vovolixo Posted June 2, 2017 Posted June 2, 2017 I received today my BPI M2+, however, I cannot make it boot. I tried both Diet Pi and Armbian Server. No boot. The red LED is on all the time. I'm using a Samsung EVO 32 GB SD card flashed with Etcher on Ubuntu. My power supply is a 5v 3A barrel connector. Since the usual suspects are not the cause, I have no idea what might be going wrong.
Naguissa Posted June 2, 2017 Posted June 2, 2017 Try pushing power and reset buttons.Check power supply, a common problem.Try other SD card, with less capacity if can be.Enviado desde mi Jolla mediante Tapatalk
vovolixo Posted June 2, 2017 Author Posted June 2, 2017 Lukasz helped me on facebook. Turns out that powering up through micro USB solved the problem, have no idea why though.
Tido Posted June 2, 2017 Posted June 2, 2017 16 hours ago, vovolixo said: barrel connector And does it now also run when you power it through the barrel connector?
