I have an orange pi zero3 with 2gb of ram. Ive installed the current
6.18.43 armbian debian build. It booted fine from SD and I then flashed the boot rom to the eeprom so I could boot from USB (sudo flashcp /usr/lib/linux-u-boot-current-orangepizero3/u-boot-sunxi-with-spl.bin /dev/mtd0)
I was able to boot from USB0 fine but not from the USB ports USB1 and 2 on the 13 pin header.
With the help of google and some ai I found that if I run the following my sd card is recognised when plugged into usb1
fdt addr bbf107b0
fdt set /soc/usb@5310000 status "okay"
bind /soc/usb@5310000 ehci_generic
usb reset
usb storage
That produced:
Bus usb@5310000: 2 USB Device(s) found
1 Storage Device(s) found
Kingston DataTraveler 3.0
57.7 GB
The uboot seems to be missing the commands for the other usb ports.
fdt addr ${fdtcontroladdr}
Working FDT set to bbf107b0
=> fdt set /soc/usb@5310000 status okay
=> fdt print /soc/usb@5310000
usb@5310000 {
compatible = "allwinner,sun50i-h616-ehci", "generic-ehci";
reg = <0x05310000 0x00000100>;
interrupts = <0x00000000 0x0000001e 0x00000004>;
clocks = <0x00000002 0x0000006a 0x00000002 0x0000006e 0x00000002 0x00000064>;
resets = <0x00000002 0x0000002c 0x00000002 0x00000030>;
phys = <0x0000001e 0x00000002>;
phy-names = "usb";
status = "okay";
phandle = <0x00000054>;
=> fdt set /soc/usb@5310400 status okay
=> fdt set /soc/usb@5311000 status okay
=> fdt set /soc/usb@5311400 status okay
=> bind /soc/usb@5310000 ehci_generic
=> bind /soc/usb@5310400 ohci_generic
=> bind /soc/usb@5311000 ehci_generic
=> bind /soc/usb@5311400 ohci_generic
=> usb reset
resetting USB...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Bus usb@5200000: 1 USB Device(s) found
Bus usb@5200400: 1 USB Device(s) found
Bus usb@5310400: 1 USB Device(s) found
Bus usb@5311000: 1 USB Device(s) found
Bus usb@5311400: 1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
does anyone have any advice on how i can update the image file code to support the additional usb ports. Ive tried looking at how to rebuild the u-boot-sunxi-with-spl.bin but could do with some guidance as ive not done this before.
Many thanks
Trev
  • Solution
Hi all i have an update. Ive managed to get it to work. Ive never done anything like this but hopefully this will help someone else. Im not sure the steps are correct but the change to uboot worked and i can now boot from usb1 not just usb0
so when your making your build and it asks about patch files ""Press ENTER to show a preview of your patch, or type 'stop' to stop patching..."" , in another window i ran.
cd build/cache/sources/u-boot-worktree/u-boot/v2026.07
find . -iname "*orangepi-zero3*"
grep -rn "ehci2\|ohci2\|ehci3\|ohci3\|usb@531" dts/upstream/src/arm64/allwinner/sun50i-h616.dtsi
cat > arch/arm/dts/sun50i-h618-orangepi-zero3-u-boot.dtsi << 'EOF'
#include "sunxi-u-boot.dtsi"
&ehci2 {
	status = "okay";
&ohci2 {
	status = "okay";
&ehci3 {
	status = "okay";
&ohci3 {
	status = "okay";
EOF
then i dropped back and carried on and i got
File: /home/armbian/build/output/patch/u-boot-sunxi64-current.patch
i then did this.
Move the patch into userpatches
mkdir -p /home/armbian/build/userpatches/u-boot/v2026.07-sunxi64
cp /home/armbian/build/output/patch/u-boot-sunxi64-current.patch /home/armbian/build/userpatches/u-boot/v2026.07-sunxi64/
check its there
ls /home/armbian/build/userpatches/u-boot/v2026.07-sunxi64/
Run the real build
export PREFER_DOCKER=no
./compile.sh uboot BOARD=orangepizero3 BRANCH=current RELEASE=trixie BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no ARTIFACT_IGNORE_CACHE=yes
when it finished i ran
find cache/sources/u-boot-worktree -name "u-boot-sunxi-with-spl.bin"
and it returned
cache/sources/u-boot-worktree/u-boot/v2026.07/u-boot-sunxi-with-spl.bin
i tested it by putting it on an sd card and plugging a bootable usb drive into usb1 (on the 13pin header) and went into uboot and ran
usb start
usb tree
you should see (Please not i hadnt removed the usb from the inital usb0 socket hence the two drives found)
=> usb start
starting USB...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Bus usb@5200000: 2 USB Device(s) found
       scanning usb for storage devices... 2 Storage Device(s) found
=> usb tree
USB device tree:
  1  Hub (480 Mb/s, 0mA)
  |  u-boot EHCI Host Controller
  +-2  Mass Storage (480 Mb/s, 100mA)
       MXTronics MXT USB Device 150101v01
  1  Hub (12 Mb/s, 0mA)
      U-Boot Root Hub
       Kingston DataTraveler 3.0 E0D55EA573F01A4119E00696
      U-Boot Root Hub
      U-Boot Root Hub
i then tested booting from usb 1 which was fine.
so i then wrote the file with.
sudo flashcp cache/sources/u-boot-worktree/u-boot/v2026.07/u-boot-sunxi-with-spl.bin /dev/mtd0
Now i need to workout SPI and GPIO control for my home tv control project.
Trev
