OSD]fb_addr for logo: 0x3f800000 [OSD]load fb addr from dts [OSD]fb_addr for logo: 0x3f800000 [CANVAS]addr=0x3f800000 width=3840, height=2160 [OSD]ERR: 16 bit/pixel mode2, but BMP has 16 bit/pixel upgrade_step=2 amlkey_init() enter! amlkey_init() 70: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[cmei] not programed yet [KM]Error:f[key_manage_query_size]L507:key[authkey] not programed yet syntax error Hit any key to stop autoboot: 0 ee_gate_off ... ## Booting Android Image at 0x01080000 ... Kernel command line: androidboot.dtbo_idx=0 buildvariant=userdebug Amlogic multi-dtb tool Single dtb detected load dtb from 0x1000000 ...... Loading Kernel Image ... OK kernel loaded at 0x01080000, end = 0x01a03670 Loading Ramdisk to 09e93000, end 09fff172 ... OK Loading Device Tree to 0000000009e81000, end 0000000009e92698 ... OK fdt_instaboot: get header err Starting kernel ... uboot time: 2026952 us get_dvfs_info 0007 [ 0.000000@0] 07400000 - 07500000, 1024 KB, ramoops@0x07400000 [ 0.000000@0] 10000000 - 10400000, 4096 KB, linux,secmon [ 0.000000@0] 3f800000 - 40000000, 8192 KB, linux,meson-fb [ 0.000000@0] 2b400000 - 30000000, 77824 KB, linux,ion-dev [ 0.000000@0] 1b000000 - 2b400000, 266240 KB, linux,codec_mm_cma [ 0.000000@0] 3f800000 - 3f800000, 0 KB, linux,codec_mm_reserve d [ 0.000000@0] 19c00000 - 1b000000, 20480 KB, linux,vdin1_cma Have somebody an idea what iam missing ? The Rkdumper tool will not find this device. Thanks Edited January 25 by kingbecher 0 Quote
SteeMan Posted January 25 Posted January 25 @kingbecher Why do you believe this isn't an Amlogic s905w? Those cpus are also cortex-a53. I see Amlogic references throughout the boot log you posted 1 Quote
kingbecher Posted January 26 Posted January 26 Ok then i will try with S905W images. Does these boot of an sd card like on the H313 ones ? 0 Quote
SteeMan Posted January 26 Posted January 26 @kingbecher This is now off topic for this thread, but you need to look at: https://www.armbian.com/amlogic-s9xx-tv-box 1 Quote
Kunshakolime Posted January 27 Posted January 27 Hi, can anyone help me with my board, I tried all 4 images from the github releases for the x96q, flashing them into sd card on windows using belenaetcher, then pluging into the box and booting it, it gets stuck at red light, the moment I eject the sd card it boots into android. am I doing something wrong or I need a specific image? 0 Quote
Andrés Pérez Domínguez x Posted January 27 Posted January 27 Hi there this is not an x96 but a 'Q10 android TV' the mb looks the same as x96 i have tried some miniarch and your armbians versions (thanks for sharing) but nothing works, anyone can identificate if this mb is compatible ? There is no information about this exact model since it looks very recent. thanks in advance 0 Quote
Nick A Posted January 28 Posted January 28 (edited) @Andrés Pérez Domínguez x your board has the UART pins clearly marked on the board. https://linux-sunxi.org/UART Install this to get more u-boot/kernel debug information. I use a CP2102. Edited January 28 by Nick A 0 Quote
sicxnull Posted January 30 Author Posted January 30 Ordered 2 more X96Qs off aliexpress. will see what versions i get. Will build images for them if they're different. 1 Quote
Kevin su Posted February 4 Posted February 4 @Nick A Could you create a current version image? I’ve tested all the images I could find, and only yours runs perfectly. Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_server.img.xz However, since this is an "edge" build, it doesn’t include MT7601U wifi card support, while the current version does. I tried compiling it myself, but ran into many errors and couldn’t complete the build. If you could create a "current" branch image, that would be ideal. Thanks in advance! 0 Quote
Nick A Posted February 4 Posted February 4 @Kevin suIf the build error was due to a base files installation error, rerun the build with the same options. It should complete the image compilation. I haven't found a proper fix yet, but rerunning the build should resolve it. I'll update the server image soon. 0 Quote
Kevin su Posted February 4 Posted February 4 (edited) @Nick A Thanks for the reply. I don’t have enough Linux knowledge, so should I just wait for your new release? My box isn’t an X96Q — it’s a generic no-name one — but after trying many, many images, I found that the version you compiled happens to work perfectly and runs smoothly. So far I haven’t found any issues (the only thing missing is Wi-Fi, but that’s not a problem with your build: SV6256P). Even other images made for X96Q LPDDR3 by different people have all kinds of problems. Another small issue: your current compilation option is fully preemptive scheduling. This option is not suitable for server use. I suggest changing it to voluntary preemption or non-preemptive, thank you. The option of your images: CONFIG_PREEMPT_BUILD=y # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y # CONFIG_PREEMPT_RT is not set CONFIG_PREEMPT_COUNT=y CONFIG_PREEMPTION=y # CONFIG_PREEMPT_DYNAMIC is not set # CONFIG_SCHED_CORE is not set # CONFIG_SCHED_CLASS_EXT is not set Edited February 4 by Kevin su 0 Quote
Nick A Posted February 5 Posted February 5 @Kevin su I wouldn’t call fully preemptive scheduling “not suitable” for server use, especially on ARM SBCs. On modern kernels, CONFIG_PREEMPT=y has low overhead and is widely used by Armbian even for headless/server images. For a purely headless system under sustained, throughput-focused load, CONFIG_PREEMPT_VOLUNTARY can be a reasonable alternative, but the difference is usually small. It’s more a tuning preference than a correctness issue. 0 Quote
Kevin su Posted February 5 Posted February 5 @Nick A I agree with your point — for modern SBCs, the difference is probably not that significant, and it’s more of a psychological feeling. However, it would be even better if the new version could switch to CONFIG_PREEMPT_VOLUNTARY. 0 Quote
Nick A Posted February 5 Posted February 5 (edited) @Kevin su Armbian uses one kernel config for both server and desktop images. You could compile your own server image and enable this option. I can help you with build errors. SBCs often have relatively weak single-core performance compared to x86 servers. Full preemption prevents a single long-running kernel task from causing noticeable "stutter" in network responses or shell interaction. Edited February 5 by Nick A 0 Quote
Kevin su Posted February 5 Posted February 5 (edited) @Nick A Thank you for your excellent work! I managed to compile it myself and shared it with someone who has the same board (IK316-EMCP_V1.0). Spoiler 1. Changed kernel preemption mode from full preemption to voluntary preemption. 2. Added MediaTek Wi-Fi drivers (MT7601U etc). 3. Embedded kernel headers. https://github.com/cdhigh/armbian_build/releases/tag/v20250306 Edited February 5 by Kevin su 0 Quote
Morales Morales Posted March 9 Posted March 9 Hi, sorry to interrupt, but could you tell me how to do hardware acceleration? I have an Allwinner H313 v5.1 0 Quote
User8675309 Posted Friday at 07:23 PM Posted Friday at 07:23 PM (edited) Did anyone ever get anything to work on a x96q v4.1? If so, what was it and where can i get it? Edited Friday at 07:25 PM by User8675309 0 Quote
