geraldine adi Posted August 20, 2024 Posted August 20, 2024 (edited) i have buy cheap tv box tripsky mini q3, i have look on recovery is based a95x_r2 and have this specs : and i search on google for dtb is in here : https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/amlogic/meson-gxlx-s905l-p271.dts i don't know how to port this, because i don't have any experience for porting this support, any support on this ? Edited August 21, 2024 by geraldine adi I have solve it and i need to change the topic title for others 0 Quote
Werner Posted August 20, 2024 Posted August 20, 2024 3 hours ago, geraldine adi said: buy cheap tv box https://docs.armbian.com/User-Guide_FAQ/#i-have-a-tv-box-or-tablet-from-insert-random-vendor-can-i-use-armbian-on-it 0 Quote
geraldine adi Posted August 21, 2024 Author Posted August 21, 2024 (edited) SOLVED !! I have try using dtb for p281 and it's work right now, i search on google that p271 architecture is same with p281 Download armbian s9xx on here I have use dtb file name is meson-gxl-s905w-p281.dtb on /dtb/amlogic By following this step : Now it's work now Thanks to armbian team and community !! Edited August 21, 2024 by geraldine adi typo dts to dtb 1 Quote
akabulous Posted September 26, 2024 Posted September 26, 2024 I recently bought the exact same board, down to the date printed on the front. I'm including a photo I took of the back before soldering a UART module, a step I only took because so far nothing has worked. You're the only person on any forum with the same device who had success in getting this device to come alive. 0 Quote
geraldine adi Posted March 27, 2025 Author Posted March 27, 2025 @akabulous did you check your board architecture using AIDA and already make sure your board is p271 with Amlogic S905l ? let me know what are your's tv box model ? 0 Quote
