robertoj Posted November 4, 2024 Author Posted November 4, 2024 If anyone needs h264 acceleration in opiz3, it is possible quickly with a version of Armbian from mid 2024, as shown in this thread: https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/?do=findComment&comment=205516 (in opi zero, h264 is already possible with official debian debs) There are a few suggestions to make it work in the latest Armbian... I am bumping this thread because I have limited time with my opiz3, but you may be able to do it (and share). More references of success: https://forum.armbian.com/topic/31848-cant-use-ffmpeg-hardware-accelration-v4l2-orange-pi-4-lts/?do=findComment&comment=175688 ^ Actually, if you see that link, you will see a way to compile your own Armbian image, with some linux patches that allow ffmpeg-v4l2request do its work. 0 Quote
robertoj Posted November 11, 2024 Author Posted November 11, 2024 Success story for h264 hardware acceleration, thanks to Jock, NickA and Armbian https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/?do=findComment&comment=205855 0 Quote
RimYT Posted February 4 Posted February 4 i tried your dts for opiz2w, and thank you, its helped me! but i have two problems: first - screen size is not 320x240 for my system (somewhere the line is being moved, although there is still space further on the screen, and the beginning of the line vertically is not at the very top of the screen, but in the middle), and second - bgr... i tried bgr = <0> and bgr = <1> and rgb = <0> etc... do you know, how to fix at least one of it? 0 Quote
RimYT Posted February 4 Posted February 4 oke, i found out, that system defines display in 240x320 mode, but i need 320x240, idk i tried to change height and weight values in dts 0 Quote
robertoj Posted February 4 Author Posted February 4 I can't understand your situation can yoiu send a photo of the LCD, the kernel version, and do some of the tests that I wrote in this thread? Start with the DTS here: https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-205335 The bgr and rgb parameters are among the last things to fix (applies to only some LCD drivers)... do you even get a picture in the LCD with wrong colors? 0 Quote
robertoj Posted May 13 Author Posted May 13 Is anyone using the orange pi zero LTS or 3, with any ilitek LCD, with spi-gpio driver? I had my LTS working with ili9341 and spi-gpio last year... but the touch is not working now... I think I changed the wiring or the DTS in the running system but I can't tell. 0 Quote
robertoj Posted June 14 Author Posted June 14 (edited) I was having some trouble with newer ili9488 LCD v2.1, and I didn't have ili9488 LCD v1.1, so I decided to experiment again with ili9341 LCD v1.2. I found that this DTS https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-204672 Doesn't work with the touch chip. By accident, I ran the ili9488 driver on this ili9341, and I saw garbled graphics... but the good news: touch was working. Something in the ili9488 DTS which doesn't work for the ili9488 LCD, works for ili9341. I found the difference was not in the ads7846 section, but in the spi speed for the ili9xxx part. I switched back to the ili9341 DTS (with adafruit driver), but changed the SPI speed from 24MHZ to 40MHz.... then the ili9341 DTS was working with graphics and touch again ALTHOUGH the graphics have some flashing pseudo-colors in some places. Maybe the 40MHZ is too much, but I re-gained touch in ili9341 LCD v1.1. I will keep doing experiments. Playing with the SPI Mhz didn't help with the ili9488 Edited June 15 by robertoj 0 Quote
Minh Tiến Nguyễn Posted June 16 Posted June 16 Hello @robertoj I think i have the same problem with @RimYT above about wrong color with ili9486, i'm using screen MPI3501 which is clone screen of waveshare tft35 I apply the same device tree and guide in https://github.com/dev-null2019/orangepizero2w35tft. The screen work but i wrong color, it seem revered Red. —> blue Green —> red Blue. —> green I also write detail in here I know my problem not totally related to your topic, but can you suggest me what i should to check more 0 Quote
Minh Tiến Nguyễn Posted June 16 Posted June 16 About wrong color i think the driver cause it. Driver for render image in this kernel sunxi is ili9486drmtft. I get right color in raspberry pi 4 but raspberry pi 4 use fb_ili9486. On this orangepi zero 2 w, i try 3 different OS but still get same wrong color after adding dts for ili9486 1. Orangepi OS Kernel 6.1 2. Armbian OS Kernel 6.1 3. Debian Bookworm 12 Kernel 6.1 All using ili9486drmtft and get wrong color I also try to change bgr value in dts, but it only create change in .../spi@1.0.../bgr not the color on screen I try to get source code https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-6.1-sun50iw9 to change the bgr field in driver, but i can't insmod the module i build. It say invalid symbol I see someone comment that after kenel 5.4 in repo sunxi remove fbtft_device, so we can't add the fb_ili9486 . The Offical OS supported by Orangepi has Kernel 5.4 Debian, i use it, but after add overlays and reboot, it seem wrong setup, ethernet not working, and i don't know why. 0 Quote
Jeffrey Posted Saturday at 02:15 PM Posted Saturday at 02:15 PM Does this still work with current armbian version? I am using v25.11.2 for Orange Pi Zero3 running Armbian Linux 6.12.58-current-sunxi64 and I can't even get the display to turn on. Now I'll admit I am a complete noob when it comes to linux so I am most likely doing something wrong. I know am doing something that's way over my head but I enjoy researching and learning things but it's hard to find things on the subject. I am using the DTS from this comment: - copied it into ~ili9341 then did: - cd ili9341 armbian-add-overlay ili9341-spi1-opiz3.dts I rebooted and notice the screen didn't come on, so I did: dmesg and then following message came up: sun6i-spi 5011000.spi: cannot register SPI host It's a cheap ili9341 tft from aliexpress, it says it's using ST7789V for display drivers, is that maybe why it isn't working? driver ili9341.ko does show up in /lib/modules/6.12.58-current-sunxi64/kernel/drivers/gpu/drm/tiny any help would be appreciated. 0 Quote
Jeffrey Posted Sunday at 04:24 PM Posted Sunday at 04:24 PM (edited) Well I got it to display something, it isn't exactly what I want but I am just happy I got it to do something. I decided to try with the orangepi image from their website "Orangepizero3_1.0.2_ubuntu_jammy_desktop_xfce_linux6.1.31.img". I was going to share image from what it's displaying but for some reason I keep getting an error trying to upload. Basically it's showing the orangepi boot logo but then all messed up, it's all over the place. ------ edit got image to upload. ------ Edited Sunday at 04:50 PM by Jeffrey 0 Quote
robertoj Posted yesterday at 05:40 PM Author Posted yesterday at 05:40 PM That photo tells me that you have the SPI and GPIO configuration right. Keep that. The completed solution for orange pi zero 3 and ili9341 is: https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#comment-204672 Copy the parts within the ili9341:ili9341@0 {} section, while keeping your gpio 0 Quote
Jeffrey Posted 1 hour ago Posted 1 hour ago @robertoj Thank you for being willing to help. It was actually because my jumper wires were too long. I now can see the everything fine on the screen. The only issue that remains is loading the desktop environment, I can't seem to get in nomatter what I try. I've tried multiple image but every single time it just fails. Any ideas?or is there an image available that is known to work that I can download? 0 Quote
robertoj Posted 17 minutes ago Author Posted 17 minutes ago Jeffrey, Is your DTS using this in the "compatible" line: adafruit,yx240qv29 ? Are you trying to use an X11 or Wayland greeter and desktop? (I can't remember what commands to use to check that right now). I didn't know about X11 problems with adafruit,yx240qv29 (only with the other driver panel-mipi-dbi) There's no available image to download with all the required parts. 0 Quote
