Emil Gruia Posted August 25 Posted August 25 Armbianmonitor: https://paste.armbian.com/zitowuviyu Hello ! I've bought a Orange Pi 5 PRO board about 2 months ago . I've tryed all images (Linux and Android) from the official Orange Pi site . Later I tryed Armbian . In the end I've concluded that the best choice is Armbian 24.5.2 Noble Gnome ( Armbian_24.5.2_Orangepi5pro_noble_vendor_6.1.43_gnome-oibaf_desktop.img ). Using Armbian 24.5.2 Noble Gnome I got the best (the smoothest) video playback, both in video players and online (youtube) content . And it' s very responsive in operation, generally . I have one single issue : My MCE remote is not detected properly - the Play, Pause, Next, Previous, Forward, Rewind buttons did't perform any actions when I used Kodi video player . When I press any of these buttons I get a 🚫 (no entry) sign on the bottom of the screen . Only the following buttons are performing correctly : Power, Ok, Left, Right, Up, Down, back, and numeric keys . If I'm using other video players, like Celluloid, Vlc,Haruna, Smplayer, all the remote control's buttons performs as it should . The remote control's model number is HP TSGH-2401 with RF USB dongle . I tryed the remote and Kodi on different Linux images, even on Armbian_24.5.2_Orangepi5pro_noble_vendor_6.1.43_xfce-oibaf_desktop.img - it perform as it should, but all these Linux images have video playback issues (or maybe i'm too picky) . The problem with the remote control is present only on Armbian 24.5.2 Noble Gnome (which I preffered for it's video performance) . I tryed to fix the problem using inputlirc package, but with limited success . I also tried "Keymap editor " add-on for Kodi, but with almost none positive results . I attached 2 screenshoots with the the screen when I get a 🚫 (no entry) sign on the bottom of the screen . Please help me with some suggestions . Thank you in advance ! 0 Quote
Dantes Posted August 29 Posted August 29 Enable logging and check for hardware keys with $ tail -f ~/.kodi/temp/kodi.log then start pressing keys to see which ones are working. Those are the only ones you can work with. 0 Quote
Solution Emil Gruia Posted October 15 Author Solution Posted October 15 I solved the problem by installing KDE Plasma desktop environment with Wayland . This solved all the problems with the MCE remote . Consider this topic solved and please close it . 0 Quote
Thomas Whitecotton Posted October 19 Posted October 19 @Emil Gruia Are you running Armbian 24.5.2 Noble with KDE Plasma, and have the MCE remote fully working now? 0 Quote
Tony3 Posted October 20 Posted October 20 I am using my mobile and Yatze app. Works great with Wayland and ubuntu. If mouse needed I also use KDE connect app on my phone. 0 Quote
