Hello, to all OrangePI PC enthusiasts.
Well I'm in the community of those who definitely underestimated the Orange of the PI, but let me share my burden :-) for the fun of it.
It started with the camera- gc2035 and vfe_v4l2 modules. Had to try a couple of images until I got it by luck I guess - after that I found out that every image I use is not capable of having a FTDI device connected to "ANY" USB Port (OK, you got me, I didn't try the microUSB and I won't). After that I tried no matter what I wanted to connect to  USB it was not even recognized.
Now I'm back in changing/swapping around Images until I found one that let me plug anything I want into the USB Ports and it worked (It was Ubuntu xenial5.25), but in exhange for that I could not ever get the camera working again. OK-> now I start compiling with the instructions from igors github page https://github.com/armbian/build and I couldn't compile a single one ???
Now I'm into the vagrant approach, still doing something while typing here, let's see.
My question here is to be precise and focused on the topic:
Is there an image out there which has both? The Cam and the USB working together or is it bound to some exclusivity?
If yes where can I find it, or what do I have to do it to make it?
all the best
Arminator
OK, now I got it all sorted out:
1.) Igors documentation on compilation through vagrant is flawless and works like a charm -> produced an image of Armbian for OrangePi PC which booted and recognized all USB Devices 3.4.113-sunxi8    O<-check OK
2.) I loaded gc2035 for the camera -> checked dmesg O<-check OK
3.) I loaded vfe_v4l2 to get video0 device -> checked dmesg:
[   77.209552] [ISP] isp platform_id = 5!
[   77.278122] [CSI_ERR][GC2035]sensor_read err at sensor_detect!
[   77.278139] [CSI_ERR][GC2035]chip found is not an target chip.
4.) I tried to unload the vfe_v4l2 module with sudo modprobe -r vfe_v4l2 and catastrophic things happen :-|
[   95.722735] [VFE_ERR]vfe dphy clock is null
[   95.722804] Unable to handle kernel NULL pointer dereference at virtual address 00000034
[   95.732513] pgd = ee0bc000
[   95.735739] [00000034] *pgd=00000000
[   95.740078] sunxi oops: enable sdcard JTAG interface
[   95.745982] sunxi oops: cpu frequency: 480 MHz
[   95.750041] sunxi oops: ddr frequency: 624 MHz
[   95.750041] sunxi oops: gpu frequency: 105 MHz
[   95.750041] sunxi oops: cpu temperature: 35
[   95.750041] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[   95.750041] Modules linked in: vfe_v4l2(-) videobuf_dma_contig videobuf_core gc2035 vfe_subdev cci vfe_os ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sanyo_decoder ir_sony_decoder ir_jvc_decoder ir_rc6_decoder ir_rc5_decoder ir_nec_decoder sunxi_cir rc_core ftdi_sio usbserial pcf8591 bmp085 8189es btrfs [last unloaded: scsi_wait_scan]
[   95.750041] CPU: 2    Not tainted  (3.4.113-sun8i #4)
[   95.750041] PC is at vfe_remove+0x2e4/0x354 [vfe_v4l2]
[   95.750041] LR is at free_irq+0x70/0x78
[   95.750041] pc : [<bf2bd1cc>]    lr : [<c00a42f8>]    psr: 80000013
[   95.750041] sp : ee03be18  ip : ee03bdf8  fp : ee03be34
[   95.750041] r10: 00000000  r9 : ee03a000  r8 : c000e1c8
[   95.750041] r7 : ed8c0b1c  r6 : 00000001  r5 : bf261d2c  r4 : ed8c0000
[   95.750041] r3 : 00000000  r2 : 00000008  r1 : ed8c001c  r0 : bf2fef7a
[   95.750041] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   95.750041] Control: 10c5387d  Table: 6e0bc06a  DAC: 00000015
[   95.750041] LR: 0xc00a4278:
[   95.750041] 4278  e1a00004 ebffff74 e89da830 c07a943c e1a0c00d e92dd8f0 e24cb004 e52de004
[   95.750041] 4298  e8bd4000 e1a06000 e1a07001 ebfffbc5 e2505000 089da8f0 e5953034 e2134802
[   95.750041] 42b8  0a000003 e3a01e51 e59f0034 ebfe154b e89da8f0 e5953068 e3530000 0a000003
[   95.750041] 42d8  e3001514 e59f0018 ebfe1544 e5854068 e1a01007 e1a00006 ebffff57 eb01bcdc
[   95.750041] 42f8  e89da8f0 c07a943c e1a0c00d e92ddbf0 e24cb004 e24dd008 e52de004 e8bd4000
[   95.750041] 4318  e1a06000 e1a08001 ebfffba6 e1a0300d e3c33d7f e3c3303f e5933004 e3c3333e
[   95.750041] 4338  e3c330ff e3530000 e1a04000 0a000004 e1a03006 e59f20cc e30015e2 e59f00c8
[   95.750041] 4358  ebfe1502 e3540000 01a00004 0a00002b e2847058 e1a00007 eb15e5b3 e5945030
[   95.750041] SP: 0xee03bd98:
[   95.750041] bd98  c0929900 00000074 c0929958 ed8c0000 ee03bdcc c00a4218 bf2bd1cc 80000013
[   95.750041] bdb8  ffffffff ee03be04 ee03be34 ee03bdd0 c000dad8 c0008370 bf2fef7a ed8c001c
[   95.750041] bdd8  00000008 00000000 ed8c0000 bf261d2c 00000001 ed8c0b1c c000e1c8 ee03a000
[   95.750041] bdf8  00000000 ee03be34 ee03bdf8 ee03be18 c00a42f8 bf2bd1cc 80000013 ffffffff
[   95.750041] be18  bf32a350 bf32a68c c096ef60 00000800 ee03be44 ee03be38 c03b98a0 bf2bcef4
[   95.750041] be38  ee03be5c ee03be48 c03b7fb0 c03b9888 bf32a384 bf32a350 ee03be74 ee03be60
[   95.750041] be58  c03b801c c03b7f30 bf32a350 ef0dfaf4 ee03be94 ee03be78 c03b79bc c03b7ffc
[   95.750041] be78  bf32a350 bf32a348 c096ede0 00000800 ee03beb4 ee03be98 c03b5688 c03b78f0
[   95.750041] IP: 0xee03bd78:
[   95.750041] bd78  ee03bd94 ee03bd88 c061da5c c00a3d00 ee03bdcc ee03bd98 c00a3d00 c061d340
[   95.750041] FP: 0xee03bdb4:
[   95.750041] bdb4  80000013 ffffffff ee03be04 ee03be34 ee03bdd0 c000dad8 c0008370 bf2fef7a
[   95.750041] bdd4  ed8c001c 00000008 00000000 ed8c0000 bf261d2c 00000001 ed8c0b1c c000e1c8
[   95.750041] bdf4  ee03a000 00000000 ee03be34 ee03bdf8 ee03be18 c00a42f8 bf2bd1cc 80000013
[   95.750041] be14  ffffffff bf32a350 bf32a68c c096ef60 00000800 ee03be44 ee03be38 c03b98a0
[   95.750041] be34  bf2bcef4 ee03be5c ee03be48 c03b7fb0 c03b9888 bf32a384 bf32a350 ee03be74
[   95.750041] be54  ee03be60 c03b801c c03b7f30 bf32a350 ef0dfaf4 ee03be94 ee03be78 c03b79bc
[   95.750041] be74  c03b7ffc bf32a350 bf32a348 c096ede0 00000800 ee03beb4 ee03be98 c03b5688
[   95.750041] be94  c03b78f0 00000000 bf32a348 ee03a000 00000800 ee03bed4 ee03beb8 c03b9f10
[   95.750041] R1: 0xed8bff9c:
[   95.750041] ff9c  d0bbd0ba d0b2d0b0 d088d1b8 450a2eb8 6e657478 5f646564 63736564 74706972
[   95.750041] ffbc  2d6e6f69 752e6973 382d6674 b6e0203a b6b6e094 20a7b6e0 e0bab6e0 b7e0adb6
[   95.750041] ffdc  bbb6e094 e094b7e0 b7e0b4b6 80b7e094 e0bbb6e0 b7e094b7 b6e02080 8fb7e0a2
[   95.750041] fffc  e0adb6e0 00000000 00000000 00000000 ed8c000c ed8c000c 00000000 00000000
[   95.750041] 001c  786e7573 66765f69 75732065 5f69786e 2e656676 00000030 00000000 00000000
[   95.750041] 003c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000001
[   95.750041] 005c  00000000 00000000 ed8c0064 ed8c0064 00000000 00000001 00000000 eeb781c0
[   95.750041] 007c  00000000 00000000 00000000 00000000 bf32a348 00000000 00000000 00000000
[   95.750041] R4: 0xed8bff80:
[   95.750041] ff80  b5d0bfd0 b5d080d1 b8d087d1 bbd081d1 bdd0b5d0 8bd1bdd0 d020b5d0 d0bbd0ba
[   95.750041] ffa0  d0b2d0b0 d088d1b8 450a2eb8 6e657478 5f646564 63736564 74706972 2d6e6f69
[   95.750041] ffc0  752e6973 382d6674 b6e0203a b6b6e094 20a7b6e0 e0bab6e0 b7e0adb6 bbb6e094
[   95.750041] ffe0  e094b7e0 b7e0b4b6 80b7e094 e0bbb6e0 b7e094b7 b6e02080 8fb7e0a2 e0adb6e0
[   95.750041] 0000  00000000 00000000 00000000 ed8c000c ed8c000c 00000000 00000000 786e7573
[   95.750041] 0020  66765f69 75732065 5f69786e 2e656676 00000030 00000000 00000000 00000000
[   95.750041] 0040  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[   95.750041] 0060  00000000 ed8c0064 ed8c0064 00000000 00000001 00000000 eeb781c0 00000000
[   95.750041] R7: 0xed8c0a9c:
[   95.750041] 0a9c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] 0abc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] 0adc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] 0afc  00000000 00000000 00000000 000000ff 00000000 00000000 00000000 00000000
[   95.750041] 0b1c  ed8c0504 ed8c0810 30326367 00003533 00000000 00000000 00000000 003c0000
[   95.750041] 0b3c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] 0b5c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] 0b7c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] R8: 0xc000e148:
[   95.750041] e148  e3570f5f e24fef7d 3798f107 e28d1008 e3a08000 e357080f e2270000 2a0012e0
[   95.750041] e168  ea00f49a e24ee004 e58de03c eaffff79 e1a02007 e28d1008 e3a00000 eb000ab3
[   95.750041] e188  e28fe014 e1a07000 e28d1008 e3570f5f 3891000f 3798f107 eaffffec e5ad0008
[   95.750041] e1a8  e1a02007 e1a0100d e3a00001 eb000aa7 eaffff80 e320f000 c0949d84 c000e87c
[   95.750041] e1c8  c003d38c c002e73c c000e7e0 c011f2dc c011f354 c011e424 c011d364 c004b3d8
[   95.750041] e1e8  c011e46c c012d64c c012d40c c000e7f0 c011dd80 c004b3d8 c012d290 c011e004
[   95.750041] e208  c007c468 c004b3d8 c004b3d8 c011eb4c c00393dc c013c554 c004b3d8 c007c550
[   95.750041] e228  c007c9b8 c004b3d8 c0035a2c c004b3d8 c004b3d8 c003e5c4 c004b3d8 c004b3d8
[   95.750041] R9: 0xee039f80:
[   95.750041] 9f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] 9fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] 9fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] 9fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] a000  00000000 00000002 00000000 ed88adc0 c094b3c0 00000002 00000015 c13ee780
[   95.750041] a020  ed88adc0 ee03a000 ef0bac40 19499f8f eeb0e200 00000000 ee03be3c ee03bda0
[   95.750041] a040  c061c3a4 00000000 00000000 00000000 00000000 00000000 01000000 00000000
[   95.750041] a060  b6f97850 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   95.750041] Process modprobe (pid: 1033, stack limit = 0xee03a2f8)
[   95.750041] Stack: (0xee03be18 to 0xee03c000)
[   95.750041] be00:                                                       bf32a350 bf32a68c
[   95.750041] be20: c096ef60 00000800 ee03be44 ee03be38 c03b98a0 bf2bcef4 ee03be5c ee03be48
[   95.750041] be40: c03b7fb0 c03b9888 bf32a384 bf32a350 ee03be74 ee03be60 c03b801c c03b7f30
[   95.750041] be60: bf32a350 ef0dfaf4 ee03be94 ee03be78 c03b79bc c03b7ffc bf32a350 bf32a348
[   95.750041] be80: c096ede0 00000800 ee03beb4 ee03be98 c03b5688 c03b78f0 00000000 bf32a348
[   95.750041] bea0: ee03a000 00000800 ee03bed4 ee03beb8 c03b9f10 c03b5574 bf32a348 00000001
[   95.750041] bec0: ee03a000 00000800 ee03beec ee03bed8 c03b9f60 c03b9ef4 bf261d2c 00000001
[   95.750041] bee0: ee03bf34 ee03bef0 bf2bd2c4 c03b9f50 ee03bf14 30697363 00000000 00000000
[   95.750041] bf00: 00000000 00000001 00000000 00000000 00000000 00000000 ee03a000 bf33884c
[   95.750041] bf20: 00000000 ee03a000 ee03bfa4 ee03bf38 c007fab0 bf2bd248 c011ee98 00000000
[   95.750041] bf40: bf33884c 00000800 ee03bf3c 5f656676 326c3476 00000000 ee03bf84 ee03bf68
[   95.750041] bf60: c011d358 c011ff70 00000003 ef032680 ef0326c0 ee0376c0 ee03bfa4 ee03bf88
[   95.750041] bf80: c011d420 0011d2e4 b8803318 b8803318 00000001 00000081 00000000 ee03bfa8
[   95.750041] bfa0: c000df60 c007f910 b8803318 b8803318 b880334c 00000800 5c1d5300 00000000
[   95.750041] bfc0: b8803318 b8803318 00000001 00000081 00000000 00000001 b8803318 bee19814
[   95.750041] bfe0: b6ef4521 bee1843c b6f85613 b6ef4526 80000030 b880334c 6f77d821 6f77dc21
[   95.750041] [<bf2bd1cc>] (vfe_remove+0x2e4/0x354 [vfe_v4l2]) from [<c03b98a0>] (platform_drv_remove+0x24/0x28)
[   95.750041] [<c03b98a0>] (platform_drv_remove+0x24/0x28) from [<c03b7fb0>] (__device_release_driver+0x8c/0xcc)
[   95.750041] [<c03b7fb0>] (__device_release_driver+0x8c/0xcc) from [<c03b801c>] (device_release_driver+0x2c/0x38)
[   95.750041] [<c03b801c>] (device_release_driver+0x2c/0x38) from [<c03b79bc>] (bus_remove_device+0xd8/0xe8)
[   95.750041] [<c03b79bc>] (bus_remove_device+0xd8/0xe8) from [<c03b5688>] (device_del+0x120/0x184)
[   95.750041] [<c03b5688>] (device_del+0x120/0x184) from [<c03b9f10>] (platform_device_del+0x28/0x5c)
[   95.750041] [<c03b9f10>] (platform_device_del+0x28/0x5c) from [<c03b9f60>] (platform_device_unregister+0x1c/0x28)
[   95.750041] [<c03b9f60>] (platform_device_unregister+0x1c/0x28) from [<bf2bd2c4>] (vfe_exit+0x88/0x174 [vfe_v4l2])
[   95.750041] [<bf2bd2c4>] (vfe_exit+0x88/0x174 [vfe_v4l2]) from [<c007fab0>] (sys_delete_module+0x1ac/0x24c)
[   95.750041] [<c007fab0>] (sys_delete_module+0x1ac/0x24c) from [<c000df60>] (ret_fast_syscall+0x0/0x30)
[   95.750041] Code: eb379c31 e594313c e284101c e59f0064 (e5932034)
[   98.166123] ---[ end trace 34bfe80aad4e40a5 ]---
What can I do that the camera will work? is there a way since if I use the image of OrangePi Community -> same Distro Jessie8 the USB devices will not work at all so is it not possible to marry both distributions to one functioning both devices?
Unfortunately I have not much kernel experience, but if somebody could tell what to do I can gain experience and will try to acomplish that.
all the best from the
Armbinator
